schmoboy(at)cox.net Guest
Posted: Wed Jan 04, 2006 9:36 am Post subject: DuckWorks Landing Lights AND AOA |
Ok, I have two DW HID landing light kits, one for each wing and I also
have the AOA kit.
Anyone else have this scenario where both the HID kit and the AOA are
recommended in the outer most bay of the leading edge. It's seems I may
have space problems between the HID mounting bracket and the AOA port
location.
Any suggestions from those out there that have the DW kits and the AOA?
-Sean #40303
Tim(at)MyRV10.com Guest
Posted: Wed Jan 04, 2006 10:27 am Post subject: DuckWorks Landing Lights AND AOA |
I dont' have the AOA, but have a question for you. Have you
found that there will be interference, or are you just
trying to find out ahead of time if there will be interference?
The HID mounts pretty far forward in the wing. I don't know
where the AOA mounts. It would seem like you'd have to be
pretty unlucky though to have that same piece of space
used by both, and not be able to get around it. Is that
what you found though?
Sean Stephens wrote:
rvbuilder(at)sausen.net Guest
Posted: Wed Jan 04, 2006 10:43 am Post subject: DuckWorks Landing Lights AND AOA |
Nope, plenty of room. I have the HID and AoA ports in the same bay.
<http://www.kitlog.com/users/display log.php?user=msausen&project=22&category=940&log=1017&row= 3>
CJohnston(at)popsound.com Guest
Posted: Wed Jan 04, 2006 10:51 am Post subject: DuckWorks Landing Lights AND AOA |
ACS lists the AOA position for the '10 at 9" forward of the wing skin
break at the spar in the middle of the bay (offset by 2" top and
bottom). Funnily enough, I just completed my HID install (thanks tim)
and panicked a bit when I thought of where the AOA goes. Unfortunately,
I panicked while daydreaming about it at work and can't measure to find
out til I get home. That last bay is getting crowded though...
cj
#40410
wings
www.perfectlygoodairplane.net
bob.condrey(at)baesystems Guest
Posted: Wed Jan 04, 2006 11:02 am Post subject: DuckWorks Landing Lights AND AOA |
Wow, finally a toy you don't have! Here's the info from the AFS website
showing the exact pressure tap locations for the AOA:
http://www.advanced-control-systems.com/AOAsupport/aoasupport.htm
Actual hole is very small but the pressure tap itself (inside of wing)
is about 1.5" or so in diameter and 2-3 inches in length. They install
with a couple of small screws through the skin.
Also, in my earlier email I called it the PSS AOA System. Rob Hickman
of Advanced Flight Systems actually bought the product line a while back
and now it's officially the AFS AOA System. Sorry Rob...
Bob #40105
Posted: Wed Jan 04, 2006 11:23 am Post subject: DuckWorks Landing Lights AND AOA |
Just looking for previous experience prior to cutting the HID hole.
> also have the AOA kit.
> may have space problems between the HID mounting bracket and the AOA
> port location.
> -Sean #40303
Posted: Wed Jan 04, 2006 11:24 am Post subject: DuckWorks Landing Lights AND AOA |
Thanks Michael. I knew someone would have done it before me.
-Sean
RV Builder (Michael Sausen) wrote:
3>
Michael Sausen
-10 #352 Fuselage
Posted: Wed Jan 04, 2006 11:25 am Post subject: DuckWorks Landing Lights AND AOA |
BTW: What type of sealant did you use to mate the ports to the skins?
In the pic it looks like something clear.
-Sean
3>
Michael Sausen
-10 #352 Fuselage
Posted: Wed Jan 04, 2006 11:48 am Post subject: DuckWorks Landing Lights AND AOA |
Ah yes, that would be the super high tech, space age glue called shoe goo also known as E6000.
Jekyll
Posted: Sat Feb 25, 2006 1:03 pm Post subject: Re: DuckWorks Landing Lights AND AOA |
| schmoboy(at)cox.net wrote: |
have the AOA kit.
location.
-Sean #40303 |
I installed both in a RV7 - no problemo. I was more concerned about airflow disruption resulting from the cutout because of the warnings in the manual to ensure a smooth flow. I emailed Rob Hickman and he said no worry. Cut away and put both in the same bay. Mine were simple to install. I put a regular light in front of the AoA but the HID would be no different. My other wing has a HID and I put the power supply on the outboard side of the rib so it is easilly accessable from the removeable wing tip and this, of course, would not interfere with the AoA.
Jekyll
