llltoome(at)gvtel.com Guest
Posted: Fri Dec 01, 2006 2:39 pm Post subject: Subaru EA-81 |
I am curious to what size radiators are being used (Square inches) with success for proper cooling on a Subaru EA-81 engine with carburetors. Also is an oil cooler necessary?
Dick
avtar412
Posted: Sat Dec 02, 2006 12:03 am Post subject: Re: Subaru EA-81 |
I have a water to oil cooler and 2 tubes through the sump with good airflow and have no trouble with cooling. Turbo as well. Radiator, I started with NSI brass unit but had to go to a purpose built aluminum unit and cools well now. 750mm x 250 x 80 deep.
propellerdesign(at)tele2. Guest
Posted: Sun Dec 03, 2006 1:33 am Post subject: Subaru EA-81 |
Here is a lot interesting information about cooling,
http://www.rotaryeng.net/how-to-cool12.html
Also attached is an excel file for cooling estimate.
Jan Carlsson
www.jcpropellerdesign.com
 Download |
| Filename: |
Coolingestimate.xls |
61.5 KB |
| Downloaded: |
513 Time(s) |
n10pg(at)neo.rr.com Guest
Posted: Sun Dec 03, 2006 11:18 am Post subject: Subaru EA-81 |
Hello Dick:
I use the aluminum radiator furnished by NSI which is 24 x 6 x 2 inch. I
installed a 180 deg thermostat. I confirmed with extensive instrumented
tests NSI's statement that the oil temperature is essentially always the
same as or within a few degrees of the coolant temperature. Therefore an oil
cooler is not required.
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
Dick
