5324(at)PRTC.NET Guest
Posted: Fri Nov 17, 2006 12:47 pm Post subject: CLASSIC IV FLAPERONS RIG... |
HELLO: I NEED TO RIG.. MY AILERONS AGAIN...DO ANY OF YOURS HAVE ANY WAY TO DO IT POINT BY POINT//////// THANKS A MILLION
PEDRO
AGAIN IN THE AIR////
CLASSIC IV WITH VERNER ENGINE
roncarolnikko(at)hotmail. Guest
Posted: Sat Nov 18, 2006 7:43 pm Post subject: CLASSIC IV FLAPERONS RIG... |
Hi Pedro I taped a small piece of wood such as a broom handle to the bottom
of the flaperons extending forward to a point 1" below the forward wing
spars. Center the control stick and adjust linkage rods to fit flaperons.
You may need to lengthen or shorten both equally from there to get the
proper nuetral flap setting. Be sure to check for binding when moving stick
to all extreme positions. Ron NB Ore
| Quote: | From: "PEDRO PEREZ" <5324(at)PRTC.NET>
Subject: Re: CLASSIC IV FLAPERONS RIG...
Date: Sat, 18 Nov 2006 16:42:10 -0400
PEDRO
Stay up-to-date with your friends through the Windows Live Spaces friends
list.
Lynn Matteson
Posted: Sun Nov 19, 2006 11:19 am Post subject: CLASSIC IV FLAPERONS RIG... |
Pedro-
There is a rather long procedure involved in rigging the flaperons
correctly. It would be best if you could get hold of someone locally
who has this procedure in their building manual, or contact John McBean
via this group. He should be able to help you out. If not, I could copy
the procedure from my manual and send it to you.
Lynn
On Saturday, November 18, 2006, at 10:43 PM, ron schick wrote:
<roncarolnikko(at)hotmail.com>
bottom of the flaperons extending forward to a point 1" below the
forward wing spars. Center the control stick and adjust linkage rods
to fit flaperons. You may need to lengthen or shorten both equally
from there to get the proper nuetral flap setting. Be sure to check
for binding when moving stick to all extreme positions. Ron NB Ore
> PEDRO
friends list.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Sun Nov 19, 2006 2:52 pm Post subject: CLASSIC IV FLAPERONS RIG... |
Flapperon info all here http://www.cfisher.com/
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
