jonathan(at)entry.co.za Guest
Posted: Tue Nov 21, 2006 10:09 pm Post subject: Sensitive Elevator |
Hi All wise ones.....
I now have over 50hrs on my 601XL, and am loving every minute., but have been
woundering if I could make it better?
The Elevator is very sensitive, in comparison to the Ailerons, I am sure
everyone will agree with me, now this in itself is not an issue, as I have
become used to the elevator, and in normal smooth flight it is not an issue at
all.
This last weekend I flew in quite severe turbulence, you know the head hitting
the canopy type of turbulence. This in itself is not an issue for the XL, as it
is very controllable in turbulence, except I feel that due to the overly
sensitive elevator, me as pilot in command tended to induce pitch oscillations.
The amount of movement on the stick (I have the dual stick option), for flare
and normal flight, is very little, thus would it not be a good idea to reduce
the snsitivity around neutral, by reducing the size of the front bellcrank. The
belcrank that the two cables attach to, in the centre console, the one the
centre single stick is attached to. This would result in the stick having to be
moved a greater distance, for the same elevator deflection. Hence reducing the
sesitivity around neutral.
The same could be achieved by increasing the horn length on the elevator itself,
but this seems like a lot more work. I think cutting down the horn size, or
making another, and fitting it for testing could be an easily achieved option.
Has anyone done this, and what do you guys think of the idea?
Thnx
Jonathan Starke
601XL Rotax 912S 50+ Hrs
Cape Town
South Africa.
daveaustin2(at)can.rogers Guest
Posted: Wed Nov 22, 2006 6:03 am Post subject: Sensitive Elevator |
Negative, John, negative.
Either of those changes would reduce the full travel of the elevators, which
you may well need in the future to save your life!
Dave Austin 601HDS - 912, Spitfire Mk VIII
carlossa52(at)gmail.com Guest
Posted: Wed Nov 22, 2006 6:08 am Post subject: Sensitive Elevator |
Jonathan, would it be possible to use the same bellcrank for that purpose?
Just add holes closer to the pivot point...
Just a thought
Carlos
CH601-HD, plans
Montreal, Canada
On 22/11/06, Jonathan Starke <jonathan(at)entry.co.za (jonathan(at)entry.co.za)> wrote:[quote] --> Zenith-List message posted by: "Jonathan Starke" <jonathan(at)entry.co.za (jonathan(at)entry.co.za)>
all.
sesitivity around neutral.[b]
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Thu Nov 23, 2006 7:35 am Post subject: Re: Sensitive Elevator |
Jonathan,
Occilations are an indication of the CG getting too far aft causing instability in the pitch axis? Had you checked the weight and ballance?
Dan
_________________ Scratch building XL with Corvair Engine |
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Thu Nov 23, 2006 8:48 am Post subject: Re: Sensitive Elevator |
I’ve flown about 250 hours in my 601XL. In August, I flew the little bird from Albany, NY to Roseburg, OR and back to Princeton, NJ (many stops along the way, obviously). The flight across the divide and into Missoula was a thrill of a lifetime. Anyway, the point is that I hit some rough stuff on more than a few occasions and I know exactly what you mean.
The tendency is to grab the stick tighter during turbulence; which frankly makes things worse. If the plane is trimmed, there is no need for more than a light touch ... even during turbulence. Relaxation is the key. You have to get into the habit of using only the thumb and forefinger on the stick. You know the plane isn't going to do anything unusual ... so just keep a loose grip and go with it.
Watch your inclinometer during those rough patches. You'll find that the use of rudder is often much more appropriate than the use of ailerons. 3 hours across Kansas in 106 degree weather was the best rudder lesson I ever had. I thought I knew how to fly the Zodiac before, but was sure I knew after. :)
Leave the elevator geometry alone. The designer made it that way for a very good reason. In slow flight and unusual attitude situations, you will need that extra travel and command.
Safe flying.
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE
Posted: Thu Nov 23, 2006 1:14 pm Post subject: Sensitive Elevator |
Davud,
do you have any good pics of the trip. Sounds like a fun one.
Juan
David X
Posted: Thu Nov 23, 2006 8:34 pm Post subject: Re: Sensitive Elevator |
I have a few. Look for my blog and pics here: http://www.myspace.com/601nj
| amyvega2005(at)earthlink. wrote: | David,
do you have any good pics of the trip. Sounds like a fun one. |
DO NOT ARCHIVE |
David X
Posted: Fri Nov 24, 2006 12:22 am Post subject: Re: Sensitive Elevator |
| amyvega2005(at)earthlink. wrote: | | David, do you have any good pics of the trip. Sounds like a fun one. |
Thanks for asking. I posted the story and pictures on this forum. Hopefully it will get everyone off of this gloomy speculation over crashes and thinking about the freedom and joy of flying.
DO NOT ARCHIVE |
Posted: Fri Nov 24, 2006 6:15 am Post subject: Sensitive Elevator |
I looked for it in archives, can you send me the link.?
JUan
David X
Posted: Mon Nov 27, 2006 12:25 am Post subject: Sensitive Elevator |
Hi Dan,
The oscilations I am talking about are induced by me, when correcting in heavy
turbulence, as the slightest movement on the stick forwards or backwards causes
a pitch change. I.e. deflecting the ailerons to lidt a dropped wing in
turbulance is very dificult to not move the stick in the pitch direction as
well.
Then Weight and Balance is bang on the manual, a I would not fly it otherwise.
(Done with three digital scales, by my AMO)
Jonathan
Jonathan,
Dan
andrewtub
Posted: Thu Feb 23, 2012 10:32 am Post subject: Re: Sensitive Elevator |
I know this is an old subject to most, but new to me. Here in my input on the issue that I have sent to Zenith for approval....
This improvement is a in order to help de-sensitize the elevator and better balance the controls. Bare with me as I explain and forgive me if the is something that has been reviewed in the past. Also this is with the dual stick option.
According to the geometry of all the cable and rod attachment points at the elevator and the control stick, the deflection of the elevator is equal to the deflection on the control stick. Before the reduction of down throw to in the elev, the elev and stick deflections were both 52-62 degrees. Now that the Elev throw is 42-47 degrees so is the control stick.
My goal is to regain the 52-62 degree deflection of the stick and maintain the 42-47 degree deflection of the Elev. This will make the pilot move the stick more (with less force) in order to have the same amount of deflection in the Elev...thus desensitizing the elev.
After some CAD work I have determined the the 5/16 hole in the horn of part number 6-ds-2-2 will now be 92.5mm from the center of the rotational axis of 6-ds-2-opposeded to the original 130mm hole location indicated on print 6-DS-2.
larrycmcfarland(at)gmail. Guest
Posted: Thu Feb 23, 2012 12:43 pm Post subject: Sensitive Elevator |
Hi Andrew,
It sounds like you haven't completed your aircraft if drilling more holes
and such are being contemplated. I 'd recommend you stay with the drawing.
The reduction you mention would result in load-changes that would put more
force on
your control stick. This would cause you to lose the very control
sensitivity needed for the elevator. Most people flying the Zeniths comment
that "the elevator has a lot of authority" and requires only small movements
during maneuvering, landing etc.
Decreasing the stick throw while increasing the force seems contrary to your
need and perhaps a safety issue.
Respectfully,
andrewtub
Posted: Thu Feb 23, 2012 4:39 pm Post subject: Re: Sensitive Elevator |
Larry, What I am talking about is the opposite of what your concern is.
This change will require less stick force and have more stick travel. The more stick travel will equal that of the original design while the elev deflection would meet the new specs.
Here's my deal. I hear all these opinions about.. just fly it for 10-15 he's and you will get used to it. Why should I get used to an undesirable trait of the plane when I have the opportunity to fix it now. I will still have the required elev deflection and better input resolution.
AT
steve.freeman(at)syntaxds Guest
Posted: Thu Feb 23, 2012 5:00 pm Post subject: Sensitive Elevator |
<< an undesirable trait of the plane >>
Hmmmmmmmmmmmmmmmm
Steve
BARRY CHECK 6
Posted: Thu Feb 23, 2012 6:05 pm Post subject: Sensitive Elevator |
It is NOT an undesirable trait. What is undesirable is that 99% of the pilots out there learned on a SLOPPY C-152. THAT DOES have undesirable characteristics. What you suggest is that you could run out of stick.
On Thu, Feb 23, 2012 at 7:39 PM, andrewtub <andrewtub(at)yahoo.com (andrewtub(at)yahoo.com)> wrote:
[quote] --> Zenith-List message posted by: "andrewtub" <andrewtub(at)yahoo.com (andrewtub(at)yahoo.com)>
AT
http://forums.matronics.com/viewtopic.php?p=367098#367098
target="_blank">http://www.matronics.com/Navigator?Zenith-List
le, List Admin.
andrewtub
Posted: Thu Feb 23, 2012 6:33 pm Post subject: Re: Sensitive Elevator |
Seriously, I had no intention to fuel a fire. It's just a mere suggestion to better a feature of the plane. In allot of the reviews I read it is mentioned that the controls could be more balanced. I get the same from three local zodiac pilots. Why not try to improve when the opportunity is there?
In response to running out of stick... the elev will still have full range of motion to the up and down stops specified by zenith.
davgray(at)sbcglobal.net Guest
Posted: Fri Feb 24, 2012 3:42 am Post subject: Sensitive Elevator |
Andrew
The controls on my 601XLB require only small inputs during flight. Even in
a 60 degree bank it only requires two fingers for pressure and no trim
adjustments.
Compare that to C & P models where the nose drops fast. The relative
displacement of the controls is pretty close. The pressure for full aileron
deflection at slow speed
is higher than the elevator with my hinge-less ailerons but not irritating.
The overall impression is good.
Mine displays completely neutral stability which makes it feel nimble but
does not self correct and return to level flight by itself when disturbed.
For that reason I did put Dynon's autopilot in. It is easier to check a map
or look up a frequency without deviating from course and flight level.
Gary Ray davgray(at)sbcglobal.net
Zenith 601XL-B, William Wynne Corvair 0.060 over, Roy's 5th bearing,
Mark's Falcon Heads, Marvel Schebler MA3-SPA Carburetor, 175 Hrs TT
Afterfxllc(at)aol.com Guest
Posted: Fri Feb 24, 2012 7:21 am Post subject: Sensitive Elevator |
If I read your email correct.....
I have thought about doing the exact same thing for my next 2 planes I build.... What you are suggesting makes sense because it would allow more stick movement for the same elevator movement thus making the stick less sensitive which is a good thing.
Jeff
In a message dated 2/24/2012 6:43:25 A.M. Eastern Standard Time, davgray(at)sbcglobal.net writes:
[quote]--> Zenith-List message posted by: "Gary Ray" <davgray(at)sbcglobal.net>
Andrew
adjustments.
rpf(at)wi.rr.com Guest
Posted: Fri Feb 24, 2012 7:40 am Post subject: Sensitive Elevator |
"making the stick less sensitive which is a good thing"
Not for me! I love the way the stick feels. Wouldn't change it for the world.
Randy
