over voltage protection
aurbo(at)ak.net
PostPosted: Sat Jan 13, 2007 5:20 pm    Post subject: over voltage protection Reply with quote
Hello,
I don't want to start a IR/non IR alternator war here but I have a question.
I am going to be using the ND 55 (or at least it is the Van's 60 Amp model and it is already on order) and I don't want to use the over voltage protection. I don't think it is necessary and I can't figure out where to install another one of the huge contactors.
I am following the Z-11 system. I was wondering if I were to just by pass the part on the drawing for the over voltage and wire the Number 4 contact directly to the F terminal on the Alternator and the wire from the Number 2 terminal to the Battery contactor would that work.
Would installing the crow bar O.V. protect module after the 5 amp pull able fuse offer any advantages if I don't install the battery disconnect contactor?
Electro-confusion
Mike Ice
Electric's
nuckollsr(at)cox.net
PostPosted: Sun Jan 14, 2007 8:18 am    Post subject: over voltage protection Reply with quote
At 04:19 PM 1/13/2007 -0900, you wrote:
Hello,
contactor?
At the present time, there is no one-size-fits-all ov protection
scheme available for internally regulated alternators. I have
taken possession of a 10 hp alternator drive stand that needs
some serious attention before I can use it for any new investigations
or development work. However, know that a technique has been
devised and will be turned into real product sometime this year.
Further, the device is easily added to any existing alternator
installation. I'll suggest you proceed with your plans while
bypassing the ov protection and control issues. We'll fill this
box in later.
< with experiment. >
< --Lawrence M. Krauss >
aurbo(at)ak.net
PostPosted: Sun Jan 14, 2007 8:45 am    Post subject: over voltage protection Reply with quote
Bob,
Thank you for a practical answer. I will keep looking for this new technique
and product that you speak of.
Mike
