apilot2(at)gmail.com Guest
Posted: Thu Dec 21, 2006 2:37 pm Post subject: IFR |
The only thing you will have to learn in your own aircraft is any new
equipment beyond what you used for the checkride, and to determine
what speeds and power settings work for the different phases of
descent, climb, holding, approach, which you have to determine in any
airplane. All planes made since about 1975 have a standard T
instrument layout of steam gauges. If you choose to go to EFIS, that
will just be learning a different presentation, but you need to know
the standard steam gauges for your backup. You need to be proficient
at flying the plane with a single gyro, compass, airspeed and
altimeter, without all the glass panel gizmos. If you can't do that,
how are you going to survive when you have one of those gizmos release
the smoke they contain and you have to shutdown your full electrical
system because you don't have the ability to crawl beneath the panel
and fly the airplane too and you only know that fire follows smoke?? E
bus means nothing if you have an electrically generated puff of smoke
in the cockpit and are in the soup. Just keep that in mind when
designing redunancy if you plan on flying IFR. Do you really want to
be testing electrical circuits to see which one generated the smoke
while trying to fly partial panel, solo?
On 12/21/06, Chris Johnston <CJohnston(at)popsound.com> wrote:
My approach to the whole IFR thing was basically that I will have to
re-learn IFR operations in my aircraft, because it will be so different
from how I trained. I'll have to get used to the EFIS, and cockpit
resource management in general, then wrangle an instructor to do an IPC
with me, and see what areas I need help in.
cj
#40410
fuse
www.perfectlygoodairplane.net
owl40188(at)yahoo.com Guest
Posted: Thu Dec 21, 2006 3:35 pm Post subject: IFR |
In light of this discussion I am attaching my current panel configuration for informational purposes. Its probably going to still change quiet a bit but the layout is probably close. I think the location of the instuments allows the pilot to use either a standard 6 pack or the EFIS tubes. I actually prefer a standard 6 pack in a lot of situations but want the HITS capability of the EFIS. The airplane will have a vacuum system and an EFIS.
Niko
40188
33.4 KB |
191 Time(s) |
Posted: Thu Dec 21, 2006 3:51 pm Post subject: IFR |
Aaah... I sense an upcoming heated discussion about what constitutes
acceptable backup systems for IFR. I definitely appreciate the gravity
(pun intended) of the situation, and what's at stake, but I'll stay out
of it. I think I can have enough fun perusing the archives on the
subject!
I guess the original question was is there a bunch of old IFR junk that
you can skip over if you are flying a technically advanced aircraft? My
admittedly limited experience sez nope. With the possible exception of
the ADF. Unless you want to listen to an AM radio station! (but you
still have to get those questions right on the written)
Remember, I'm a low time pilot, and the ink is still drying on my IFR
ticket. I don't really know anything. These are just things I think.
cj
#40410
fuse
Tim(at)MyRV10.com Guest
Posted: Thu Dec 21, 2006 4:20 pm Post subject: IFR |
Not bad, Niko, but I think you'll actually come to like the EFIS
better than the 6-pack for the references you can get. If it
were me, I'd flip them so the 6 pack is either low or to the right,
and center up your EFIS on your side of the plane so it's right
in front of you. I know you're trying to recreate a total
steam gauge set, but given what you have in the EFIS, I'd use
that more, and ditch the VSI and Turn Coordinator completely.
Even if all heck breaks loose, you can get by without those
2, although admittedly they do have useful purposes...but
if the steam gauges are your "backup", then it's not worth
duplicating those functions. On the other hand, if the EFIS
is your "backup", and you're adamant about that, then I'd
say you should ditch one of the screens, or just use it as
a full-screen map page.
Actually, the best thing for you since it looks like you're
on the fence about trusting that you'll like an EFIS, is
to get out and get in someone's plane with a GRT system
and fly behind it. You may be put at ease knowing that it
actually works pretty well. From a steam gauge replacement
point of view, today's EFIS's really do a great job at
taking over for a 6-pack. From an approach/terrain/weather
and more extended EFIS/MFD function point of view, then you
have to decide if the more expensive EFIS's are what you
need or not. The GRT stuff though is great in that it gives
you a lot for a little.
Niko wrote:
[quote] In light of this discussion I am attaching my current panel
Niko
40188
LIKE2LOOP(at)aol.com Guest
Posted: Thu Dec 21, 2006 6:01 pm Post subject: IFR |
In a message dated 12/21/06 5:23:02 P.M. Eastern Standard Time, apilot2(at)gmail.com writes:
| Quote: | Fact is the ONLY backup to GPS today is the conventional VOR/DME/ILS system, and that will continue for years into the future.
Does any one have current info on just how long the VOR system will be supported? I think it was going to expire in 2007, 2-3 years ago the VOR system got a life extension to when??? This must be published info somewhere??
Locally the PHK VOR got taken out with the dual hurricanes and is NOT scheduled to get replaced. I would expect very few VOR major repairs with the FAA budget woes, only standard maintenance. I would want to know more about VOR longevity before I build my panel, unless i was ready to buy NOW. Is this good thinking? I agree with Tim, learn them all, they are on the written test. And if it is in the plane you test in you do need to know how to use it. I also think 3 types of approaches are currently required for IFR flight exam. The three depend on your equipment. Is that correct?
Steve
rene(at)felker.com Guest
Rick S.
Posted: Thu Dec 21, 2006 7:03 pm Post subject: IFR |
Steve,
I can see VOR and DME...not ILS.
just a pennys worth...
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Rick S.
Posted: Thu Dec 21, 2006 7:25 pm Post subject: IFR |
CJ wrote: "Remember, I'm a low time pilot, and the ink is still drying on my IFR
ticket. I don't really know anything. These are just things I think."
Grasshopper you are wise beyond your years and your humble opinion of yourself is refreshing...
Now why do you jump out of airplanes and BASE jump??????
Rick S.
40185
RV-10
40185 |
Rick S.
Posted: Thu Dec 21, 2006 7:29 pm Post subject: IFR |
And you don't know nothing CJ?? Your well on your way young man.
CJ wrote:
"Hey Jeff -
I'm with you about not cluttering your head with "non-useful" or
outdated instrument flight training, and to a certain extent trying to
train for the IFR environment that you'll be flying in - ie: super
modern GPS with LPV approaches and EFIS systems that talk to the NAV and
provide ILS needles on the display etc. the reality is that you have to
know ALL of the stuff. I'm talking ADF OBS CDI DME arcs - everything.
First of all, it's all going to be on the knowledge test (written), and
second of all, the aircraft you'll be training in (unless you finish
your build and train in your own aircraft) will most likely have a
couple nav/coms, CDI/OBS, maybe even an ADF, and a slightly older IFR
GPS like a KLN94 if it has one at all. and if the aircraft has it,
you'll be expected to know how to navigate with it. The rule as it was
explained to me is that for your checkride, you have to show proficiency
with all the installed equipment. A friend of mine just got his IFR
ticket, and he didn't have to do any GPS approaches. Why? No IFR GPS
in the plane. Also, to a certain extent, it helps to understand the
evolution of some of the equipment and know how to use it. not sure
why.
RV-10
40185 |
etekberg(at)gmail.com Guest
Posted: Fri Dec 22, 2006 6:03 am Post subject: IFR |
What exactly do you disagree with?
As I stated, CAT 1 like minimums are available with LPV when the runway supports it (that means appropriate lighting, obstruction clearance, etc. - no ILS is required). The FAA is ramping LPV approach creation; they are working their way to thousands of LPV approaches (remember LPV is not your typical GPS approach at this point in time). Saying the typical GPS approach is going to remain crappy for a LONG time depends upon your definition of LONG. If long means anything more than a few years - you are dead wrong.
And where did I state to fly GPS only? I said to use GPS/NAV/COM as primary (maybe you forgot the NAV/COM part?) and have an adaquate backup VOR/ILS system in case of primary failure. And just for the record, the FAA has not determined what will be the GPS/WAAS backup will be yet. I don't expect VORs nor DMEs to be going anywhere for at least 1~2 decades.
Eric
On 12/21/06, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote: [quote]--> RV10-List message posted by: "Kelly McMullen" <apilot2(at)gmail.com (apilot2(at)gmail.com)>
I would disagree with that assessment. You will not get CAT I minimums
without ILS approach clearances, approach lighting and runway
lighting. Most runways that don't have ILS don't have the clear zones,
the approach lighting nor the runway lighting and markings. Most GPS
approaches are going to remain at non-precision minimums in the range
of 400-800 ft and 3/4 to 1 mile vis for a LONG time. Tim is right.
Learn the IFR system as it exists. Flying GPS only, will only diminish
your skills and ability to navigate when the GPS loses lock, system
crashes, loses power, etc. Fact is the ONLY backup to GPS today is the
the future.
On 12/21/06, Eric Ekberg <etekberg(at)gmail.com (etekberg(at)gmail.com)> wrote:
| Quote: | My 2 cents:
Get a WAAS capable GPS/NAV/COM and have a backup NAV/COM. If you get an
> audio panel you'll get a marker beacon receiver thrown in with it (although
| Quote: | they are going the way of the dodo also). A big FAA goal is the publishing
of LPV approaches (WAAS equivalent to CAT 1 - when runway supports it).
They aren't a big deal at this moment in time, but they will be soon. If
GPS fails you'll have VOR/ILS (backup NAV/COM) for fallback.
Also you should have in-cockpit weather (Garmin 396 or 496 is the cheapest
current method).
Of course with one engine and no ice protection I wouldn't call it a hard
IFR setup.
Eric
On 12/21/06, Jeff Carpenter < jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
> --> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com) >
| Quote: | > I'd like to expand this thread a bit to get some feedback on what I'd
> call Modern IFR equipment and the resulting training that's
> appropriate for using it.
> I've got about 250 hours, but haven't flown in over seven years. In
> many ways, I'll be starting over as I prepare to fly my RV-10.
> Instrument navigation, for me, was never more than triangulating off
> of a couple of VORs and perhaps getting some useful information off
> of a DME if the plane I was renting was so equipped.
> I plan to get back up to speed by getting my instrument rating.
> Starting over, I imagine that there are entire IFR systems I can do
> without... and not further clutter my head with "old fashioned"
> information.
> To what extent can I equip my plane without those things, still have
> safe alternatives should the gps system fail and avoid spending time
> instrument training for systems I won't be using?
Posted: Fri Dec 22, 2006 8:10 am Post subject: IFR |
What I disagree with is the concept that there will be thousands of
LPV approaches where there is no ILS today. Sure, the minimums are
approved, but have you looked at what is required for a precision
approach, regardless of the guidance? It isn't just designing an
approach. You have to spend the money to ensure an obstacle free
approach path, install approach lighting and runway lighting that
doesn't exist today, to CAT 1 ILS standards. Without that, you will be
limited to non-precision minimums. That is a fact. There is no big
budget to pay for all that runway and approach lighting improvement.
Unless the individual airports find a way to pay for it, it simply is
not going to happen in less than a decade.
On 12/22/06, Eric Ekberg <etekberg(at)gmail.com> wrote:
| Quote: | What exactly do you disagree with?
dead wrong.
Posted: Fri Dec 22, 2006 9:21 am Post subject: IFR |
I somewhat agree with the intent of what you just said there. But just to get some facts straight, there will be lots of LPV approaches where there are no ILSs today (they just won't be 200 feet approaches though).
But back to the intent, I don't think you are considering all the facts. Have you thought about those airports that may have the other infrastructure, but only 1 ILS system? In order to have an approach at both ends of the runway (pre-GPS/WAAS) you need two ILSs. With LPV you don't. Opposite runway ends and other runways become prime candidates I would think.
Are you aware that the typical ILS system requires the ground terrain at the airport to be straight and somewhat level? The traditional ILS reflects off the ground. I say traditional because there are other types of ILSs. If there are hills or mountains or other obstructions, they are much more difficult if not impossible to implement. LPV approaches have none of those concerns. What about these type airports that have the money, but not the terrain?
Also, ILS systems are expensive for the airport and require significant maintenance for the airport. LPV approaches are maintenance free and significantly reduce the cost of the approach to the airport. I would think that will mean more approaches for middle-income airports.
Regardless, even if we assume that all low minimum LPV approaches will only be ILS overlays, the bottom line question is: how is my equipment recommendation poor? It in no way precludes the use of ILS.
Eric
On 12/22/06, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote: [quote]--> RV10-List message posted by: "Kelly McMullen" <apilot2(at)gmail.com (apilot2(at)gmail.com)>
On 12/22/06, Eric Ekberg <etekberg(at)gmail.com (etekberg(at)gmail.com)> wrote:
[quote] What exactly do you disagree with?
definition of LONG. If long means anything more than a few years - you are [quote][b]
Posted: Fri Dec 22, 2006 9:48 am Post subject: IFR |
Yes, I'm well aware of what an ILS takes....(I used to be a controller
at an airport with a Cat II approach). Just because a runway has an
ILS at one end, doesn't mean it is good for a precision approach at
the other end. The glide slope requirements are what you are talking
about, not localizer. Costs for maintenance are a lot more than just
the transmitter. Runway and approach lighting and required backup
generators are major expenses that will also be required. That isn't
going to happen at airports without commercial service. Without them,
it is pretty unlikely the FAA is going to approve an approach to less
than 400 ft and 3/4 mi. And any sane pilot wouldn't want to fly them.
Adding a WAAS capable IFR certified unit to any panel is going to cost
you $10K, which many folks are not going to spend unless their mission
need calls for frequent use of LPV approaches. Only one WAAS certified
receiver is available today, two more in maybe 6 months. Existing ILSs
will be around for a long time, as will many of the VORs. WAAS is
about 5 yrs behind schedule now, LAAS has no realistic timetable, and
it is what you REALLY want to fly a precision GPS approach.
But back to the original discussion. We are talking about equipment
for a 250 hour pilot without an instrument rating, who is going to go
get his rating. Such a pilot has a long ways to go before they are
ready to shoot LPV approaches to minimums in real weather when they
really need to get down. That sort of pilot IMHO is best served to get
their rating with conventional equipment, then decide what is the
right level of equipment, rather than relying on advice of pilots who
have totally different mission profiles, skills and needs. It isn't
hard to pick up the GPS skills, it is much harder to go the other
direction, to transition from glass cockpit to steam gauges and VOR.
| Quote: | I somewhat agree with the intent of what you just said there. But just to
think.
terrain?
Eric
etc. -
your
are
Posted: Fri Dec 22, 2006 10:04 am Post subject: IFR |
Don't worry. If I had something to toot my horn about, you'd hear it
loud and clear! About aircraft construction, IFR flight or regs, or
piloting in general, there's waaaay more qualified people than me on
this list to provide answers. Risk assessment is something of a hobby
for me, and when calculating risk, I've found it important to qualify
the source of a piece of information - ie: direct experience, indirect
experience, etc. My least favorite thing is "conventional wisdom". I
can never seem to nail down sources for that kind of info. So when I
add a drop of personal experience into such a wealth of actual knowledge
and actual experience, it's important for me to qualify it.
Now, ask me about BASE jumping, skydiving, or canopy piloting and I'll
give you all the qualified answers you want! (see attached pictures!)
cj
#40410
fuse
49.24 KB |
159 Time(s) |
32.48 KB |
159 Time(s) |
38.69 KB |
182 Time(s) |
25.59 KB |
197 Time(s) |
