george(at)falco.co.nz Guest
Posted: Sat Jan 28, 2006 6:35 pm Post subject: Starter |
Hi All..
I thought you may be interested in this one.
I have a Skytec NL inline starter on my Falco.. It has been a great unit but the other day a potentially dangerous situation occurred.
I was training a friend to fly my machine (Yeah yeah.. another story) when I got out all sounded fine and he duly taxied out for 2 circuits. On his return.. immediately he exited the runway there was the familiar noise of the ring gear taking a hiding. What transpired was as the picture suggests... the two screw that hold the end cap to the starter had vanished. The end cap and gear where then being spring forced on to the ring gear... not a good situation.. had the gear managed to engage the results would have been very nasty.
If you have one of these starters I would recommend changing the front screws for a lockable variety.
George Richards
www.falco.co.nz
| | - The Matronics Falco-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Falco-List |
117.46 KB |
824 Time(s) |
votorschair(at)earthlink. Guest
Posted: Sat Jan 28, 2006 7:09 pm Post subject: Starter |
Thanks for the information George. I was thinking of using a B&C starter and alternator when I get to that point. Did you consider those and did you decide against them for some reason I should know about.
Al Aitken
votorschair(at)earthlink.net (votorschair(at)earthlink.net)
Posted: Sat Jan 28, 2006 7:32 pm Post subject: Starter |
HI Al..
The only thing stopping me for the B&C was all the info I read on the Sequoia site with other guys having trouble making them fit. I don't know it they have an inline version or not now but they didn't when I was buying.
The Skytec is a fantastic little unit and spins the prop really well.. this is and will be an issue for them though. I got the very first one from Rich Chiappe at Skytec so maybe this has changed on later units. The companies support is second to none however so I'm sure that this will be remedied if it is likely to be an issue.
I will certainly be changing the screws to something I can lock wire in future however.
Hope you project is coming along nicely.
Cheers
GR
PS. for anyone who wondered what happened to my website.. I'm changing servers at present.. hopefully back again in a couple of days.
[quote] --
chaskuss(at)yahoo.com Guest
Posted: Sun Jan 29, 2006 8:30 am Post subject: Starter |
George & Listers,
A third option for starters is a converted Toyota
Pick Up truck starter. These are marketed by several
folks for the experimental market. I purchased mine
from a rebuilder who sells on EBay. See
http://cgi.ebay.com/ebaymotors/Airboat-Starter-forTextron-Lycoming-Engines-149tfw-NR_W0QQcmdZViewItemQQcategoryZ26439QQitemZ4580254772QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/Airboat-Starter-forTextron-Lycoming-Engines-122tfw_W0QQcmdZViewItemQQcategoryZ26442QQitemZ4522782279QQrdZ1QQsspagenameZWDVW
Lycomings manufactured before 1970 use the older 122
tooth ring gear starters. Although many of the older
engines have been updated. It's best to count the
number of teeth on your ring gear.
Charlie Kuss
--- George Richards <george(at)falco.co.nz> wrote:
[quote] HI Al..
info I read on the
I can lock wire in
future however.
Cheers
GR
couple of days.
Posted: Sun Jan 29, 2006 10:54 am Post subject: Starter |
Hi Charlie..
Unfortunately these side motor style starters don't fit in a Falco.. Things
are very tight in there.
Several builders have tried and reported problems... see the skunkworks,
there is quite a bit written on starters.
The only comfortable fit is the in-line style of starter.
I think these starters are how B & C and others started out life. At least
where they got their first brain wave from.
