jdm(at)wideworld.net Guest
Posted: Thu Nov 23, 2006 1:41 pm Post subject: Spark Plug Gap Question |
Happy Thanksgiving everyone!
I'm changing plugs in my 503 and I was wondering what the gap should be?
The plugs are NGK BR8ES.
Thank you!
John Murr
Original Firestar
503 DCDI
Posted: Thu Nov 23, 2006 2:03 pm Post subject: Spark Plug Gap Question |
should be?
| John Murr
John M:
Kodiak has all the manuals for all the engines on the web. Download
and check it out:
http://www.kodiakbs.com/tiintro.htm
_________________ John Hauck
Titus, Alabama |
Posted: Thu Nov 23, 2006 2:18 pm Post subject: Spark Plug Gap Question |
Thank you!
HShack(at)aol.com Guest
Posted: Thu Nov 23, 2006 2:53 pm Post subject: Spark Plug Gap Question |
In a message dated 11/23/2006 4:42:27 PM Eastern Standard Time, jdm(at)wideworld.net writes:
| Quote: | I'm changing plugs in my 503 and I was wondering what the gap should be?
Thank you!
John Murr |
My book says ".016- .020". I use a flat feeler guage & set to a snug .017".
Howard Shackleford
FS II
SC
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Thu Nov 23, 2006 7:43 pm Post subject: Re: Spark Plug Gap Question |
My 503 with gual Ducati ignition is supposed to have plug gaps of .014 - .018 per the manual. I can be hard to start if the plug gap is larger than spec.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
Posted: Thu Nov 23, 2006 8:25 pm Post subject: Spark Plug Gap Question |
In a message dated 11/23/2006 10:44:48 PM Eastern Standard Time, jrjungjr(at)yahoo.com writes:
| Quote: | My 503 with gual Ducati ignition is supposed to have plug gaps of .014 - .018 per the manual. I can be hard to start if the plug gap is larger than spec.
John Jung
Firestar II N6163J
Surprise, AZ |
The manual I have came with my 503 DCDI purchased in late '98; I wonder if Rotax changed the gap spec. sometime after that...........
Howard Shackleford
FS II
SC
Posted: Thu Nov 23, 2006 8:33 pm Post subject: Spark Plug Gap Question |
wonder if
| Howard Shackleford
Shack:
Look it up here:
Titus, Alabama |
Posted: Fri Nov 24, 2006 4:28 am Post subject: Spark Plug Gap Question |
The Kodiak guide says .016-.020 for the 503. I used .018.
