Float Flyr
Posted: Mon Nov 27, 2006 7:19 am Post subject: Conventional Vs Tail and other training |
The tricycle gear handles differently no doubt.... But directionally more
stable. I think directional stability will be the result of a number of
factors. E.g. the speed of taxi, the number of wheels on the ground, the
direction and speed of the wind, the condition and length of the runway and
lets not forget the experience of the pilot.
What I find interesting is the fact that in this country we don't have a
tail wheel endorsement and it seems we also don't have the perceived
problems of flying with one. I am in favour of additional training where it
is needed and additional training on the tail wheel is probably a good idea.
For pilots who have only flown with the conventional gear some training in
the tricycle config. Would also be a good idea. There are manoeuvres used
on tricycle gear that do not even exist on conventional aircraft. E.g. soft
field taxiing. I'm willing to bet there are people who are reading this
list who have had at least one accident involving a tricycle/conventional
gear plane on a runway.
In this country, now, you don't have to do any spirals, the recover from
which can seriously twist your plane, if done incorrectly. You also don't
have to do any spins the recovery from which is mandatory to a good day. I
don't know if this is true south of the 49th but up this way it appears that
TC ( Transport Canada ), the governing body wants people to have their
crashes away from the airports. I think that spiral and spin training would
be at least as important as training on conventional gear.
The above in reference to the safe operation of Kitfox aircraft.
Fly fish, Fly floats, Fly Safe!
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
MichaelGibbs(at)cox.net Guest
Posted: Tue Nov 28, 2006 9:02 am Post subject: Conventional Vs Tail and other training |
Noel sez:
| Quote: | I think directional stability will be the result of a number of
the direction and speed of the wind, the condition and length of the
runway and lets not forget the experience of the pilot.
You are describing the factors that affect controllability, not
stability. According to the Webster's dictionary, stability is,
"...the property of a body that causes it, when disturbed from a
condition of equilibrium or steady motion, to develop forces or
moments that restore the original condition..."
Just as you want the airplane's center of pressure (or surface area)
behind the center of mass to make it stable in pitch and yaw during
flight, you need the non-turning wheels behind the center of mass to
make it stable on the ground. Directional stability has only to do
with the relationship between the main (or non-turning) gear and the
center of mass. Main gear behind the center of mass = stable, main
gear in front of the center of mass = unstable.
If the wind displaces the tail end of a tail dragger to one side, it
takes positive action on the part of the pilot to bring it back
straight--the airplane wants to continue on around rather than
straighten out. A nose wheeled airplane that is displaced in the
same way tends to straighten out (not necessarily staying on the
runway, mind you).
I wasn't saying that a tail wheel airplane is uncontrollable
(obviously!), just that they are not directionally stable. This
instability means that the pilot must actively control the direction
of the airplane at all times, i.e., you have to fly it all the way to
the hangar, as it were.
Mike G.
N728KF
Fox5flyer Guest
Posted: Tue Nov 28, 2006 11:53 am Post subject: Conventional Vs Tail and other training |
Good explanation Mike. That's about as clear and simple as one could make
it.
Deke
Michael said...
runway, mind you).
Mike G.
N728KF
Float Flyr
Posted: Tue Nov 28, 2006 12:07 pm Post subject: Conventional Vs Tail and other training |
I agree with your definition of stability. At low speed with little or no
cross wind I think the conventional gear will be more stable simply because
the thrust coming from in front of the centre of mass works to stabilize the
plane and the increase in the distance between the mains and the steering
wheel (wheel base) being longer the conventional gear should be more stable.
At somewhat higher speed when a tricycle gear plane may have its nose wheel
off the ground, as in soft field operation and a conventional gear plane may
have its tail up then both planes will display very similar stabilities.
Only when the conventional gear is slowing down, as in landing, and the tail
is still off the ground is the operational stability marginally lower than
the a comparable tricycle plane. What are we talking about here two or
three seconds of a flight?
Yes there are places where a tricycle plane is more stable than a
conventional. Slow taxi in a strong cross wind is one. But the tail dragger
is more stable taxiing down wind than the tricycle.
Visibility is a bit better in the tricycle Kitfox than the conventional gear
Kitfox. But if you bring your tricycle gear 'Fox that close to the back of
my plane you are too darn close! Let's face it we don't have the visual
problems that the old war birds like the avenger had. The problem that Air
Venture had last summer wouldn't have happened if the plane in the back had
been a bit smaller. That problem was only partially caused by the tail
dragger... Pilot distraction is probably more to blame.
What I really disagree with is the picture painted of every conventional
gear plane being some sort of dragon that must be slain or at least tamed.
At the same time tricycle gear planes are painted to be almost auto-landing
super safe (that in itself may make them more dangerous and lead to ground
accidents). By the way, "auto-landing", I think you will find, is what
Cessna called their first tricycle gear planes.
Either way these are great planes.
Noel
[quote] --
Kitfox III-A
Posted: Wed Nov 29, 2006 7:33 pm Post subject: Conventional Vs Tail and other training |
Noel sez:
| Quote: | I agree with your definition of stability. At low speed with little
or no cross wind...thrust coming from in front of the centre of
mass...At somewhat higher speed when a tricycle gear plane may have
its nose wheel off the ground...and a conventional gear plane may
stabilities.
You say you agree with the definition of stability and yet you didn't
get it at all. Lifting the nose or tail wheel has nothing to do with
stability but it does have something to do with controlability.
Stability has only to do with the relationship between the pivot
point--the main landing gear in this case--and the center of mass.
It has nothing to do with engine power or air over the tail or
speed--these all affect controlability, not stability.
There are plenty of controlable vehicles that are unstable.
Bicycles, for example are very unstable yet most of us find them easy
to control. Without active input from a pilot, though, the bike
falls right over. That said, we all know it takes some practice and
a few spills to master the balance required to ride one.
| Quote: | What I really disagree with is the picture painted of every
conventional gear plane being some sort of dragon...[and] tricycle
gear planes are painted to be almost auto-landing super safe...
I hope you aren't saying that I made either of those claims.
Mike G.
N728KF
Float Flyr
Posted: Thu Nov 30, 2006 6:50 am Post subject: Conventional Vs Tail and other training |
Let me get this straight ... A vehicle with a high centre of gravity on a
short wheel base is more stable than the same machine configured with a
longer wheel base and a lower centre of gravity.
Ok I got it ....Not!
| Quote: | Stability has only to do with the relationship between the pivot
point--the main landing gear in this case--and the centre of mass.
I think you are over simplifying things. I will agree that the tricycle
plane will have more longitudal stability than its conventional counterpart
but only for the few seconds after touch down. After that it depends on
many other factors.
The conventional aircraft is only less stable for a few seconds of every
flight and yes that is more than enough time to have an accident. The
tricycle gear also has seconds of instability especially taxiing downwind
with the wind to either aft quarter and that is either a high speed or low
speed taxi.
As for the bicycle if you spin the wheels fast enough it will stay up on
it's own.
And slaying the dragon I was referring to the consensus which seems to be
displayed by tricycle operators. Not necessarily every tricycle operator
and not any particular operator.
I notice no one has said anything about the numbers of ground accidents
involving tricycle vs. conventional gear planes. From that there are only
two deductions ... They all have accidents or there are no accidents.
Either way it would indicate neither configuration is more stable.
Me......
I fly floats.
Noel
[quote] --
Kitfox III-A
dave
Posted: Thu Nov 30, 2006 7:01 am Post subject: Conventional Vs Tail and other training |
I would assume that most ground handling accidents are 99.9 % pilot error
no matter what the gear config is .
Some can fly taildraggers and some cannot not it seems.
All personal preferance from my viewpoint but that being said I am sure that
there is a far greater amount of taildragger Kitfoxes produced and a small
percentage that cannot physically or have the desire to fly them so they
opt for a tri- gear.
Taildragger Kitfox is a very tame aircraft to fly, it is the pilot that is
not competant that does not like them.
Can we end this topic now ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
GENTRYLL(at)aol.com Guest
Posted: Thu Nov 30, 2006 7:08 am Post subject: Conventional Vs Tail and other training |
This question is kind of an offshoot of the current topic. I would like to ask those of you that have a lot of Kitfox or other light taildragger time, if a noticeable difference in horsepower of say a 65 hp. 582 and a 100 hp Subaru cause's a noticeable difference in rudder control due to the difference in torque.
lcfitt(at)sbcglobal.net Guest
Posted: Thu Nov 30, 2006 7:21 am Post subject: Conventional Vs Tail and other training |
Mike,
A bit ago you intruduced the center of pressure into the stability equation.
I am totally confused now. Isn't the center of pressure a factor when
moving on the ground as well as in the air?
Lowell
Float Flyr
Posted: Thu Nov 30, 2006 7:45 am Post subject: Conventional Vs Tail and other training |
My sentiments exactly.... Especially the last one.
Noel
[quote] --
Kitfox III-A
Posted: Thu Nov 30, 2006 9:58 am Post subject: Conventional Vs Tail and other training |
I got my TW endorsement in a KF-4 with a 100 hp NSI
Soob. It was amazing to me how this plane wanted to
make a 15 degree right turn as I raised the tail on
takeoff and then a left turn as I rotated for lift
off. Very pronounced tendency. It was much easier to
land than takeoff.
I was really worried when I first flew my S-5 with the
140 hp NSI in it. I expected an even worse turn to
correct for as I changed the plain of rotation of the
big gyroscope out front. Instead it had almost no
turning tendancy at all. Well, maybe 1/3 of the
tendancy of the S-4.
I think there are more factors than hp at play here,
like prop size and weight, rpm, and aircraft geometry.
My friends tell me that the newer Maules are the worst
plane on the ground that they fly. The big tails and
relatively smaller rudders make them want to turn into
the wind more and give you less power to stop that.
This is where stability works against you and more
controlability would be helpful.
The whole discussion of controlability and stability
is about twice as complex as so far covered. You have
ground stability and aerodynamic stability. You have
ground controlability and aerodynamic controlability.
Then brakes, wheel alignment, adverse yaw and other
factors to consider.
Pilotage: If you normally react to a ground loop by
moving the stick to hold the outside wing up, in a KF
your adverse yaw will help you control the plane. If
you normally move the stick with the rudder to keep
the plane from turning, you will make it ground loop
worse. You may not even know which you do, since most
people concentrate on what they are doing with the
rudder on the ground.
There is so much more to this that it is very
extensive to get into. But I think the origional
topic is more of, which do you like and what can I
handle? Stick shift or automatic?
I agree with the idea of trying both enough to be
profficient, then choosing the one you like. The rest
is pride.
Kurt S. S-5 KitFox (N-210F "Heavy")
--- GENTRYLL(at)aol.com wrote:
| Quote: | This question is kind of an offshoot of the current
dave
Posted: Thu Nov 30, 2006 10:14 am Post subject: Conventional Vs Tail and other training |
kurt
would you contribute that to asseymetrical thrust and P factor ?
Dave
Posted: Thu Nov 30, 2006 11:41 am Post subject: Conventional Vs Tail and other training |
Hi Dave,
Actually neither of those were primary in that KF-IV
case. The NSI prop turns CCW, so it takes left rudder
to fight P factor and it would turn right as you power
up. The rotating wind behind the prop would push the
tail left - nose right. Yes, that happens, but not
changing at tail lift or rotation.
Torque in the CCW rotation case makes the plane turn
right too. Once your rpms are up, I think you've
adjusted for it and the other forces make primary
changes.
Asseymetrical thrust does change at rotation, but in
the NSI case, it turns left as the tail comes up
because the downward moving blade loses thrust on the
left side and the upward moving blade increases thrust
on the right side.
The big factor for that plane was gyroscopic - a big
right turn as you lift the tail and a left turn at
liftoff. And from the inside the prop really looked
big too.
You've got all 4 forces at work and some against the
other. And they change as you accellerate and rotate.
The plane goes with the winner of the moment.
I suppose in the big war birds, torque at powerup, P
factor as you rolled, followed by gyroscopic and
assymetrical thrust at tail lift and rotation keep
them dancing on the pedals.
When I did my spins during testing, I found the
spinner back contacted the cowl due to the gyroscope
forces, even at idle rpm, during those spins. It is
the only time my cowl took a hit in all my maneuvers.
Kurt S.
--- dave <dave(at)cfisher.com> wrote:
| Quote: | kurt
and P factor ?
Dave
Cheap talk?
Posted: Fri Dec 01, 2006 8:40 am Post subject: Conventional Vs Tail and other training |
Noel sez:
| Quote: | Let me get this straight...A vehicle with a high centre of gravity
on a short wheel base is more stable than the same machine
configured with a longer wheel base and a lower centre of gravity.
We are talking about directional stability here, Noel, not lateral.
How high the thing sits has nothing to do with directional stability.
Here's an experiment for you to conduct:
Go down to the local grocery store and grab a shopping cart that's in
reasonably good shape. Give it a push across the parking lot
(watching out for parked cars, of course) and see how it travels.
Now take the same cart and turn it around backward and give it a
shove. This time it will flip around forward on its own.
Now, fill the cart with a heavy load of groceries and do both test
runs again. You'll see that the cart still continues straight when
pushed forward and still flips around when pushed backward. The
higher load makes no difference.
Now go to your local Home Depot or Lowes or hardware store and get
one of those flat carts used for hauling bricks and lumber (NOT one
with wheels mounted in the MIDDLE, it must have FIXED wheels at one
end and SWIVEL wheels at the other end). Push one of these both
forward and back and you'll see it stay straight when the swivel
wheels are in the front and it will flip around when the swivel
wheels are in back. Now load this one up with a bunch of heavy
stuff--no change!
| Quote: | I will agree that the tricycle plane will have more longitudal
stability than its conventional counterpart but only for the few
As I've said repeatedly, you are talking about CONTROLABILITY. I am
talking about STABILITY. They are NOT the same thing.
| Quote: | The conventional aircraft is only less stable for a few seconds...
It is ALWAYS unstable by definition. I hope after conducting the
shopping cart experiment you'll understand that.
| Quote: | As for the bicycle if you spin the wheels fast enough it will stay
up on it's own.
It seems like you are trying very hard to NOT understand the
underlying concept of stability. Try another experiment: go out and
push the bicycle as fast as you or the kid down the block can
POSSIBLY push it and see if that is enough to keep it upright. My
point was that even though the bike (at reasonable speeds) wants to
fall over, the rider can easily CONTROL it even though it is UNSTABLE.
| Quote: | I notice no one has said anything about the numbers of ground
accidents involving tricycle vs. conventional gear planes.
I am quite certain that if I invested the considerable amount of time
required to show that, per capita, there are more
loss-of-control-on-the-ground accidents in tail draggers you would
dispute the source of the data, dispute what constitutes a loss of
control, and dispute the experience and qualifications of the pilots
involved and go on believing that since you are able to CONTROL a
tail dragger it must be stable.
Mike G.
N728KF
Posted: Fri Dec 01, 2006 8:41 am Post subject: Conventional Vs Tail and other training |
Lowell asks:
| Quote: | A bit ago you intruduced the center of pressure into the stability
equation. I am totally confused now. Isn't the center of pressure a
factor when moving on the ground as well as in the air?
It is a factor, Lowell, but when the airplane is on the ground it
cannot pivot around the center of pressure like it would in
flight--it will always pivot around the main gear (unless you are
skidding the wheels, of course).
So, in flight, the center of mass is forward of the pivot point
(center of pressure), giving the airplane positive yaw stability. On
the ground, a tail dragger's pivot point is now the main gear, which
is in forward of the center of mass, causing negative stability. A
tricycle gear airplane's pivot point is also the main gear, but they
are still behind the center of mass, therefore it has positive
stability.
Mike G.
N728KF
aldaniels(at)fmtcblue.com Guest
Posted: Mon Dec 04, 2006 10:04 pm Post subject: Conventional Vs Tail and other training |
Its nice to see familiar names on the list as I have been off for half a
year due to work. This thing about which end the little wheel should be
on comes up every year or so. We fly these things for fun so put it
where you want it. The only real reason to put it on the back is for
landing soft or rough, and I am not referring to sod or packed dirt. If
you need 8:50 or 26 inch tires to keep from digging in then you need the
little wheel on the back, but I have put my Vixen in most of the Idaho
back country strips with no concern. The advantage in that it handles
like a go cart on the ground and will take a lot of cross wind. The tail
wheel version is easy if you make sure that there is no toe in, that you
land slow enough, and maybe most importantly if you are landing on
pavement that your air pressure is down in the mains - 10 to 15 pounds,
and up towards the limit in the tailwheel. If anyone is interested and
in my area I have two model 5's in my hangar, with the little wheel on
different ends that I would be happy to take you flying in each so you
can see for yourself. However if you are here you are also just a few
minutes from the factory and John can show you also.
kitfoxmike
Posted: Tue Dec 05, 2006 11:30 am Post subject: Re: Conventional Vs Tail and other training |
geees,
I think this thread started with a fella wanting a nose wheel airplane, I'm sure because he just doesn't have the skills or want the skills associated with rudder control. Yes the tail plane is more unstable on the ground, you need rudder skills. I say lets give the original poster some ideas on the choice between the ch701 vs. kitfox nose wheel airplane not try to convince him that the tail wheel airplane is easy to fly and not a problem. How do any of us know how this persons skills are or want to be. I for one will never try to talk anybody into a tail plane. I have about 600 hrs in my fox, tail wheel, and although I feel it is the funnest most satisfying airplane to fly, I will not advice another person that the tail wheel is the only airplane to fly. Nor will I tell a nose wheel pilot that in short he is a sissy, and that nose wheel airplanes in short, hasn't been said, should be outlawed. Lets move on.
