bobbyhester(at)charter.ne Guest
Posted: Sun Jan 14, 2007 7:41 pm Post subject: Superior Recall followup |
This weekend I swaped out my Superior cylinders and pistons. There was a recall on the cylinders because of soft barrels (the barrels were not hardened properly). You can read all about it on their web site: http://www.superiorairparts.com/index.asp
[img]cid:part1.09070205.04070502(at)charter.net[/img] [img]cid:part2.01080204.05000704(at)charter.net[/img]
If you missed the details that I found out, that are not listed in the recall here they are again:
Here is some additional info that I found out.
The FAA had them issue the Service Bulletin right away. They know who owns the cylinders that are recalled and will be sending out letters to the affective customers as soon as possible. To speed up the process they created the Quick check form link from the online service bulletin http://www.superiorairparts.com/sb0601/ this is were you can type in your serial numbers and find out if they are on the recall list. If they are, you need to fill out the online Warrenty Claims Form. They will use this info to process the recall.
Manufacture date format info
In the recall it shows were to find the date of manufacture of the cylinder from within serial number.
The example shown is 52-F05-32055.
F05 is the date code BUT IT DOES NOT MEAN FEB. 05' , It means June 05'
A=JAN B=FEB C=MARCH D=APRIL
E=MAY F=JUNE G=JULY H=AUG
I=Is not used J=SEPT K=OCT L=NOV
M=DEC
| Description: |
| Filesize: |
19.16 KB |
| Viewed: |
329 Time(s) |
| Description: |
| Filesize: |
16.91 KB |
| Viewed: |
312 Time(s) |
