Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Mon Dec 04, 2006 3:35 pm Post subject: Fuel Tank Ends |
Scratch Builders,
I am making the end caps for the fuel tanks and wanted to ask others about forming the corners. Should I shrink the metal and have a corner all around? Or, just form the flanges and leave the corners out and fill with weld?
I made some parts with 5mm constant flange, but had to anneal the corners to get the 6061 T6 material to flow. The parts look OK just didn't know about fatigue in the corners.
What do you think?
Pictures attached at the forum
112.01 KB |
623 Time(s) |
121.55 KB |
610 Time(s) |
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Posted: Mon Dec 04, 2006 5:40 pm Post subject: Fuel Tank Ends |
Ron,
A nice shape to work with, but I'd reverse the ends placing the flanges
under the main skins as you've done so that the heat
you put into welding is better distributed between the cap flange and
the edge of the main skins. 6061-T6 is not the best material
for a tank as applies to a welded construct. 5052-H32 is ideal as it's
yield to work hardening is better for holding its shape.
You're corners will fill easily the way you've got them, but if
reversed, a little easier. You can put more material into the weld if
you've got 1/8-inch of drum hanging outside the main skin edge and the
edge won't burn away so readily as the edge weld of a typical flange-
weld would. Practice a lot before you ruin the first set of tanks by
making sample welds to proof your skills or that of the guy you entrust
to the job. I welded the tanks with clecos and then removed the clecos
one by one and welded them shut. If you want to make the job of welding
much easier, make the ends out of .040 if you haven't already as less
than that is difficult to control heat- distortion and get consistent welds.
Best of luck,
Larry McFarland - 601HDS at www.macsmachine.com
WClagg
Posted: Tue Dec 05, 2006 4:22 am Post subject: Fuel Tank Ends |
I agree with Ron. I tried to make tamks for my 701 just like the drawings....... three days later, half a sheet of aluminum, a bottle of argon and half a pound of rod later I threw it in the floor. Then I stomped it.
Made the next tank out of .032 and turned the flange on the tank ends in. Made it just like Ron said and in one evening I had a tank that didn't leak. I used 6061-T6 only because I didn't want to wait for the 5052.
Wayne Clagg
CH701, left wing done, starting on right.
_________________ Wayne Clagg |
Ron Lendon
Posted: Tue Dec 05, 2006 2:32 pm Post subject: Re: Fuel Tank Ends |
Larry and Wayne,
The print shows the edges coming together like the picture below and has a notation "BEAD WELD ALL FLANGE SEAMS". This should make it easier to fuse the materials while adding filler rod and it should also make a really strong joint. I'm not to sure about the methods you are speaking of so I will probally make it like the print. I am still open for suggestions.
632.97 KB |
598 Time(s) |
CH 601 XLB
N601LT - Flying
WClagg
Posted: Tue Dec 05, 2006 6:31 pm Post subject: Fuel Tank Ends |
Ron,
Give it a whirl and let us know how it comes out. I sure would like to know. I really hope you get it worked out. My problem was with the weld cracking. I would get one spot fixed and pressure test at about 1/2" water column and it would let go somewhere else. I tried annealing and everything I could think of. It just appeared to me that there wasn't enough meat or weld to take any stress at all. Be sure and let us know how it works out.
Wayne
Ron Lendon
Posted: Wed Dec 06, 2006 8:31 pm Post subject: Re: Fuel Tank Ends |
Wayne,
I will keep the list updated on my experiences. Going to have the welding done by a pro at work, will take pictures and document the process.
CH 601 XLB
N601LT - Flying
