Fox5flyer Guest
Posted: Sat Dec 30, 2006 9:50 am Post subject: Possible overheating and EGT question |
The ambient cockpit temp may very well be at 68f, but I wouldn't bet on what
it is under that panel. It depends on a lot of things, some of which are
the radios, transponder, various other heat producing electronics, heater
fluid lines and the heater core itself (if there is one), amount of heat
producing sunlight hitting the (usually) dark glare shield, heat being
transmitted by the firewall, etc. My EIS has an internal temp reading that
is often over 120f on hot flying days. Well, hot for up here in NE Michigan
anyway. I imagine it would be considerably higher down in the desert
climates. Of course, this is all relative to the amount of ventilation that
is provided for the electronics and I suspect that many of us have very
little to nothing. Hopefully my EIS compensates for that temp difference,
but if it really does, I don't know. Has anybody stuck a thermocouple up
under the panel to see what their temp is? I've always planned on running a
vent tube up there, but I just haven't been able to get to it.
Deke
S5
snip...
| Quote: | My EGT doesn't have any compensation built in but the documentation says
it
| Quote: | is calibrated for 20C (68F) Since my cockpit temps seldom if ever get
above
| Quote: | 68F the instrument is usable. Even if the cockpit temps went up to 80F
the
| Quote: | accuracy of reading the meter because of parallax etc is probably close to
the 12F the meter will be reading too low.
In flight my EGTs show an almost even 1100F my plugs say they are getting
good mixture so I can now depend ( to an extent ) on my EGT gauge. I
will
| Quote: | probably continue to check my plugs every 5-10 hr.
..snip
Float Flyr
Posted: Sat Dec 30, 2006 12:13 pm Post subject: Possible overheating and EGT question |
All valid points Deke:
The only thing I have in my panel that can generate any heat is the T&B. I
tend to use my EGT mostly as a trend indicator and If I tell you my EGT was
1100F then there is an error Could be as much as 50F either way in that
reading. In the mean time I'm not too worried because there is enough air
leaks and draughts in the cockpit to fly a kite ( if I had more room). I
fold my wings after every flight and usually do a pretty good post flight
inspection so sealing the areas of air leaks isn't high priority for me. If
I put the skis on this winter I'll just wear my WW II Flight pants and a
good heavy parka.
The documentation on your EIS should give you the operational temperature
range. I think the high end will probably be around 150F (65C). After that
thermal runaway of electronic components is a possibility. You will get an
indication of that when your EIS just stops. Seriously though there is
probably an indicator on your EIS to let you know when its too hot.
My mother always said, "When all else fails.... Read the instructions".
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
torgemor(at)online.no Guest
Posted: Sat Dec 30, 2006 12:39 pm Post subject: Possible overheating and EGT question |
Hi Lynn,
ok., then your instrument do compensate for "cold junction", good -seems
to be an excellent unit!
Those "new" instruments use "high impedance" amplifiers in the first
stage, therefore they do not load the "thermo couple" that much, the patch
cable may then be quite long, -even long enough for a Kitfox.
Interesting.
Cheers
Torgeir.
On Sat, 30 Dec 2006 15:49:15 +0100, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Right on Noel, re the speaker wire...not even Monster wire would work
here. : ) Actually though, the instructions say that you CAN cut the
wires shorter:
"NOTE: The length of wire on the EGT & CHT probes, or the extension wire
may be shortened as desired for your installation."
A personal note on their NOTE....I'm almost certain that I recall
speaking to Sandy at Grand Rapids Technologies (EIS) about shortening
the wires, and she said that you can shorten the wires coming from the
unit...actually the connector... but NOT the probe wires.
Torgeir-
I just read the manual re the "unit temperature"...to quote:
"This function is displayed on the hourmeter page, and shows the
internal temperature of the instrument. It is used by the instrument for
cold-junction compensation of the EGTs and CHTs. It is also useful for
estimating the cabin temperature, as it tends to stabilize at about
30-35 degrees F above the ambient temperature."
It goes on to mention that it (the unit temperature) can be used to
check for excessive instrument (the EIS itself) heat, but that's not
pertinent to this discussion.
Lynn
On Dec 30, 2006, at 9:00 AM, Noel Loveys wrote:
> Enough to say Lynn your EIS is probably a darn sight more accurate than
> my
> EGT. As long as you didn't cut any wires or use speaker zip wire in
> your
> installation.
> Noel
Lynn Matteson
Posted: Sat Dec 30, 2006 1:29 pm Post subject: Possible overheating and EGT question |
Quote from the (mine anyway) manual:
"Unit temperatures above 170 degrees F can degrade the readability of
the display. (The display will return to normal when it is cooled to
normal temperatures.) Temperatures above 200 deg F can activate the
internal thermal fuse, shutting down the instrument."
Lynn
T&B. I
EGT was
that
enough air
room). I
flight
for me. If
and a
good heavy parka.
temperature
After that
will get an
there is
instructions".
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Dec 30, 2006 1:35 pm Post subject: Possible overheating and EGT question |
Thanks for that summation, Torgeir. I'm no electronics guru...I don't
even play one on TV : )...so that vote of confidence in the EIS is
welcome news.
Lynn
p.s. Yes, the leads are quite long...mine are still coiled up behind
the panel...just in case. One of these days I'll shorten them up for
neatness' sake.
On Dec 30, 2006, at 3:39 PM, Torgeir Mortensen wrote:
<torgemor(at)online.no>
Hi Lynn,
seems to be an excellent unit!
first stage, therefore they do not load the "thermo couple" that
much, the patch cable may then be quite long, -even long enough for
a Kitfox.
Interesting.
Cheers
Torgeir.
N369LM |
Posted: Sat Dec 30, 2006 2:01 pm Post subject: Possible overheating and EGT question |
Lowell and All,
here's the next one about the EGT; this time about the thermocouple
connection methods, just the three of them.
In the end of this you'll find the visual wives of cold junction, the way
I often use to explain it.
This first one, is our standard Westach setup, a straight through setup
accepting some error.
The second one is the preferred connection setup of a thermocouple, this
one has no error if it is correctly corrected for cold junction
temperature and the instrument has no error!
The last one is a combination of the above, but also manipulating the
thermocouple resistance in order to extend the distance between probe and
indicator.
All of these drawings is made (yesterday night) with AutoCAD, the files is
converted to jpg for the ease of presentation. (They might look a little
“gray”, but this is due to the high compression.)
Next time we'll see how "cheap devices" can be used to measure cold
junction temperature and OAT.
(Prob. Next year.)
Torgeir.
17.47 KB |
272 Time(s) |
44.71 KB |
291 Time(s) |
47.46 KB |
296 Time(s) |
20.22 KB |
294 Time(s) |
Float Flyr
Posted: Sat Dec 30, 2006 2:44 pm Post subject: Possible overheating and EGT question |
That's normal for LCD displays. If you leave your GPS out in open sunlight
too long it will go all black and you won't be able to read anything on it.
After it cools even slightly the display returns to operational condition.
The 200 (F) thermal fuse is the upper end of the EIS operation ( the 'puter
that runs the display) if it gets that hot under your instrument panel (if
that's where your EIS unit is) believe me you're cooked or at least par
boiled.
The EIS unit Gathers info from your engine then drives your display...
There is no holy book that says it needs to be close to the display. I
would guess harnesses can be made for the digital display of any necessary
length.
I would love to have your system set up for the 582. Two strokes are
particular about EGT. Mixture can be changed by either applying or reducing
throttle and/or load.
Now I'll dream about a full FADEC two stroke fuel injection.... Hmmmm sounds
like the engine Rotax cancelled last spring.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Dec 30, 2006 4:05 pm Post subject: Possible overheating and EGT question |
I don't have CAD on this computer. My copy is 2000 and won't load onto the
XP. S I did this up on Photoshop.
It is a Rough, and I mean rough, diagram of my EGT schematic as came with my
EGT documentation... I don't intend to open the Instrument to check on the
location of the cold junction
Just one more configuration.
Still prefer the EIS set up Lynn has... Just need one for 2 cyc.
Cheers and Happy New Year
Noel
[quote] --
61.32 KB |
277 Time(s) |
Kitfox III-A
kenharrison(at)ubgcharlot Guest
Posted: Sun Dec 31, 2006 9:28 am Post subject: Possible overheating and EGT question |
Hello all,
I have a quick question on this topic of EIS/EGTs. I have searched the archives but don’t see any info. I have an EIS which I was going to use for EGT, CHT, Water temp. Has anyone considered using a regular “steam guage” EGT instrument in conjunction with the EIS, as a backup. Can such a thing be done on the same EGT probe?
I have a panel that has all the “steam gauges”, and would like to add the EIS as a backup to all of them if that’s possible. Has anybody ever done this?
Thanks for the help,
Ken
Float Flyr
Posted: Sun Dec 31, 2006 12:21 pm Post subject: Possible overheating and EGT question |
The "steam gauge" should be wired in parallel with the EIS using chromel(+) and alumel(-) wires. those wire can be hard to get. Some say it's ok to use copper wires but that introduces more junctions as well as resistances.
The problem is the resistance across the "steam gauge" is not nearly as high as the close to infinite resistance across the input terminals of your EIS. Therefore it is possible the introduction of a mechanical gauge will disrupt the calibration of your EIS. It could lower the voltage across both EGT and EIS inputs.
Another problem is your EIS probably has a cold junction built in to it which has the temperature consistently monitored. If Your steam gauge has a cold junction built in (it probably does) then that junction should be removed. That means opening the mechanical gauge head, removing the cold junction and resealing the gauge.
Go with the EIS alone on this one... If it goes blank you will have more to worry about than an EGT arbitrarily sky rocketing. There are some instruments that having a second back up set of gauges is nice to have e.g. tachometer and fuel quantity. but one of the reasons to install an EIS is to save weight so installing both won't help matters.
Noel [quote]
Kitfox III-A
czkree(at)netzero.net Guest
Posted: Mon Jan 01, 2007 12:23 pm Post subject: Possible overheating and EGT question |
You had talked about your egt's at take off being high or close to the max
limit. At take off I will assume you are at full throttle? At the full
throttle setting you are no longer using the needle, you would be using the
main jet. If the temps are high changing the needle will not do much for you
at full throttle. You will need to go in and change the main jet to the next
larger size. The needle is only going to affect your mid range. You ask if
it is normal to change carb settings? Sure it is as the density of the air
changes so does the mixture. More dense the air the leaner the mixture, less
dense air, richer mixture, if you do nothing. This is the most common time
to make the lean to rich change. In the spring it would be rich back to
lean.
As Rex stated you will not change the sync. if you do the same change to
both carbs.
Steve
STA-Lite Aviation, Inc.
Authorized Rotax Repair Station
www.staliteaviation.com
