2-10 Switch
sonex76(at)velocity.net
PostPosted: Sat Jan 06, 2007 7:44 pm    Post subject: 2-10 Switch Reply with quote
Hello,
I am wiring my aircraft per drawing Z-20 for a Jabiru engine
and am having a hard time wrapping my mind around
the wiring of the 2-10 switch. The book says this switch function
is ON-ON-ON. I want the bottom position to have Master OFF;
middle position Master ON and the top position to be Alternator ON.
I am using the OV disconnect relay system, a starter solenoid and
a battery solenoid.
Would someone mind try and explain this switch wiring to me
based on the Z-20 drawing.. Please!!
Thanks in advance..
Dick Fisher
sonex76(at)velocity.net (sonex76(at)velocity.net)
nuckollsr(at)cox.net
PostPosted: Sat Jan 06, 2007 10:51 pm    Post subject: 2-10 Switch Reply with quote
At 10:43 PM 1/6/2007 -0500, you wrote:
Hello,
a battery solenoid.
This is explained in detail in Chapter 11 of the 'Connection.
There is also some information on the 2-10 switch operation
and terminal numbering conventions in Appendix Z figure
at the bottom of Page Z-9 and Note 15 on page Z-10.
If you study the wiring of the DC Power Master switch
in Z-20 (or any other z-figures) you'll see that when
the switch is in full down position (as drawn) there is
no pathway for either the battery or alternator . . . I.e.
the system is OFF. Now, the switch is designated as
an ON-ON-ON functionality because there are some connections
made through the switch in any of its three positions.
As wired, we do not connect to terminals 3 and 6 which
provide conduction pathway in the lower position of the handle.
With nothing connected to 3 and 6, then the lowest position
of the handle produces a system OFF condition.
In the mid position, terminals 1 and 2 are connected
which closes the battery circuit . . . but terminals 5 and
6 are still connected on the other side of the switch leaving
the alternator OFF. Moving the switch one more step leaves
terminals 1 and 2 connected (battery still on) and connects
terminals 4 and 5 are now connected which adds alternator
operation.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Sun Jan 07, 2007 6:13 am    Post subject: 2-10 Switch Reply with quote
Thank you very much for the clear and concise answer
to my questions on the 2-10 switch. I am now able to
understand the functionality as depicted in your drawing.
Dick Fisher
