Derburring Rib Flange Slots
arthurww
PostPosted: Tue Jan 09, 2007 1:01 pm    Post subject: Derburring Rib Flange Slots Reply with quote
Looked at the ribs for the VS last night.
Alot of head scratching... how on earth am I supposed
to deburr those flange slots?
How have you done it?
Can anyone point me towards that magic tool?
Arthur
 Filesize:  1.36 MB
 Viewed:  555 Time(s)
#40641 EMP
mike(at)cleavelandtool.co
PostPosted: Tue Jan 09, 2007 1:15 pm    Post subject: Derburring Rib Flange Slots Reply with quote
I drag scotch brite through folded in half
On 1/9/07, arthurww <arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)> wrote:[quote] --> RV10-List message posted by: "arthurww" <arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)>
Arthur
#40641 EMP
http://forums.matronics.com/viewtopic.php?p=86619#86619
http://forums.matronics.com//files/p1010007_275.jpg
www.cleavelandtool.com [quote][b]
MauleDriver(at)nc.rr.com
PostPosted: Tue Jan 09, 2007 1:35 pm    Post subject: Derburring Rib Flange Slots Reply with quote
I learned from the folks at the Alexander Tech Center to do it with the
scotchbrite wheels. Not pretty but fast and effective. Don't know how
I would explain it though. I'm curious what others do too.
Arthur
#40641 EMP
PostPosted: Tue Jan 09, 2007 1:54 pm    Post subject: Derburring Rib Flange Slots Reply with quote
I do that to the outside... you get the inside?
On 1/9/07, MauleDriver <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote: [quote]--> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
Arthur
#40641 EMP
Cleaveland Aircraft Tool
515-432-6794
indigoonlatigo(at)msn.com
PostPosted: Tue Jan 09, 2007 3:04 pm    Post subject: Derburring Rib Flange Slots Reply with quote
Get one of those black emery boards with the cushioned backing at the
pharmacy. They work great. Each side has a different coarseness. The round
part of the flange can be down done with the deburring blade tool.
JOhn G.
From: "Mike Lauritsen - Work" <mike(at)cleavelandtool.com>
Subject: Re: Derburring Rib Flange Slots
Date: Tue, 9 Jan 2007 15:13:59 -0600
>Regards
>Arthur
>#40641 EMP
>Read this topic online here:
Mike Lauritsen
515-432-6794
arthurww
PostPosted: Tue Jan 09, 2007 3:50 pm    Post subject: Re: Derburring Rib Flange Slots Reply with quote
I am getting some emery cloth strip (p400) to try, but will have to work out
a good way to hold the parts because you need 2 hands for the strip.....
#40641 EMP
Rick S.
PostPosted: Tue Jan 09, 2007 7:07 pm    Post subject: Derburring Rib Flange Slots Reply with quote
Lowes sells these mini scotchbrite wheels for Dremel tools and Sears has some cone shaped deburring bits made of similar material. They make quick work of doing the flanges..Hehe....glad I'm done with that task
Drive on for all you guys looking at that stinking pile of wing ribs!! Wink
Rick S.
40185
RV-10 composite parts
Rick S.
RV-10
40185
KiloPapa
PostPosted: Tue Jan 09, 2007 9:06 pm    Post subject: Derburring Rib Flange Slots Reply with quote
Try 600 silicon carbide sandpaper on a tongue depressor.
Kevin
40494
Arthur
#40641 EMP
Kevin
40494
sstella(at)incisaledge.co
PostPosted: Wed Jan 10, 2007 5:44 am    Post subject: Derburring Rib Flange Slots Reply with quote
I was able to use a scotchbrite wheel from the outside of the slot to get
most of it, then I used the pads to finish it off.
Steve Stella
40654 Emp
PostPosted: Wed Jan 10, 2007 6:22 am    Post subject: Derburring Rib Flange Slots Reply with quote
I think we only hit the outside and touched up the inside with the pad -
it's been awhile.
Since then, I tried the various powered mini-wheels and pad holders but
it looks like John G's nail file pads are the ticket. You definitely
want a couple of those in the tool box.
On 1/9/07, *MauleDriver* <MauleDriver(at)nc.rr.com
<mailto:MauleDriver(at)nc.rr.com>> wrote:
<MauleDriver(at)nc.rr.com <mailto:MauleDriver(at)nc.rr.com>>
with the
know how
arthurww wrote:
<mailto:arthur(at)cftech.co.uk>>
> Regards
> Arthur
arthurww
PostPosted: Thu Jan 11, 2007 3:47 pm    Post subject: Re: Derburring Rib Flange Slots Reply with quote
I think I may have found that magic tool...
3M (of course) do a 3mm thick unitized cut & polish wheel.
Available in 3 diameters 38, 50 & 75mm.
Tried one tonight in a right angle die grinder... seemed to work very well
and quite quick.
Arthur
#40641 EMP
PostPosted: Fri Jan 12, 2007 7:08 am    Post subject: Derburring Rib Flange Slots Reply with quote
If you guys want them, I can supply them. I found that both those and the bristle disks will wear very quickly, thus I didn't think they were a good value. But I am happy to stock anything that is in demand Smile If you would like them email me directly.
Mike Lauritsen
515-432-6794
On 1/11/07, arthurww <arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)> wrote:[quote] --> RV10-List message posted by: "arthurww" <arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)>
and quite quick.
Arthur
#40641 EMP
jeff(at)westcottpress.com
PostPosted: Fri Jan 12, 2007 8:08 am    Post subject: Derburring Rib Flange Slots Reply with quote
Hi Mike,
While you're talking about stocking things... I was on the ezburr (www.ezburr.com) website the other day and saw that they will custom manufacture bits that drill and deburr in one step.  I didn't delve into it enough to determine the costs involved, but it seems to me that it's something that you could pursue and offer to the builders if the economies of scale work out.
Jeff Carpenter
40304
I was on the Burr Away
On Jan 12, 2007, at 7:08 AM, Mike Lauritsen - Work wrote:
[quote]If you guys want them, I can supply them.  I found that both those and the bristle disks will wear very quickly, thus I didn't think they were a good value.  But I am happy to stock anything that is in demand Smile  If you would like them email me directly.
Mike Lauritsen
515-432-6794
and quite quick.
Arthur
#40641 EMP
PostPosted: Fri Jan 12, 2007 8:35 am    Post subject: Derburring Rib Flange Slots Reply with quote
Checking into it. Stock they start at 3/8". These cutters were designed to use in a milling machine or a very rigid application. I know that builders have had mixed results, some swear by them, some swear at them. I am willing to try it to see if there is a better solution out there. For those that use them, do you still deburr the two sides that are between the parts (inside of the skin, outside of the substructure)?
On 1/12/07, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:[quote] Hi Mike,
While you're talking about stocking things... I was on the ezburr (www.ezburr.com ) website the other day and saw that they will custom manufacture bits that drill and deburr in one step. I didn't delve into it enough to determine the costs involved, but it seems to me that it's something that you could pursue and offer to the builders if the economies of scale work out.
Jeff Carpenter
40304
Mike Lauritsen
515-432-6794
On 1/11/07, arthurww < arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)> wrote:
--> RV10-List message posted by: "arthurww" < arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)>
and quite quick.
Arthur
#40641 EMP
href="http://www.matronics.com/Navigator?RV10-List">
href="http://forums.matronics.com">
[b] http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com
Mike Lauritsen
515-432-6794
arthurww
PostPosted: Fri Jan 12, 2007 9:14 am    Post subject: Re: Derburring Rib Flange Slots Reply with quote
Ok Mike but they are cheap aren't they?
Especially if you live in the UK. Wink
#40641 EMP
PostPosted: Fri Jan 12, 2007 9:23 am    Post subject: Derburring Rib Flange Slots Reply with quote
Sorry, I though we were talking about a 3M product Wink
On 1/12/07, arthurww <arthur(at)cftech.co.uk (arthur(at)cftech.co.uk)> wrote:
Especially if you live in the UK. [Wink]
#40641 EMP
rvbuilder(at)sausen.net
PostPosted: Fri Jan 12, 2007 11:06 am    Post subject: Derburring Rib Flange Slots Reply with quote
I Used the Cogsdill quite a bit and they were generally ok if you set the tension correctly. They were always a bit fragile though and changing the blade was a female dog. I don’t know if the single step version of the ezburr would be useful because you still need to take the pieces apart in order to get both sides but their standard deburr tool looks greatly improved and much beefier than the Cogsdill.
Michael Sausen
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lauritsen - Work
Sent: Friday, January 12, 2007 10:33 AM
Subject: Re: Re: Derburring Rib Flange Slots
Hi Mike,
Jeff Carpenter
40304
Mike Lauritsen
515-432-6794
and quite quick.
Arthur
#40641 EMP
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com
http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhref="http://www.matronics.com/Navigator?RV10-List">
5
6
7
8
9
5
6
jjessen
PostPosted: Mon Jan 15, 2007 1:31 pm    Post subject: Derburring Rib Flange Slots Reply with quote
I use the Cogsdill and other than a couple broken blades, really like them. However, I'd sure like some definitive yea or nea on the use of scotch brite deburring-by-rubbing technique discussed awhile back, especially for those using reamers. For those using the Cogsdill, I set my air at 20 pounds and it seems to produce a just right rotation for the drill. I'm using a Sioux. If anyone has an opinion on the correct rotational speed, I'd like to know.
John Jessen (he who is about to head back home and a weekend of building)
#328
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Friday, January 12, 2007 2:07 PM
Subject: RE: Re: Derburring Rib Flange Slots
Michael Sausen
Hi Mike,
Jeff Carpenter
40304
Mike Lauritsen
515-432-6794
and quite quick.
Arthur
#40641 EMP
href="http://www.matronics.com/Navigator?RV10-List">[/url][url=http://www.matronics.com/Navigator?RV10-List]http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">[/url][url=http://forums.matronics.com]http://forums.matronics.com
http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhref="http://www.matronics.com/Navigator?RV10-List">[/url]
href="[url=http://www.matronics.com/Navigator?RV10-List]http://www.matronics.com/Navigator?RV10-List">[/url]
5
6
7
8
9
5
6
7 [quote][b]
