Forward vision for tail wheel pilots
Goto page Previous  1, 2
dan(at)rvproject.com
PostPosted: Fri Dec 01, 2006 7:09 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
Don't forget to install auto-land while you're at it.
do NOT archive
Bob Perkinson
PostPosted: Fri Dec 01, 2006 7:23 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
I just installed one on my pick up. If I had spent the $98 a month ago it would have saved me more that that. The small blind spot behind the truck counseled a small car. The hole that I punched in the small cars front bumper with the trailer hitch, when I backed up cost me $765. The monitor is mounted eye level with the left rear view mirror and is part of my scan when I back up now. Having a camera looking into a blind spot no matter how small could save more than a few dollars. I see no problem with having someway of checking directly in front of the plane just before taxing. There might be a tie down rope laying there that you forgot about, sucking that into the prop might give you a bad day.
Bob Perkinson
Hendersonville, TN.
RV9 N658RP Reserved
If nothing changes
Nothing changes
I agree. I might be able to buy the argument for a camera, but not in an RV. I can't imagine another airplane that I couldn't see from inside my RV-7.
Phil
On Dec 1, 2006, at 7:57 PM, Paul Besing wrote:
Sorry, but I just can't see it...especially in an RV. The visibility is pretty darn good in any tailwheel RV. The blind spot is very small actually. Unlike alot of tailwheel airplanes, you can almsot see over the nose on a tailwheel RV.
Paul Besing
jsflyrv(at)verizon.net
PostPosted: Fri Dec 01, 2006 8:03 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
I am 6'3" and almost hit the canopy, and there is still a lot of blind
spot in front of a RV-6. Look no one is saying you have to have one I
just don't see a problem with it and I do not believe that adding it to
a scan would be a problem I don't have one and probably never well but
it could save someones bacon sometime.
Paul Besing
Terry Watson <terry(at)tcwatson.com> wrote:
Think of it as a “front-view” mirror. You glance at it when you want
to see if anything or anyone is in the blind spot. Just because the
technology behind it is sophisticated doesn’t mean it has to be
distracting. Don’t make it complicated. And yes, I was thinking
about people putting it in their tailwheel RV’s.
But since I am building a nose-wheel airplane I don’t have a horse
in this race. Hey, maybe I could use one to …. No, never mind!
Terry
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing
Sent: Friday, December 01, 2006 3:55 PM
To: rv-list(at)matronics.com
Subject: Re: Forward vision for tail wheel pilots
Jerry, you are absolutely right about the GPS thing...stuff like
that will suck you in, and I've seen it as a CFII with people trying
to get things tuned, set, etc while taxiing to the runway.
First of all, this being the RV-List, I was thinking he was
referring to putting it in an RV, not something like the aircraft
the ran into the RV at oshkosh.
Second, how many times have you heard of a large airplane taxiing
into another one like the accident this year? Yes, there are ground
incursions, but this one was extremely rare. Yes, this "gizmo"
might have prevented the accident, but in more ways than one could
cause another one if your attention wasn't divided properly. I'm in
the business of flying aircraft where I have two forms of vision.
FLIR in my right eye and unaided view in my left. I have to divide
my attention all the time between the views. I have hundreds of
hours doing it, and my device follows my head movement and is not a
fixed platform. I use it while taxiing as well as flying. Well,
let me tell you this, it is not easy.
Two problems here. One is parallax. The camera is mounted at a
different place than where you are sitting. What it sees is from a
different angle and perspective than you are looking. If you try to
empart that in a scan, your natural feel, even though you are only
taxiing, will be disrupted. Second is fixation. The untrainted
pilot with a "gizmo" like this will be distracted. Maybe he'll be
turning the aircraft between some hangars, and while looking at his
monitor, the perception of his turning won't be great enough (the
parallax thing) so he turns more. Looks outside and bang, he just
hit another airplane or hangar.
Nevertheless, you can't fix one accident by employing non realistic
items like this, that could cause more. Airplanes have been flying
for 100 years without them, and this kind of accident is so very
rare, that I wouldn't change a thing about airplanes to prevent
another one.
There are few fly ins each year. There are fewer airports that have
this kind of congestion and chaos going on without some strict
aircraft control procedures. It's unfortunate, and I'm sure that
the EAA will implement measures with their marshalls to prevent it.
But I'm sorry, TV cameras in airplanes are NOT the solution. Better
ground collision avoidance training (a hot topic with the FAA right
now anyway) and sharp pilots/ground crew/controllers are the best
way to prevent accidents like these.
No more stuff needed in the cockpit I say. I've already learned my
lesson about gadgets, I tell you. I always revert back to the
basics when things don't go as planned, and ignore the gadgets and
get back to being a pilot.
Paul Besing
Jerry Springer <jsflyrv(at)verizon.net> wrote:
Not true, you don't set there and stare at the "gizmo" it is
part of an
overall scan. I bet there is much more attention given inside the
cockpit tuning and adjusting radios and GPS's than would be
focused on a
camera/monitor. I would much rather the plane behind me was
staring at a
forward looking camera/monitor than at the GPS or a map etc. It
would
really be nice to have a split screen looking forward and back
at the
same time.
Jerry
Jeff Point wrote:
www.aeroelectric.com
www.kitlog.com
jhstarn(at)verizon.net
PostPosted: Fri Dec 01, 2006 8:59 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
That's what we "thought" too....until the motionless Cherokee. BUT then again our's is only an RV "derivative". I would think that the view out the left side of a -7 would be pretty close to the HRII but lacking looking out the right side during an "S" turn. KABONG Do Not Archive
aerobubba(at)earthlink.ne
PostPosted: Sat Dec 02, 2006 6:46 am    Post subject: Forward vision for tail wheel pilots Reply with quote
Wow-
Move over primer!
Let me just say that the fellow who flew the H-1 replica said the fwd vis
unit installed on that plane was a godsend. Unfortunately, it couldn't
keep the engine running-
glen matejcek
aerobubba(at)earthlink.net
december29(at)bellsouth.n
PostPosted: Sat Dec 02, 2006 8:20 am    Post subject: Forward vision for tail wheel pilots Reply with quote
Glen,
I LOVE IT!!! Move over primer, ha ha. I say weigh the benefits, think
about it, and use it if it makes sense. These are experimental right? (
that said, I'm built straight to plans). Since I'm the slowest -8 builder,
I feel qualified to comment. This list has SO much good stuff on it, I
really appreciate everyone's expertise. But over like the last two years it
has become a vent for some, to really lay others low. I don't know why that
is?
All I know is we all selected a great airframe. If a guy wants to fly it
on floats, or to Alaska, or over the in-laws to prove something, or at
night, or in the weather, or upside down, it's okay................jeesh.
I've spent my entire life in aviation. I love flying airplanes for
whatever reason, (I think I know mine). I don't know why others fly, but
if they get the same joy I get from hanging around the airport, flying in
the sun, talking about women and perfecting their craft then in the words of
"Stripes" (an epic film worthy of an Oscar, ha,ha), "Lighten up, Francis".
Flames are for afterburners. Thankfully, Van didn't listen to people who
said building his own airplane was stupid...........
My two cents,
#80002
cubflyr(at)comcast.net
PostPosted: Sat Dec 02, 2006 9:37 am    Post subject: Forward vision for tail wheel pilots Reply with quote
Blind spot? What blind spot. In taxiing an RV-4, one has either seen what is
ahead or is looking at it. You also have to taxi ahead of your aircraft the
same as flying ahead of your aircraft. If I am so far behind my aircraft as
I am TAXIING for crying out loud, then I had better taxi her right back to
the hangar. Am I doing my checklist when I am taxiing? Instrument scan?
Radio frequency check? Control check? No. I am taxiing the aircraft.
Everything else can wait. Yes, those airline-types do it on the run. Right.
Both pilots doing the checklists. Yours can wait. And I am always quite a
ways behind the aircraft in front of me, even and maybe especially at OSH.
You never know what they are going to suddenly be inclined to do. This is
not NASCAR; drafting has no advantage here. And a mirror for the ones
behind. And looking around.
Besides, my other ride is a J-3 Cub. You want to discuss blind spots. Just
sit in the back seat and drive it somewhere. Oh, well, you have to PAY
ATTENTION. Doing S-turns and looking ahead. Huh. Or I could put a video
monitor in the back seat of the Cub. Since they haven't been around very
long, I guess no one ever thought of that.
And a stall-warning device.
And a stick shaker.
And a BRS.
And a Ground Proximity Radar
And a..............
What's that thumping? Oh, it's Charles Lindbergh rolling in his grave.
Michael
RV-4 N232 Suzie Q
Guess I'll go put the airplane away. This Flying thing is just to dangerous
Terry Watson
PostPosted: Sat Dec 02, 2006 12:20 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
OK, I move that Michael be excused from any mandatory requirement that this
group adopts to require all tailwheel RV's to have video monitoring of
anything.
My tailwheel experience is so limited to be virtually non-existent. My very
first ride in an RV was in the back seat of Rob Huntsinger's RV-4 at
Arlington north of Seattle, probably close to ten years ago. We taxied to
the north end of the field to get fuel, then headed south on the taxiway to
take off. It was a busy spring day. Tow planes with gliders were launching
between the taxiway and the runway. People were walking across the taxiway
to the glider area. I was happily getting used to the back seat totally
oblivious to anything in front of us and Rob was S-turning our way along the
taxiway. Suddenly an S turn became a 90 degree turn with a shot of power and
we were off the taxiway into the grass. Looking over my left shoulder I saw
why. We were ducking out of the way of a big radial engine tail-wheeled Yak
going the opposite direction. I'm not sure he ever saw us. Yes, Rob saw him,
and yes, we didn't get chopped up, but it did help confirm my decision to
build a nose wheeled airplane.
C'mon guys, it was only a suggested source for something people were asking
about on this list maybe six months ago. I'm not saying everyone ought to
have one. I'm not even saying it's a good idea; I'm just saying that IF you
want one THEN this MIGHT be an inexpensive source.
And from what I remember reading about Charles Lindberg's opinion of his
total lack of forward visibility in his Sprit of St. Louis, my bet is that
he would have jumped at an option to see what was ahead of him. But then
maybe he wasn't macho enough to fly an RV.??
Terry
gmcjetpilot
PostPosted: Sat Dec 02, 2006 12:26 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
I understand where Paul is coming from, a camera
and monitor in the cockpit of a RV is gimmicky and not
needed. RV's have good fwd vis if you sit high and
pay attention.
I know its easy to take an emotional stand to justify
putting cameras in a RV from the accident, but lets
face it a TBM is a BIG PLANE and could have avoided
hitting the RV with proper technique (meaning leaving
a large gap so they could see the little plane.) WE
HAVE the pilot aility to fly and taxi safely with out a
camera. Camera adds weight and no doubt drag, not
thanks but its fun to think about but not practical or
needed. George RV-4/RV-7
Hopperdhh(at)aol.com
PostPosted: Sat Dec 02, 2006 1:25 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
Terry,
I found the post interesting because I have been looking for a small screen TV monitor for a special instrument project. If it will display a standard TV formatted video signal (NTSV?), then I would like to display various things like trim and flap positions and digital tach, and some other things I can't think of right now. I know how to use old Motorola microprocessor chips to do those things. Would love to feed video to my GPS 295 if anyone knows how. Would probably have to be hacked to get the source code. Garmin wouldn't like that!
Does someone on the list know of a small (2 or 3 inch) color monitor that could be used for above project?
Did the $100 combo have a color monitor?
Dan Hopper
RV-7A
Oh, do not archive .
In a message dated 12/2/2006 3:22:41 PM Eastern Standard Time, terry(at)tcwatson.com writes:
--> RV-List message posted by: "Terry Watson" <terry(at)tcwatson.com>
anything.
Terry Watson
PostPosted: Sat Dec 02, 2006 2:18 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
Yes, this monitor is color. I see the price varies from the $89.99 I saw at Costco to $98.83 at Walmart’s online store to $169 at some other on-line sources. Here is the VR3 model number: VRBCS300W
I noticed that the Costco part number had “cos” added to it, which could possibly mean that it is somehow different, although I don’t think so.
Here is the product description off of Walmart’s website:
Get the security you need to protect your family and friends. Eliminate the blinds spots and see what's behind you before you back up. Large 2.5" monitor is easy to view.
  • Wireless Back-Up Camera System with Color LCD Monitor allows you to see what is behind you before you back up
  • Comes complete with everything you need to install
  • Avoid accidents and injuries in your Car, Van, SUV, RV, or delivery vehicle
  • Camera mounts to your existing license plate holder and provides 110 degrees of horizontal camera viewing and 80 degrees vertical camera viewing (measured diagonally)
  • 2.5" color monitor mounts to your dash or visor
  • For use with 12V DC electrical systems
  • Installation is easy with the elimination of wires
  • Help is available by calling the number provided
  • Easy to read, bilingual (English/Spanish) installation
I think I have convinced myself to buy one for my pickup. Gee, it even says it’s made for RV’s!
Terry
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Hopperdhh(at)aol.com
Sent: Saturday, December 02, 2006 1:24 PM
Terry,
Dan Hopper
RV-7A
anything. www.aeroelectric.com
 Filesize:  73 Bytes
 Viewed:  3673 Time(s)
rv8ch
PostPosted: Sat Dec 02, 2006 11:00 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
Terry, Please let us know how it works. It sounds like an excellent
safety enhancer.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
neilmcleod(at)wildblue.ne
PostPosted: Sun Dec 03, 2006 4:48 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
Here’s a set up that looks pretty good and has some good reviews from motorcycle road racers (of which I am one) for rear view use. Unfortunately it’s about 600 bucks for the camera and monitor. www.themotocam.com
Sent: Saturday, December 02, 2006 2:24 PM
Terry,
Dan Hopper
RV-7A
Terry Watson
PostPosted: Sun Dec 03, 2006 10:47 pm    Post subject: Forward vision for tail wheel pilots Reply with quote
Mickey, Dan, anyone else who is interested:
I did buy and install the little video camera & screen from Costco for
$90.00. I put it on my pickup as a back-up assist. The quality seems just
fine, and installation was especially easy, except for the crimp-on wire
taps that cut my truck's wiring and I had to take the gizmos off and solder
things back together.
The camera is in a plastic bracket that doubles as the top or bottom half of
a license plate frame. The wire comes out of that and hooks into the back-up
light circuit for the vehicle, so the camera is only powered when the
back-up lights are, or typically when the vehicle is in reverse. The wire is
also the broadcast antenna for the camera so it has a tag on it telling you
not to cut it off shorter than the location of the tag.
The receiver has a cigarette lighter plug or a hard wired cord; both are in
the box. There is a swivel holder for the screen and Velcro self-stick pads
to fasten either the swivel holder or the screen by itself to the vehicle.
It works on the same frequency as some cordless phones. I think I picked up
a stores security camera picture on the screen at one intersection I went
through tonight. I doubt that this would be a problem for anyone. I just
hadn't turned off the screen to see if it would pick up anything. It did.
I measured the little molded plastic box that the screen is mounted in but
forgot to write the dimensions down. If anyone needs it, I can go measure it
again and write it down this time. I think it was 3+" wide by 2+" tall by
7/8" thick; very light weight. The specs say the screen is 1-1/2". A bigger
screen in a smaller box would be better, of course, but this isn't bad, and
it's a clean design. You won't want to mount it too far away from your eyes.
The one concern I would have for it as the forward vision for a tail wheel
aircraft is that the camera lens is quite wide angle. This is great for a
back-up assist, but it might be too wide-angle for that blind spot some of
us are worried about. It would be very hard to judge distance by looking at
the screen, but I doubt if you would want to use it for that much precision
anyway.
The screen is in color and the image is quite clear but distorted as through
a fish-eye lens. Interference from other electronics MIGHT be a problem; I
don't know. As for it causing problems with your avionics, just turning off
the camera and receiver would be easy and should solve that. The whole
system must weigh much less than a pound; it's quite light but I didn't
weigh it.
One very helpful feature of the receiver is that you have four possibilities
for the picture; right side up mirror image; right side up straight image;
upside down mirror image, or upside down not mirrored. You sequence through
the four settings with the only control button besides the power button.
This means that you could either install it as a back-up assist as I did and
set it so it reads like you were looking in a mirror, or as a forward view
enhancer without having to mentally interpolate what you are seeing.
I'm sure some will find lots of uses for this gadget or variations of the
concept. If this one serves your purpose, it is a well thought out and
manufactured system for an attractive price.
For the record: Manufacturer is VR3, model number is VRBCS300W. Costco has
it for $90; Wal-Mart for about $100. On line it's advertised for up to $170.
Terry
says it's made for RV's!
safety enhancer.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
aerokinetic(at)sbcglobal.
PostPosted: Mon Dec 04, 2006 6:01 am    Post subject: Forward vision for tail wheel pilots Reply with quote
I don't believe I need anything on my -4 except my eyeballs and some shallow S-turns... but watch closely to see how they handled this problem in WWII on big taildraggers like the P-47 when taxiing in tight quarters (it's a cool video -you won't be sorry you viewed it).
http://video.google.com/videoplay?docid=4368250464023128830&amp;pr=goog-sl
I personally think similar procedures should be used at OSH and other fly-ins with warbirds and other large taildraggers.
Scott
N4ZW
Vince Frazier
PostPosted: Mon Dec 04, 2006 6:38 am    Post subject: Forward vision for tail wheel pilots Reply with quote
Subject: RE: Re: Forward vision for tail wheel pilots
I used a Sony Super HAD CCD color bullet camera (VC-805) from Circuit
Specialists. It works perfectly. It's not a wide angle camera like the
backup cameras. It's been installed for well over a year and hasn't
missed a beat.
A little more info for those who want it: scroll down to the FLIR
section.
http://www.vincesrocket.com/Additions%20after%2010-27-04.htm
It's not for everyone, but I like it and use it whenever I'm at an
unfamiliar or busy airport. Or just to keep up with my nosedragging RV
buddies on the taxiway.
YMMV
Vince
Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/
jeffpoint
PostPosted: Mon Dec 04, 2006 11:19 am    Post subject: Forward vision for tail wheel pilots Reply with quote
Great idea. Are you volunteering for this duty? Wink
Jeff Point
RV-6 flying
RV-8 tail
Jeff Point
RV-6
Milwaukee WI
Page 2 of 2
