PeterHunt1(at)aol.com Guest
Posted: Sat Jan 28, 2006 10:30 am Post subject: Fwd: plenum |
Return-path: <PeterHunt1(at)aol.com>
Full-name: PeterHunt1
Message-ID: <24c.5f1d665.310d0ff1(at)aol.com>
Date: Sat, 28 Jan 2006 13:20:33 EST
Subject: plenum
To: aflyer(at)lazy8.net
-------------------------------1138472433
John,
I too have built a nice aluminum plenum for my RV-6 (O-360-A1A). Just got
it in the air, but immediately found hot CHT's on climb out. I too suspect my
LASAR and am running tests to determine how much CHT drop there is when I
switch it off. You said your Lightspeed system solved the problem, but was
there also any change in fuel burn?
Pete
<META content=3D"MSHTML 6.00.2800.1264" name=3DGENERATOR>
<BODY id=3Drole_body style=3D"FONT-SIZE: 10pt; COLOR: #000000; FONT-FAMILY:=20Arial"
bottomMargin=3D7 leftMargin=3D7 topMargin=3D7 rightMargin=3D7><FONT id=3Drole_document
face=3DArial color=3D#000000 size=3D2>
John,
I too have built a nice aluminum plenum for my RV-6 (O-360-A1A).=20Just
got it in the air, but immediately found hot CHT's on climb out. I too
suspect my LASAR and am running tests to determine how much CHT drop there is
when I switch it off. You said your Lightspeed system solved the problem,
but was there also any change in fuel burn?
Pete
-------------------------------1138472433--
Nuisance
Posted: Sat Jan 28, 2006 2:34 pm Post subject: Re: Fwd: plenum |
Pete
I did not see a change in fuel burn, or in true airspeed when I switched.
I only saw the reduction in CHT, and the increase in EGT, both about the same as when I turned my LASAR off.
I have the optional timing display with the Lightspeed...at 8500 ft, wide open throttle (23" map), and 2500 rpm, it only shows about 4 degrees advance from baseline.
I don't know what the LASAR system was doing, they consider that information to be proprietary.
_________________ Life is too short to run lean of peak. |
walter(at)tondu.com Guest
Posted: Sat Jan 28, 2006 5:29 pm Post subject: Fwd: plenum |
They must have told avweb, and I've also gotten this information
directly from them over the phone. Here's a quote from avweb.
"With settings available from zero to 42 degrees before Top Dead Center,
however, the LASAR matches the spark advance to make possible the most
"fire in the hole" from the smallest possible amount of fuel."
And the whole article...
http://www.avweb.com/news/reviews/182489-1.html
Walter Tondu
http://www.rv7-a.com
Flying!
Nuisance
Posted: Sun Jan 29, 2006 6:32 am Post subject: Re: Fwd: plenum |
Hi Walter
I did read that article back in '01, and that, together with a strong recommendation from Ken Tunnel at Lycon, is why I ordered my engine with the LASAR system.
The information I tried to get from Harry Fenton when he was still working for Unison was basically a timing map. That is, at what MAP and RPM does the advance start, and what is it at a normal cruise setting, and what is it at a high altitude cruise, etc. This information has always been withheld. We are given the range 0-42 degrees...I think Lightspeed says 0-40. But, it is the essence of this dicussion to consider when, and how much, advance is provided at various settings. This is what I am referring to when I say that the LASAR advance curve is too aggressive...too much advance comes in too early as MAP is reduced, and that is what causes the CHTs to run higher than they should.
I firmly believe that with LASAR, by the time you provide enough extra cooling air to keep your engine at normal, sub 400 degree CHTs, you have caused enough extra drag to negate the benefit of any extra power you may be getting from the timing advance. You are also putting more strain on the rod and main bearings (see the discussion of thetaPP on the GAMI website, and John Deacon's articles on AVWEB).
I have read (somewhere, maybe on one of these email lists) that the E-mag people are using a more conservative timing advance curve, and I would leap to the conclusion that they are aware of these problems.
LASAR, as a certified system, is stuck with what they have. The company won't put more R&D into the system due to the poor market acceptance on the existing system...they won't even develop a system for Continentals. They did their testing on C-172s and various Pipers that provide huge masses of air for cooling (and go slow). They pushed the timing curve in the attempt to provide more attractive performance results, and didn't realize what would happen to the tighter cowled engines in the experimental world.
Best of luck to ya!
disclaimer...these are all just my stupid opinions.
Posted: Sun Jan 29, 2006 6:12 pm Post subject: Fwd: plenum |
I agree on every point. Well said.
Walter Tondu
Flying!
