Landing Lights Part II
demeo(at)sonic.net
PostPosted: Sun Dec 17, 2006 7:26 pm    Post subject: Landing Lights Part II Reply with quote
Thanks for all the info in the first thread. This weekend while working
in an ice cold hanger I tried to bend the landing light lens into the
wing for fitting and final assembly. SNAP! It broke. So, I am
wondering what other material anyone has used in this application for a
landing light lens. The lens I broke was from LP Aero and appears to be
acrylic (the sticker on the lens did not indicate material type and
neither do the plans). Any ideas what would be appropriate on the
leading edge under all flight and weather conditions? Other builders
have told me their lenses are cracked and discolored in less than one
year's use. Would lycra or some other more pliable substitute be
appropriate?
Brad
The information contained in this transmission is attorney-client privileged and/or confidential information intended for the use of the individual or entity named-above as recipient. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
IRS circular 230 Disclosure: As required by U.S. Treasury Regulations governing tax practice, you are hereby advised that any written tax advice contatined herein was not written or intended to be used (and cannot be used) by any taxpayer for the purpose of avoiding penalties that may be imposed under the U.S. Internal Revenue Code.
demeo.vcf
 Filename:  demeo.vcf
 Filesize:  264 Bytes
 Downloaded:  153 Time(s)
VideoFlyer(at)aol.com
PostPosted: Sun Dec 17, 2006 8:12 pm    Post subject: Landing Lights Part II Reply with quote
I think Lycra is another name for Spandex...a stretchy fabric. Do you mean Lexan? Lexan is a better choice (more pliable) than Plexiglass.
Dave
bryanmmartin
PostPosted: Sun Dec 17, 2006 11:24 pm    Post subject: Landing Lights Part II Reply with quote
I built one of my landing light lenses out of acrylic and one out of Lexan. It took two attempts to make the acrylic one, the first one shattered when I tried to drill the holes for the mounting screws. On the second attempt I heated the tail end of a drill bit in a propane torch and melted my mounting holes in it. It was much easier to make the lens out of Lexan, the stuff cuts and drills abut like wood with no tendency to shatter. Lexan is not as scratch resistant as acrylic and I understand it wont tolerate exposure to gasoline and other petroleum solvents but those are not of great concern for a landing light lens mounted in the wing tip. I would highly recommend Lexan for this application.
On Dec 17, 2006, at 10:26 PM, Brad DeMeo wrote:
Thanks for all the info in the first thread.  This weekend while working in an ice cold hanger I tried to bend the landing light lens into the wing for fitting and final assembly. SNAP!  It broke.  So, I am wondering what other material anyone has used in this application for a landing light lens.  The lens I broke was from LP Aero and appears to be acrylic (the sticker on the lens did not indicate material type and neither do the plans).  Any ideas what would be appropriate on the leading edge under all flight and weather conditions?  Other builders have told me their lenses are cracked and discolored in less than one year's use.   Would lycra or some other more pliable substitute be appropriate?
Brad
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
goodings(at)yorku.ca
PostPosted: Mon Dec 18, 2006 7:26 am    Post subject: Landing Lights Part II Reply with quote
For the curved lenses in wingtips, as others have said, Lexan seems to be
the way to go. We used it successfully, with a thickness of 1/32 inch.
Lexan is one trade name for polycarbonate. One drawback of Lexan is that
it clouds/discolours with almost any solvent. Acrylic (aka lucite,
perspex) plastic is more solvent-resistent. If you preheat it (somewhat
above the boiling point of water - the judicious use of a heat gun can be
satisfactory for relatively small pieces), it will bend and take a
permanent set into a curved shape. However, you don't need heat with
Lexan. One good tip: both Lexan and acrylic can be polished and
protected very nicely with Nu Finish car wax in an orange plastic bottle,
sold in Canada in Canadian Tire stores for about $9. It is much cheaper
(and much better, in my opinion) than Mirror Glaze and other aviation
waxes which I tried before someone put me onto Nu Finish. It does not
discolour or cloud Lexan or acrylic, even after several years of use.
John Goodings, C-FGPJ, CH601HD with R912S, Toronto/Ottawa/Waterloo.
naumuk(at)alltel.net
PostPosted: Mon Dec 18, 2006 3:14 pm    Post subject: Landing Lights Part II Reply with quote
Bill Naumuk
HDS Fuselage
Townville, Pa
PostPosted: Mon Dec 18, 2006 3:18 pm    Post subject: Landing Lights Part II Reply with quote
Brad-
Contact Jeff Small. He used standard plexiglass but heated the blank to
shape in his (Cooking) oven. Definitely thought out of the box.
Bill Naumuk
HDS Fuselage
Townville, Pa
Afterfxllc(at)aol.com
PostPosted: Mon Dec 18, 2006 3:59 pm    Post subject: Landing Lights Part II Reply with quote
I made my lenses out of plexi. I put them in the oven and tested a piece to see what temp worked best. When you find the proper temp you have to place the plxi on something smooth because it will be soft and will pick up any impression it is laying on. The best way to shape it is to make a piece of 0.25 the same as the leading edge then use it to form the plexi around. the plexi will almost be like taffy and won't be hard to form. You will need to make it oversized because the gloves you are wearing WILL leave an impression in the plexi. Let it cool and you are done. Don't try and cool it with water just let it cool slowly and you will have a nice lens. The ones I made were for the Vans RV-7 and they are still looking good to this day.
Hope this helps
btucke73(at)yahoo.com
PostPosted: Mon Dec 18, 2006 8:05 pm    Post subject: Landing Lights Part II Reply with quote
I used Lexan. There is no reason I can think of to
use plexiglass for this application. Lexan will not
break. In fact, I screwed directly into the Lexan to
install. I heated it in the oven to bend, and used a
heat gun for a little extra.
R/
Brandon
N601XT HDS 40 hours
