Cabin Heater Questions
Nick(at)Scholtes1.com
PostPosted: Fri Dec 08, 2006 10:03 am    Post subject: Cabin Heater Questions Reply with quote
KitFoxers,
I have a couple of questions about cabin heaters for a KitFox. I'm in
the process of purchasing a KitFox, which is located in Florida, and
flying it home here to the arctic (Chicago -- brrrrrrrrr!!!). The
KitFox in question is a Model IV Speedster with a 912UL, and it has no
heater.
But it was originally equipped with a carb heater. The owner decided
that carb heat wasn't required anymore, and removed the air hoses and
simply put air cleaners on the carb. But, the heat "muff" and the carb
heat box are still there.
One question is, if I duct the heat out of the carb heat box to holes
that I drill in the firewall, will that be enough heat to be
"comfortable" in a Chicago winter?
My other question revolves around installing a water heater. It seems
to me that there are two ways to plumb in the water heater. One is to
plumb it "in series" with the radiator, the other is to plumb it "in
parallel". If it is plumbed "in series" and before the radiator, water
that is at it's hottest gets to the heater core. But, there is no way
to put a valve in-line to "throttle" the water flow. If the heater core
is placed "in parallel" with the radiator, then it can be throttled, but
it seems as though not much hot water would get to it, with the water
choosing to flow through the less-restrictive radiator instead.
Anyway, any advice on how to plumb in a heater core?
Thanks!
Nick Scholtes
kitfoxmike
PostPosted: Fri Dec 08, 2006 11:20 am    Post subject: Re: Cabin Heater Questions Reply with quote
I put a heater system on my 912ul kitfox4. The way I did it was to take a funnel and put it behind the radiator and then put a hose on the back of that and run it into the cabin. Works good down to 30 degrees. When it gets that cold you also need to restrict the radiator, currently I'm using duct tape, but I want to change to something better, still thinking on that one.
With this in mind, I want to pull off the radiator where the hottest spot is, currently I'm pulling off the center, I want to move the funnel to the side that has the hottest water, meaning the inlet of the radiator. Does anybody know the direction of flow of the radiator. Does it come in on the copilot side or the pilot side???
What's great about using this is there is no drain on the electrical system and no weight gain.
My next project is to remove all the cowlings and put a plastic wrap around everying for the cockpit to keep out air leaks, will find out possibly tonight on that one.
kirkhull(at)kc.rr.com
PostPosted: Fri Dec 08, 2006 12:14 pm    Post subject: Cabin Heater Questions Reply with quote
I installed a heater core with an electric fan works great to well below
zero if the cabin is sealed up well.
Float Flyr
PostPosted: Fri Dec 08, 2006 12:16 pm    Post subject: Cabin Heater Questions Reply with quote
For the radiator heater Plumb it in parallel with the radiator then all you
have to do is to put a throttling valve in series with the radiator to force
hot water through the heater core. You may also want to put a throttling
valve in series with the heater core to eliminate heat during those hot
Illinois summer days. Just make sure only one throttle is closed at a time
and you never completely close the valve on the radiator.
I was in Rockford over 40 yr. ago For the first annual EAA fly in.... I
remember getting off the plane at O'Hare and having the heat hit me like a
brick wall!
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
kitfoxmike
PostPosted: Fri Dec 08, 2006 12:31 pm    Post subject: Re: Cabin Heater Questions Reply with quote
mine would work great if everything is sealed up. The thing is, I thought of the hot water heater inside, but I didn't like the idea of all the junk that is involved. Plus, my electrical is tapped out. I fly with a stereo, transponder, and my favorite: wellon strobes, the best they have. those suckers are so bright they can be seen from far away. Usually I can be seen before I ever see the other plane.
When I put my hand on the hose (from the hose coming off the radiator) it is always a good temp, just get so much leaks from the cowl and such, hopefully my wrap will work out.
Another plus from this is you can install it in about 15 minutes with, oil funnel, wire ties, and about 2 feet of 1 1/2 hose. instant low cost heat.
lcfitt(at)sbcglobal.net
PostPosted: Fri Dec 08, 2006 2:56 pm    Post subject: Cabin Heater Questions Reply with quote
Nick,
One thought regarding using the heat muff. The traditional heater sold by
Skystar recirculated the air through the heater core. Mine is similar to
what you are describing and it uses ram outside air across the core for
heat. If it is 30° outside it may warm the air to 90°. If it is 20° it may
warm it to 80°, etc. It will take the chill off my feet, but I still wear
warm clothing. Another guy with the SS heater flys in his shirtsleeves.
Lowell
smokey_bear_40220(at)yaho
PostPosted: Fri Dec 08, 2006 10:16 pm    Post subject: Cabin Heater Questions Reply with quote
I like your idea better Lowell. If we come to a
survival situation, it will be with what we have on
and possibly with injuries. Wear what you wear
outside and you will be better prepared.
Kurt S. S-5
--- Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
Nick,
wear warm clothing. Another guy with the SS heater
Lowell
Float Flyr
PostPosted: Sat Dec 09, 2006 5:33 am    Post subject: Cabin Heater Questions Reply with quote
The best thing to have is survival training. Warm clothing in cold climes
is step one.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sat Dec 09, 2006 7:50 am    Post subject: Cabin Heater Questions Reply with quote
Kurt,
I had this conversation once with Burt Garrison. He flew the last
operational mission of the SR-71, then went on to fly the U-2 before
retirement and a position with SouthWest. I borrowed his hangar at Lincoln
Harder near Beal AFB when I did my first flight there in 1998. He said he
flew over the Sierras one beautiful clear winter day in a friends Luscombe
and it wasn't until he got home that he thought of his mistake. Since then
when I fly over rough winter terrain, I take my little tent, sleeping bag,
parka. etc.
I got some good advice from Burt, by just listening to his story.
Lowell
occom
PostPosted: Sat Dec 09, 2006 8:09 am    Post subject: Cabin Heater Questions Reply with quote
A personal locator beacon with GPS is a good idea for fliers or hunters or
really just about anyone heading into the wilderness, They'll find you a lot
faster if they know where you are.
RRTRACK(at)aol.com
PostPosted: Sun Dec 10, 2006 6:18 am    Post subject: Cabin Heater Questions Reply with quote
I would just want to caution any one taking air from behind the radiator for cabin heat to make sure the exhaust is not part of the mix. I have wanted to try this myself but have to tape up most of the radiator in winter to keep the engine temps up.
Mark
Wisconsin
kitfoxmike
PostPosted: Sun Dec 10, 2006 9:33 am    Post subject: Re: Cabin Heater Questions Reply with quote
first off, you don't pull air off the strip stream of the exhaust. I have the 912 and the radiator is away from the exhaust. If you are worried about it, put in a co meter.
I put in my wrap yesterday and wow, what difference. No air in the cockpit at all, real nice.
PostPosted: Sun Dec 10, 2006 11:41 am    Post subject: Cabin Heater Questions Reply with quote
There is a start up company - HighWing LLC (Yes I am involved) that has a
radiator shutter kit for the Skystar supplied radiator for the 912 series
engines. It is an easy assembly and attached to the radiator with Nylon Tie
wraps. It requires a Button Lock dash control like the A-700 from ACS for
operation.
For other radiators, an exact dimensional drawing with location of the inlet
and outlet accurately depicted and we will make up jigs from that.
Attached - two photos. one installed in a Speedster radiator shroud and one
uninstalled.
If anyone is interested drop an off list note.
Lowell
 Filesize:  30.14 KB
 Viewed:  532 Time(s)
 Filesize:  38.56 KB
 Viewed:  553 Time(s)
dave
PostPosted: Sun Dec 10, 2006 5:45 pm    Post subject: Cabin Heater Questions Reply with quote
Hey Mike,
You put in a wrap ? what is that ? I assume a heat muff?
I pull heat from my radiator with no exhaust at all but I also havc an
extention on mine as you can see in those videos I posted. But my Heat
muff gives the most heat . I can fly at 0 F and keep cabin temp of over 50
F on cloudy days. Much warmer on sunny days. My record is over 2 hour x
country at - 25 C and never wore gloves entire trip till i landed on Lake
at flyin.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
kitfoxmike
PostPosted: Mon Dec 11, 2006 6:57 am    Post subject: Re: Cabin Heater Questions Reply with quote
No, much better. You can't have heat inside unless you can keep it in. You remove the cowls, get some plastic, I used the stuff you buy for your home windows, it comes in a roll and has a backing, thick stuff. Next you wrap between the windscreen and the firewall, I taped mine at the edges with clear duct tape and then use a razor blade and x'd the openings for the cam locks, sealed all the air leaks I was getting. Then you put the cowls back on, nobody can see the plastic, but you know it's there.
av8rps(at)tznet.com
PostPosted: Mon Dec 11, 2006 10:14 am    Post subject: Cabin Heater Questions Reply with quote
Nick,
In response to your earlier question about cabin heat, I installed a heater
core with a fan controlled by an automotive water shutoff valve in my 912ul
Model IV-1200. It works good as long as you keep your CHT's around 200
degrees, and keep the cabin well sealed. I don't have any photos convenient
but would be happy to take some if you'd like to see more of the
installation.
BUT if it were me, I'd utilize the carb heat muff before going through all
the bother with the heater core setup. It would be easier to do, less
expensive, lighter, and most likely provide even better heat than the heater
core setup. But I doubt using the carb heat system as it is (by letting the
hot air just rise up into a scat tube that would go to the cabin) would
provide very little heat. So here's what I think one needs to do to create a
very good heat system using just the existing carb heat muff;
I haven't done it yet on my airplane (I too have the removed carb heat setup
you do), but my plan is to use the old carb heat muff off the left front
exhaust header by attaching a scat tube to the top of it and then attaching
it near the gearbox inside the cowl so it gets a direct prop blast of
pressurized air. I'd then fabricate from a piece of aluminum or stainless a
four or five inch extension to the bottom of the muff, with a round outlet
on it to attach a piece of scat tubing that will then go to a controllable
firewall heater air valve. End result, a simple, light, inexpensive cabin
heat system that is controllable from the instrument panel. I'm confident
this setup will provide very good heat, as a Rans I fly has a similar setup
and it gets very warm. The exhaust temps coming right off that cylinder
head should be nice and toasty. Plus, with no welds anywhere in the area,
there is much less risk of exhaust fumes in the cabin. BTW, don't forget to
stuff the heat muff with some good stainless or brass scouring pads. They
retain heat and slow down the air movement, providing significantly more
heat than a system without any.
If after that I find that I need (or maybe just want) even more cabin heat,
I would then make a heat muff to fit around my muffler, and connect the carb
heat muff scat tube to that. Then run two short scat tubes to airboxes on
the firewall (so you now have two controllable heat vents. Your wife will
love it....) You will probably want to play with scouring pad use in this
system, as you shouldn't slow down the air so much that you cause excessive
exhaust pipe temps. (I'm going to guess you could just remove the pads from
the header pipe muff, but keeping them in the muffler muff. You will
essentially have preheated air entering the muffler, and being heated again
before entering the cabin). This double heat muff system should allow you
to fly in the coldest of conditions.
And then if all else fails, install that heater core system as well for a
"three heat system". But bear in mind, should your heater ever fail in a
full heat mode, you had better be ready to fly home naked Smile You will
have one hot cabin!
I've attached a quick drawing I did that should make this all more
understandable, hopefully.
Paul Seehafer
Central Wisconsin
 Filesize:  87.69 KB
 Viewed:  512 Time(s)
kitfoxmike
PostPosted: Mon Dec 11, 2006 10:43 am    Post subject: Re: Cabin Heater Questions Reply with quote
I thought the same idea, but instead of pulling air from the outside, plumb air from the inside and put a little fan from a computer into the hose to bring you air, that way it can get hot faster and better. just my thought on the inlet air.
johnmay
PostPosted: Tue Dec 12, 2006 6:14 pm    Post subject: Cabin Heater Questions Reply with quote
Nick,
I am developing a heating system that uses hand warmers which when opened and exposed to the air heat up to about 125 degrees F. I have calculated that it will take about 12 of these wrapped around and duct taped to a scat tube stuffed with pot scrubbers. It should last long enough for a 10 hour flight.
DO NOT ARCHIVE
John May
SW Michigan
