VW engine/pics
roncarolnikko(at)hotmail.
PostPosted: Sat Jan 13, 2007 10:41 am    Post subject: VW engine/pics Reply with quote
Hi Kieth check the archives as this subject keeps popping up. I'll try to
post pics to sportflight if I get time meanwhile I'll attach some to this.
Sorry If the files are large. One suggestion is to use more than 1915cc like
I did. Valley Engineering LLC makes a redrive. Ron NB Ore 1915cc VW,
1.61:1 redrive, 72" Ivo ~50 hours and going flying now.
Subject: VW engine
Date: Sat, 13 Jan 2007 06:25:14 -0800
Ron,
New to this and asking questions. VW is the way I am considering going.
Any advice, suggestions, pics.
Keith C.
Sacto, CA
From photos to predictions, The MSN Entertainment Guide to Golden Globes has
it all. http://tv.msn.com/tv/globes2007/?icid=nctagline1
 Filesize:  25.2 KB
 Viewed:  354 Time(s)
 Filesize:  33.41 KB
 Viewed:  328 Time(s)
 Filesize:  32.69 KB
 Viewed:  325 Time(s)
 Filesize:  38.99 KB
 Viewed:  324 Time(s)
 Filesize:  38.15 KB
 Viewed:  310 Time(s)
edygert(at)charter.net
PostPosted: Sat Jan 13, 2007 3:45 pm    Post subject: VW engine/pics Reply with quote
Ron, good pictures...thanks!
What's your compression ratio and the fuel type you are running?
Cyl head, oil temps?
Also, what kind for alternator for elect power?
Ed Dygert, in TN
to post pics to sportflight if I get time meanwhile I'll attach some to this.
like I did. Valley Engineering LLC makes a redrive. Ron NB Ore 1915cc
VW, 1.61:1 redrive, 72" Ivo ~50 hours and going flying now.
>From: "Keith C." <kcflys(at)pacbell.net>
>Subject: VW engine
>Ron,
>Thanks,
>Keith C.
>Sacto, CA
has it all. http://tv.msn.com/tv/globes2007/?icid=nctagline1
2:04 PM
PostPosted: Sat Jan 13, 2007 7:44 pm    Post subject: VW engine/pics Reply with quote
Type one case, 94 mm pistons, ~8:1 compression, 87 octane 3000-3500 rpm. I
used a Diel accesory case which has the mag drive, alternator and starter as
well as lycoming mounting bushings. Great Plains Aircraft sells all the
stuff for the motor, but you can buy a new stroker crank and stroker pistons
on Fleabay for much less. Oil temp in summer around 190 today never came
off the peg. Cylinder head temps were through the roof reading under the
spark plug. Moved sender under head bolt and now 375 tops. Got that tip
from GP Aircraft. Got one hour flying in today. Ron NB Ore
Subject: RE: VW engine/pics
Date: Sat, 13 Jan 2007 17:46:51 -0600
Ed Dygert, in TN
PostPosted: Sun Jan 14, 2007 10:15 am    Post subject: VW engine/pics Reply with quote
Hey Ron,
Thanks for the pics and advice, all will be needed as I go through this.
Keith
Sacto
PostPosted: Sun Jan 14, 2007 8:56 pm    Post subject: VW engine/pics Reply with quote
I think the pics get stored somewhere on matronics, but I'll send some
direct. Anyone know where to find the pics in digest surfing? Ron NB Ore
To: <roncarolnikko(at)hotmail.com>
Subject: Re: VW engine/pics
Date: Sun, 14 Jan 2007 13:19:54 -0600
Hi Ron,
I get the list in the digest format and did not receive the file & pics.
Would you mind sending them to me?
larry
Type your favorite song.  Get a customized station.  Try MSN Radio powered
by Pandora. http://radio.msn.com/?icid=T002MSN03A07001
