Flight testing and Airmaster controller
hagargs(at)earthlink.net
PostPosted: Thu Nov 23, 2006 12:09 pm    Post subject: Flight testing and Airmaster controller Reply with quote
Twenty hours are on the plane now. Was out yesterday for 2 and a half hours and burned 9.1 gallons of gas. Landings in the mon-wheel are becomming a non-event. Eight T&g's and 1 full stop resulted in no hair raising events. Concentration on the task at hand was all that was required. Now flying with only one aboard results in very impressive performance. Take offs only require giving it the gas and keeping it straight. It leaps off the ground the moment back pressure is taken off of the stick. Clean stalls are straight and true with plenty of warning. Dirty stalls require some footwork to keep from falling off on a wing. No worse than a 152 I had been in. CO levels have been going down with each minor mod. Latest mod: I removed the access door on the bottom of the fuselage for the gascolator and sump drains under the rear baggage bay. This was replac ed by a reverse scoop. If CO is coming in through the flap slots this is in position to suck it right out again. Did this after flyling with Bob Lindsay in a Liberty. There are 2 scoops under the Liberty fuselage right about where my gascolator door is. It was real convenient to do this already having a hole under my plane. The scoop is pretty unobtrusive under there.
Squawks: Still need to fix my right strobe, think the cheap wire I used is breaking down under the high voltage. Strobe light and power supply is good, and multimeter shows continuity to the wing tip, though no strobe flashing. Kuntzleman has a wingtip strobe light harness I am planning to pull through the wing.
The Airmaster controller is no regulating the propellor in automatic mode. Manual switch works fine at controlling pitch. The fuse at the back side of the controller was reset. All wiring appears tight and secure. The slip ring contacts and wiring looks good. Has any one dealt with this? Are there any other bench test other than those noted in the book? Do all of these things have to be sent to NZ to be checked out? Does anyone know of any US service reps?
Steve Hagar
A143
N40SH
Mesa AZ
Steve Hagar
hagargs(at)earthlink.net (hagargs(at)earthlink.net)
daseitz(at)cfl.rr.com
PostPosted: Thu Nov 23, 2006 1:46 pm    Post subject: Flight testing and Airmaster controller Reply with quote
Look at the indicator lights on the controller when in the auto mode. It
should tell you if there is a problem. See which lights are on and what
color they are and if flashing or not. Look it up in the book for any
faults. What happens if you put it in manual and set the pitch in the middle
and then switch to auto? Does the prop go to fine pitch or stay where it is?
And what do the lights do then?
Dean Seitz
Troy Maynor
PostPosted: Fri Nov 24, 2006 8:07 pm    Post subject: Flight testing and Airmaster controller Reply with quote
Steve,
It is always encouraging to read of sucess with the monowheel. I am still
working on mine when I can and have been tempted to try and change over to a
trike gear even though the extra time and cost. I will fly as a mono and see
then. I had some questions for you if you don't mind;
How much tail dragger time did you have before the Europa?
Did your insurance cost more because of the retractable gear and it also
being a tail dragger?
Did you get Europa specific training before you flew yours?
Thanks for the help and encouragement.
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,interior,engine install, wiring.
Weaverville, NC USA
<<<<<<<<<<<<<<<<<<<<<<Time: 12:09:17 PM PST US
Subject: Flight testing and Airmaster controller
and
non-event.
Concentration
giving
going
bottom
bay. This was replaced by a reverse scoop. If CO is coming in through the
scoops
breaking
Kuntzleman
wing.
propellor
fuse
secure.
Do
know
Steve Hagar
A143
N40SH
Mesa AZ
Steve Hagar
hagargs(at)earthlink.net >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
hansjd(at)online.no
PostPosted: Sat Nov 25, 2006 2:36 am    Post subject: Flight testing and Airmaster controller Reply with quote
Hi Steve,
Good to hear your mono behaves "normal" - in contrast to all the horror
stories I've heard and read. An interesting question in this respect:
How long are your outrigger legs? Do they touch the ground simultaniously
with the main?, i.e. are all four whells touching ground at the same time?
I seem to remember someone refering to the ground handling of his mono as a
non-event - due to outriggers beeing longer than specified, was that you?
Mine are 6mm longer each side, but still a small wagging is noticeable.Maybe
I should go for longer lengs before flight-testing. I expect that to happen
in the spring.
Congrats with your finished and flying Europa!
Cheers
Hans # 334
nielskock(at)get2net.dk
PostPosted: Sat Nov 25, 2006 8:57 am    Post subject: Flight testing and Airmaster controller Reply with quote
Hi Hans and Troy and others waiting for the Mono-baptism.
Believe me: don't waste one minute worrying about the lenght of the spindly
outrigger legs. As long as they
are according to the builder's manual it doesn't matter one bit whether both
weels are resting on the ground
or are a couple of cm above the dirt. As soon as you apply power and are
accellerating down the runway,
concentrating on keeping straight the airflow will stabilize the wings, and
you won't notice that your under-
carriage is a little different from those with dangling airbrakes
permanently locked in the dwn. position.
And once safely airborne you will enjoy the feeling of acceleration when you
retract flaps and wheels.
As many Mono-owners have probably mentioned before in these pages even the
first landing is a thing to
look forward to and not to dread. Why? Because you will most likely be more
concentrated than ever before
which is definitely a helpful thing in that situation. Again, the
outrigger-wheel configuration is NOT a problem
as long as you tap-dance your rudder-pedals eagerly, keeping the little
beauty straight.
There is even a very good chance that your first landing in your very own
Europa will be one of the best
you have made, very likely better than many of the subsequent ones.
How do I know this? Because that is exactly what happened to me one glorious
day July 12 .1999.
Will it ever ground-loop? Not neccessarily if that initial level of
concentration is present during each and
every landing that marvellous little thing.
I shall not boast that I have never groundlooped. I have, once, because I
allowed myself to relax after a memorable,
but successful landing. It happened about 3 years ago when I arrived home
from a PFA rally at Kemble.
The wind was gusting to 40 Kts around the Airport (Odense, DK), and finals
were bumpy, to put it mildly, but
all went well. Until I, wery content with myself, crossed the apron 90
degrees to the gale, taxying a trifle fast, I
must confess, the hangar 200 meters away beckoning. One of the 40 knotters
noticed my smugness and slammed
the tail of my poor ODA, swinging her round, dipping her nose and smashing
her propeller.
It could have been avoided with more contration! And it had nothing to do
with landing the mono.
So, enjoy.
Niels Kock
PostPosted: Sat Nov 25, 2006 11:09 am    Post subject: Flight testing and Airmaster controller Reply with quote
My outriggers are slightly short and do not both touch the same time. The
trick is to ignore any rocking from side to side and just keep it straight
with the rudder. To date I do not even find myself consiously trying to
correct for rocking with the ailerons at least on the ground anyway. If
you are straight and have the ground speed the plane just jumps off of the
ground with just a tiny release of back pressure. If I have a cross wind
present I give in a little pre load and keep the upwind wing down.
Aileron fine tuning really comes in as soon as you leave the ground where
your're not bumping outriggers.
Steve
Steve Hagar
tony.bale(at)virgin.net
PostPosted: Sat Nov 25, 2006 3:15 pm    Post subject: Flight testing and Airmaster controller Reply with quote
Troy,
Stick with the Mono. I had 500 hours on spam cans - so hardly well
experienced. With less than 4 hours on a PFA course I was signed off.
Respect the aircraft, don't stop flying it till its in the hanger, and
don't push the crosswinds - less from the left!
Our test pilot told us - while you're on the ground if your feet aren't
moving - you've lost control, so hide you're wallet.
Our outriggers touch when she's on the ground, no idea if it makes any
difference.
We had no problems with insurance and there are 3 other Europa's at our
strip all Mono's.
And one last thing - watch all the gizzmo's - weight goes on exponentially
Keep smiling (and sanding)
Tony.
ps still havn't installed the Airmaster, its in the garage - but can't wait.
Original Message:
Date: Fri, 24 Nov 2006 22:58:31 -0500
Subject: Re: Flight testing and Airmaster controller
Steve,
Troy Maynor
Left to finish:
Weaverville, NC USA
and
non-event.
Concentration
giving
going
bottom
scoops
breaking
Kuntzleman
wing.
propellor
fuse
secure.
Do
know
Steve Hagar
A143
N40SH
Mesa AZ
Steve Hagar
mail2web - Check your email from the web at
http://mail2web.com/ .
Troy Maynor
PostPosted: Mon Nov 27, 2006 5:24 pm    Post subject: Flight testing and Airmaster controller Reply with quote
Fellow Europaphites,
I want to thank all of you that replied on the above subject. I received
only positive reenforcement to keep me pressing forward in my monowheel.
I will see yall in the clouds. Thanks.
Troy Maynor
Left to finish:
Paint,(some) interior,engine install, (some) wiring.
Weaverville, NC USA
winmail.dat
 Filename:  winmail.dat
 Filesize:  1.73 KB
 Downloaded:  194 Time(s)
