cabin locks
dlm46007(at)cox.net
PostPosted: Fri Nov 24, 2006 7:39 pm    Post subject: cabin locks Reply with quote
Anyone putting keyed locks on the main doors? any pictures of the inside mechanism?
capsteve
PostPosted: Fri Nov 24, 2006 9:01 pm    Post subject: cabin locks Reply with quote
I’ve been working on kitting up an install using these billet flush handles. I need a week or two more to finish up but I’ll post some pics of the handle now and follow up later with some install pics…
Steve
40205
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Friday, November 24, 2006 10:39 PM
Subject: cabin locks
www.aeroelectric.com
 Filesize:  46.12 KB
 Viewed:  159 Time(s)
 Filesize:  49.93 KB
 Viewed:  173 Time(s)
LarryRosen
PostPosted: Sat Nov 25, 2006 5:36 am    Post subject: cabin locks Reply with quote
Dave,
Look at Tim Lewis' guide on using two key locks like those used on the
baggage door.
<http://home.earthlink.net/~timrv6/doorlock/door_lock.html>
Larry Rosen
inside mechanism?
Larry Rosen
#40356
N205EN (reserved)
<http>
jesse(at)itecusa.org
PostPosted: Sat Nov 25, 2006 9:02 am    Post subject: cabin locks Reply with quote
We have put the extra lock that comes with the ignition/baggage set in the pilot’s door. The mechanism, when it “locks” swings the lever in the way of the geared arm that connects to the pin that locks the door. It is not very strong, but if someone wants to get it that bad, it is better that they break the lock than the door or something like that. For the right side, to prevent needing to go around and unlock, we drill a hole in the same rod just forward of the handle mechanism on the arm that pulls the from pin and stick a quick-release pin in the hole so the mechanism cannot move. That seems to work quite well.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
-- Release Date: 11/24/2006 5:20 PM
11/24/2006 5:20 PM
