n395v
Posted: Mon Jan 30, 2006 11:07 am Post subject: Radial engines in general |
I know nothing about radials, absolutely nothing.
What are their advantages/disadvantages.
Where is the cam, do they have a corrosion problem?
Why an odd number of cylinders?
Is the hydraulic lock issue as big as some make it seem?
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
_________________ Milt |
moose174(at)gmail.com Guest
Posted: Mon Jan 30, 2006 4:04 pm Post subject: Radial engines in general |
Hi Milt.
Being such a new list it may take awhile for the guys with more radial experience to find it and chime in.
This link gives a fairly decent overview of the radial - http://en.wikipedia.org/wiki/Radial_engine
Odd number of cylinders for the every other firing order.
On the M14 the cam is a steel disk with two rows of lobes on the outer perimeter, front row is for intake and rear row is for exhaust. The disk is in front of the cylinders (you can see the push rods on the front of engine) it is geared to the crank and turns opposite direction. Picture of cylinder assembly here http://www.goflyamoose.com/Main%20Pages/m14p.html bottom link on page - M14 cylinder drawing.
Hydraulic lock is an issue but if proper procedures are followed it won't be a "problem". A lot of the M14's are installing lower cylinder manifold drains or "clean kits" to help reduce the pooling of oil in the bottom 3 (typically) cylinders.
Hope that helps a little.
Scott
Murphy Moose M14P
On 1/30/06, N395V <N395V(at)direcway.com (N395V(at)direcway.com)> wrote: | Quote: | --> M14PEngines-List message posted by: "N395V" <N395V(at)direcway.com (N395V(at)direcway.com)>
Milt
N395V
F1 Rocket
ScottA
Joined: 05 Jan 2006 Posts: 100 Location: Park City, UT
Posted: Mon Jan 30, 2006 7:21 pm Post subject: Re: Radial engines in general |
Not sure why it is putting all those ? marks between when I post using gmail.
n395v
