dave
Posted: Mon Jan 15, 2007 5:11 am Post subject: Lesson Learned Hand prop |
David,
Great report and luckily you are ok .
YES !! Always treat props as live, as you found out a loose ground
connection is all it takes.
I routinely hand prop a 582 and 503 near daily .
I think most engines can be hand proped.
One bonus of a 2 stroke on a Kitfox is that you can prop from left side
holding onto door frame or ona 912 from the right side with full access to
the controls.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Mon Jan 15, 2007 6:35 am Post subject: Lesson Learned Hand prop |
When working on GA engines I always use a clip lead to ground the p-terminal
right on the mag. With the Rotax 582 in my own plane I always treat it as
if it was primed to go. So far I've been lucky with that. One idea would be
to remove the spark plug leads.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Mon Jan 15, 2007 9:59 am Post subject: Lesson Learned Hand prop |
Michel,
Ahh the Jab is CDI and not magneto .
Rotax are CDI but with the gear box you get 2.2 to 3.to 1 ratios to help
spin the crankshaft that much faster.
Ducati ignition needs about 270 to 300 rpm to actually be able to get the
any spark at all. I would assume the Jab is simular.
That being said the point igntion rotax 2 strokes will fire easier than the
CDI igntion.
Regardless, Hand proping can be dangerous but sometimes essential. On 2
strokes I always turn the prop at least 5 turns to loosen up the gear box
oil. This really helps save the battery. I also check mags on startup , run
up and shutdown.
Dave
Michel
Posted: Mon Jan 15, 2007 11:27 am Post subject: Lesson Learned Hand prop |
On Jan 15, 2007, at 4:59 PM, dave wrote:
| Quote: | Ahh the Jab is CDI and not magneto .
Er ... no Dave. I think I have coils and not capacitors. But I
understand that it has to spin 300 RPM to create a spark at the plug.
Please note that I don't know much about engines and the little I know
is about marine diesels, an entirely different ball game.
I do spin the prop by hand, at each preflight. I do it in the hangar,
after checking oil and gascolator. I hand turn the prop 5 to 10 times,
feeling the compression and listening for telltale breathing sound, or
unusual noise. In the winter, I do it with the choke open. It brings
fuel in the carb, which makes starting easier. Mind you, all this is
what I was told to do by my Jabiru dealer and since he still has all
his fingers, I assume it's safe.
Michel
Float Flyr
Posted: Mon Jan 15, 2007 2:21 pm Post subject: Lesson Learned Hand prop |
CDI or not before you turn over a prop by hand check to make sure the mag
switches are off. If you have the mag switches on your ignition key just
put it in your pocket. Stranger things have happened.
My 20 YO., V4, 90 horse outboard is supposed to have CDI on it and I've
started it many times with a short piece of cord wrapped around the top
flywheel. Most of the time it starts before I've pulled the chord
completely through it's length.
I don't want any one to end up with the nickname "Lefty"
Noel
[quote] --
Kitfox III-A
wliles(at)bayou.com Guest
Posted: Mon Jan 15, 2007 6:08 pm Post subject: Lesson Learned Hand prop |
Noel removing the spark plug leads would certainly keep the engine from
starting, however, the Ducati ignition modules can be ruined if they get
enough charge and can't discharge through the plugs. Better to unplug
the modules from the engine coil.
Jerry Liles
Noel Loveys wrote:
Noel
Float Flyr
Posted: Mon Jan 15, 2007 9:26 pm Post subject: Lesson Learned Hand prop |
Sounds logical... Thanks
The main thing is to be careful.... You don't want to be the one that has
an engine start unexpectedly.
Noel
[quote] --
Kitfox III-A
Michel
Posted: Tue Jan 16, 2007 12:55 am Post subject: Lesson Learned Hand prop |
| Quote: | From: Noel Loveys [noelloveys(at)yahoo.ca]
switches are off.
Yep! And that's why I wrote that I hand prop in the hangar, Noel, prior to enter or move the plane; and just after the oil and gascolator check. It's like a ritual. For the oil, I don't even need to wipe the dipstick; for the gascolator, if any water or dirt is there, it will come out first as it would have settled at the bottom.
Michel
Float Flyr
Posted: Tue Jan 16, 2007 6:10 am Post subject: Lesson Learned Hand prop |
I do a post flight inspection... I consider that to be the important one.
If there are any little things about the plane that I want to check on it
will be fresh in my mind.
Then I trailer the plane home and put it in my garage/workshop and now
hangar. Before the next fight I will check everything. All hoses, tubes,
filters ( gascolator) and of course wiring.
When I go to fly I will do a whole walk around/ inspection again. Last year
I found on the final inspection that the rudder had been bent.. It took a
day to get it ready to fly again.
Noel
[quote] --
Kitfox III-A
