pcondon(at)mitre.org Guest
Posted: Tue Nov 21, 2006 8:06 am Post subject: Fuel line question (Dana) _ W R O N G C A R B F I T T I |
I seem to recall a special Lycoming P/N fuel line fitting #6 all steel
that threads into the carb with a jam nut with a "O" ring to seal. You
have a normal aluminum fitting threaded into the carb. I would go with
the steel fitting.
Now for your clearance problem. Can the 90 degree carb fitting rotate
up and a 45 fitting be added to route your feed line away from the
exhaust work ? I have used universal steel 45's and 90's (JIC) #6 to do
such routing.
I also recall the Lycoming steel nipple being "O" ringed just for this
case where you need exact orientation AND fuel sealing. Without the "O"
ring thingy you are at the mercy of snugging the tapered pipe threaded
fitting of the standard fitting down to disallow fluid leaking but not
aligning as needed......
| Quote: | use
that, the fuel line passes right over the exhaust. The 90 degree
fitting
| Quote: | parallels the exhaust but still is within an inch. In addition, as
you
| Quote: | can
see in the picture, the fuel line make a 90 degree "curve" that "just
ain't
right". More here, the firesleeves rubs the engine mount which will
not
| Quote: | viabrate.
Suggestions or "ID'ers"
Could someone please post a link showing there fuel line run from the
mechanical fuel pump to the carb.
I need to get this firewall forward stuff done as the painter just
called
| Quote: | to
say he painted the flying surfaces BLACK over the weekend!!
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
