larger wire fuselinks
sportav8r(at)gmail.com
PostPosted: Mon Jan 15, 2007 8:32 am    Post subject: larger wire fuselinks Reply with quote
Bob- your site says to contact you for fabrication of larger
fuselinks than 20 or 22 AWG.
I'm going to need an 8 AWG fuselink in my 4 AWG starter/alternator B+
wire. Pointers, please?
-Bill B
nuckollsr(at)cox.net
PostPosted: Mon Jan 15, 2007 10:24 am    Post subject: larger wire fuselinks Reply with quote
Use an ANL or MAX-inline fuse holder. Fusible links should
not be applied to uses other than those illustrated and
sized in the Z-figures.
< with experiment. >
< --Lawrence M. Krauss >
I'm sorry, that should read, the 8AWG run from the alternator to the
PM starter solenoid lug needs a 12 AWG fuselink; can you advise how
best to construct one?
The run from the battery to the starter is obviously protected by the
battery contactor; my fault for not having the schematic open in front
of me as I wrote the querry.
-Bill
-Bill B
