Sean Blair
Joined: 09 Jan 2006 Posts: 39 Location: Colorado Springs
Posted: Tue Jan 31, 2006 9:01 pm Post subject: Center fuselage |
I’m confused……. I’m currently riveting the bottom skins on the center fuselage and if you take a look at the rivet callout, Section 26, page 8, it shows rivets on the leading edge of the F-1077 skin, and nothing on the mating trailing end of the F-1076 skin. To me this is backward considering the overlap should be with air flow and not against it. The previous page seems correct with the F-1076 on top of the F-1077. This is just the opposite of the rivet callout page. Is my thinking correct?
Thanks!
Sean Blair
#40225
_________________ Sean S. Blair
#40225
N967SB (reserved) |
rvbuilder(at)sausen.net Guest
Posted: Wed Feb 01, 2006 4:28 am Post subject: Center fuselage |
Sean,
I think this is just how they did the rivet picture. You are correct in going with the assembly picture on 26-7.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Blair
Sent: Tuesday, January 31, 2006 10:59 PM
Subject: Center fuselage
Thanks!
Sean Blair
#40225
