AV8ORJWC
Posted: Sun Nov 12, 2006 12:34 am Post subject: Quadrant vs. Vernier Cables |
A comment was made (I believe from Scott) which went unresponded to. For those few who have not made their decision or are still open to input on the subject of choice. It has been said that the Law of Primacy prevails in aviation. That item first learned by instruction or experience is most often retained. Example, most pilot who learn on High wing prefer High Wing. Those who learn on Low wing prefer low wing. Those who fly with Vernier cables, tend to choose cables for their RV-10. Those who have flown High Performance aircraft (those over 200 hp) with throttle quadrants on turboprop or turbine or multi then tend to chose throttle quadrants.
The choice of throttle quadrants allows the competent pilot to control Throttle-Prop-Mixture with multiple digits - Simultaneously. Much like piano playing it is a learned skill. Add Multi-Engine into the mix and the more primitive cables are automatically replaced with a quadrant and the discussion is over.
Just food for thought which no one commented on after the valuable observation.
John Cox
#40600
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sun Nov 12, 2006 12:47 am Post subject: Quadrant vs. Vernier Cables |
There was a lister who pointed out the difference in price of the throttle quadrants from vans and aircraft spruce. I’m ready to pick one up and am also curious as to the quality difference. Anyone have any experience with both from a comparison standpoint???
Steve
40205
AV8ORJWC
Posted: Sun Nov 12, 2006 1:25 am Post subject: Quadrant vs. Vernier Cables |
Just to benchmark the process. Take a look at the two variants used on Lancair IV and IVPT through Aerocraft Parts & Avionics. http://www.aerocraftparts.com/SearchForm.aspx?Search=Throttle%20Quadrant Then the A/S looks pretty nice. You get what you pay for.
Seek “In the Left seat time” with flying RV-10s, cause it is worth the effort. Once you have flown proficiently with a quadrant, the discussion might just be closed.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri
Sent: Sunday, November 12, 2006 12:44 AM
Subject: RE: Quadrant vs. Vernier Cables
Steve
40205
Tim(at)MyRV10.com Guest
Posted: Sun Nov 12, 2006 2:38 am Post subject: Quadrant vs. Vernier Cables |
I didn't comment on this at the time, but here goes...
I don't know if they're the same quadrant, or not, but I would certainly
recommend at least that it be the identical quadrant. The one from
Vans is made to such a length as to fit properly in the matched holes.
It's also very smooth and nice. The only negative is that it doesn't
come with any cool sort of cover for the sides, but I took care of that
myself. One thing when comparing the quadrants, you need to understand
that from Van's, when you order the quadrant, you're also getting the
3 cables, and some hardware too, so the price difference still might
be there, but it probably isn't that extreme. Van's isn't known for
overcharging on many items, after all, so I'd be surprised if it were
lots more when compared apples-to-apples.
My one tip for the quadrant: It does rub between the levers and
body, on the slots. Take some UHMW tape and put small tape tabs
on the control arms, just about 1" long, where it contacts the slots
on both sides of the lever. The noise goes away and it's silky
smooth.
I'm sure everyone already saw my reply to Scott's post where I
agreed that it was far nicer and more precise than the experience
I had with Van's push-pulls in N220RV, so I won't do that over unless
requested.
Steven DiNieri wrote:
[quote] There was a lister who pointed out the difference in price of the
Steve
40205
apilot2(at)gmail.com Guest
Posted: Sun Nov 12, 2006 6:01 am Post subject: Quadrant vs. Vernier Cables |
For balance, I'll give you the other side. I'm multi rated, have flown
both twins, where, as you say, there is no argument, and Mooneys with
both quadrant and pushpull. With the Mooney there is no question, the
push pull is better. I recently flew one with a friend checking out an
engine analyzer. It simply wasn't possible to make mixture adjustments
to finer than 2-3 tenths gph, making achieving a desired 20 LOP for
that particular flight very difficult to achieve. I've observed the
same issue on twins for both mixture and trying to sync the props...it
takes effort and concentration. Perhaps you get better at inducing
minute changes with more hours...you are right about primacy, and I
have probably 15 times more time in planes with push pull than
quadrant, but my time in quadrant planes isn't all that small either.
The nicety of being able to operate all three levers(or more) at once
simply isn't needed on a single engine. The prop is rarely changed,
perhaps 2-3 times per flight. The mixture needs to be finely adjusted
for cruise and then mostly left alone.
The throttle is the only control you will change more frequently.
Then there is the maintenance side. Push pull is easier to install,
adjust and maintain.
Just the other side of the coin. Don't expect to change anyone's mind.
On 11/12/06, John W. Cox <johnwcox(at)pacificnw.com> wrote:
discussion is over.
Posted: Sun Nov 12, 2006 6:44 am Post subject: Quadrant vs. Vernier Cables |
To be perfectly straight forward as it relates to the RV-10, and
only the RV-10, if you buy the quadrant from Van's, and compare it
to the push-pulls from Van's as installed on their factory planes,
there is no comparison that the quadrant is better.
I understand that there will be opposite or varied results when
talking about other manufacturers of planes, but on these particular
planes, using the Van's supplied options, that is what my comments
are related to. To be even more precise, the only quadrants
on RV-10's I've used have been in conjunction with fuel injected
RV-10's, using both AFP and Bendix/Precision systems, and they're
both smooth...not sure about carbs.
The sad thing is, probably 98% of the builders will make this
decision without having the opportunity to directly compare them.
I didn't get the direct comparison until I flew my own plane
with the quadrant.
The reason I bring this up so adamantly, by the way, is that my
transition training experience was not nearly what it could have
been because I was distracted constantly by poor throttle/prop
control. I wanted badly to fly with precision, and when 2350
RPM was called for, I wanted 2350, not 2390. On 220RV, with
it's push-pulls, this was a very big challenge and caused me to
spend much more time than I wanted on obtaining this precision,
and no matter what I did it didn't get better.
To further the matter one more step, I am familiar with push-pulls,
having flown probably 10 different models that used them, so I know
they are capable of being pretty good. But when limiting it to the
Van's available parts, my results are as above. My main concern is
that for those who really *like* the looks and feel of a quadrant
often get pushed by others to go vernier push-pulls because of opposite
results in other planes....having never flown both RV-10 systems.
I simply want them to be comfortable with the idea that on the RV-10,
they will not suffer for having a quadrant, and it may actually
give them a superior feel.
One last comment... For people buying things like EFIS systems, or
debating on panel layout, or picking throttle systems, interiors,
or heck, even the RV-10 kit in general, demo flights are money
well spent. It's well worth spending a little extra cash to seek out
a plane or two that has the equipment you're questioning, and
go for a flight. I only wish these options were easily available
to me when I was building, but there just weren't enough -10's
flying yet. Buy my offer is open to RV-10 builders....if you
can drag yourself up to Wisconsin on a time that we can agree on, I
will be happy to take you for a flight. Most people know how my
plane is equipped, so for anyone interested in similar stuff, it
would be worth it...especially for things like the Cheltons.
You can learn a lot from the more relaxed atmosphere of a flight
with another builder.
Kelly McMullen wrote:
> on the
> flown
> and the
> discussion is over.
ed(at)muellerartcover.com Guest
Posted: Sun Nov 12, 2006 6:47 am Post subject: Quadrant vs. Vernier Cables |
Kelly,
Next time you want to make fine adjustments on a quadrant, try this (if
I can explain it): get the mixture close to the proper setting then
pull the lever towards you (rearward) slightly. Place your thumb on the
faceplate sideways across the slot and against the stem of the lever.
Holding your thumb solid against the faceplate, roll (don't push keep
your thumb keep it stationary on the faceplate) your thumb forward, it
will move the lever in very small increments. I personally like the
quadrant.
Ed Mueller
#40525
> For
> on the
> have flown
> and the
> discussion is over.
ddddsp1(at)juno.com Guest
Posted: Sun Nov 12, 2006 8:01 am Post subject: Quadrant vs. Vernier Cables |
Kelly,
Your thoughts are great for those considering which option to go with. Like most other decisions we make while building they need to FIT your needs...........not your friends who you are trying to impress. The bottom line on these equipment choices is that "most" of the time both options will fly the plane well. For newbies though it is nice to get different perspectives as they may not know the questions to ask at that stage of the build. I know I am MUCH smarter now than 6 months ago largely due to posts and opinions on this list that made me consider other options than my own. However, at the end of the day I make the choice on the equipment that fits my needs........quality, cost, type of flying, ergonomics, etc. I went vernier because I like an OPEN, SPACIOUS cabin. Quadrants look cool but take up space albiet not much but appear to intrude into the cabin from the panel. Call me old fashion but I like a flat panel........contours are ok as long as it doesn't take away from my cabin space. LOL If I could change the plans I would even eliminate the stick between my legs and go to the side joystick like Cirrus or Columbia to give me more cabin "comfort" space. Anyway, for all the newbies...don't discard the vernier controls just because you read a POST stating how great a pilot loves his/her quadrant. Do what you want and what will meet your needs....looks only count on the ground.
Just my 2 cents worth.
Dean 40449
Visit http://www.juno.com/value to sign up today!
kdbelue(at)charter.net Guest
Posted: Sun Nov 12, 2006 8:17 am Post subject: Quadrant vs. Vernier Cables |
Tim, I'd like to add another point of view to this discussion: I flew 220RV
also and like you found that it was difficult to set the rpm's where I
wanted. I have the same type of push-pull controls in my RV-6A but it is
very precise, easy to set the rpm's and I've had the same experience in
other RV's. I'm not refuting that the quadrant is good, I just believe
there is something other than the controls on 220RV that makes it harder to
adjust. At the time I was flying it, I thought it may be how the
instrumentation was set up because I would adjust the manifold pressure and
tach but then a minute later it would be all different.
I haven't decided on which controls to put in my RV10; I like push-pull, but
the quadrant is nice also. I suppose I'll have to fly a 10 with a quadrant
to really know.
Kevin Belue
RV-6A flying
RV-10 finish
mritter509(at)msn.com Guest
Posted: Sun Nov 12, 2006 11:41 am Post subject: Quadrant vs. Vernier Cables |
I've had a quadrant in a Piper Lance and vernier in a Bonanza. Went with
the vernier cables in my RV-10 and find them very precise and easy to use.
Mark (N410MR Flying)
| Quote: | From: "ddddsp1(at)juno.com" <ddddsp1(at)juno.com>
Subject: Re: Quadrant vs. Vernier Cables
Date: Sun, 12 Nov 2006 16:00:18 GMT
Kelly,
space. Anyway, for all the newbies....don't discard the vernier controls
Dean 40449
Try the next generation of search with Windows Live Search today!
Posted: Sun Nov 12, 2006 12:23 pm Post subject: Quadrant vs. Vernier Cables |
Tim & Kevin,
Take a look at the pic attached. I believe this may fix the problem with the venier cables on Vans RV 10. With the much wider panel in the RV 10 the panel flexes and the controls are not as stiff and accurate. I put this on to strengthen the lower panel in the middle where the control are. All but eliminates the flex when you push and pull on the controls.
Just a thought,
DEAN 40449
471.52 KB |
307 Time(s) |
Posted: Sun Nov 12, 2006 3:10 pm Post subject: Quadrant vs. Vernier Cables |
You may very well be right that it is specific to that plane.
That plane is miserable in that area. I also don't want to
discourage people from verniers if that's what you like, because
I can't see why you couldn't make them work well for you if you
tried....and they cost less. It is definitely something that
you can develop a preference for. I just want people to be
assured that you definitely can go quadrant with Van's
quadrant on the -10 and be happy....so don't make your
decision not to go with it based on some perceived lack
of smoothness or precision. It was one of the decisions I
agonized over myself, because the push-pulls do take up
less space in the cabin, and give some different options for
panel layout. Dean is right, in his post, that you should
go with what fits your style the best.
Thanks for your input Kevin, it's nice to know you noticed the
same thing on that plane, but still like the controls in
other RV's.
220RV also and like you found that it was difficult to set the rpm's
where I wanted. I have the same type of push-pull controls in my RV-6A
but it is very precise, easy to set the rpm's and I've had the same
experience in other RV's. I'm not refuting that the quadrant is good, I
just believe there is something other than the controls on 220RV that
makes it harder to adjust. At the time I was flying it, I thought it may
be how the instrumentation was set up because I would adjust the
manifold pressure and tach but then a minute later it would be all
different.
but the quadrant is nice also. I suppose I'll have to fly a 10 with a
quadrant to really know.
Kevin Belue
RV-6A flying
RV-10 finish
Posted: Sun Nov 12, 2006 3:18 pm Post subject: Quadrant vs. Vernier Cables |
Dean, that's a great idea on that brace for the panel. I'm wondering
though if it might not make it more directly stiffer to the cable mount
plate if you put some angle tabs on the end of the mounting plate for
the controls, and attached it to the braces there. That way the actual
place you're pushing on is braced tightly. I'm not sure that this
is what caused 220RV to suck so bad, but if you're right on your guess,
that could be a really good fix. But, Mark also said his work well, so
perhaps it's just 220RV. Maybe it's even more that Continental
engine's injection system.
ddddsp1(at)juno.com wrote:
| Quote: | Tim & Kevin,
controls.
Just a thought,
DEAN 40449
Posted: Sun Nov 12, 2006 3:35 pm Post subject: Quadrant vs. Vernier Cables |
I agree Dean. I don't care if I get the prop within 10 rpm, although
it is easy with most verniers. I want mixture adjustable to the 0.1gph
resolution..which is very hard to achieve with a quadrant..I've tried
every trick in the book on certified airplanes, and a nudge gets you
0.2-0.3 every time. Easy with vernier. I want power precise as well,
as 100rpm over the fence makes difference between planting plane and
floating down the runway.
but for all those that are convinced that quadrant is better for them, so be it.
On 11/12/06, ddddsp1(at)juno.com <ddddsp1(at)juno.com> wrote:
Kelly,
Dean 40449
dmaib@me.com
Posted: Sun Nov 12, 2006 5:05 pm Post subject: Quadrant vs. Vernier Cables |
Dean,
Are the two pieces of aluminum angle running from the firewall to the lower panel the mod you have done? If so, do they connect to the back of the plate that the verniers are mounted in, or to the bottom edge of the panel.
David Maib
40559
On Nov 12, 2006, at 2:19 PM, ddddsp1(at)juno.com (ddddsp1(at)juno.com) wrote:
Tim & Kevin,
Just a thought,
DEAN 40449
<rv10 096.jpg>
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Sun Nov 12, 2006 8:26 pm Post subject: Quadrant vs. Vernier Cables |
Tim,
I went just next to the cable mount because I wanted to be able to remove the cable bracket and lower the controls to work under the panel. Moving it out that much does not effect how ridgid the controls are. It is like nite and day from the original design. Also I am tying up the controls forward of the panel instead of running them through the useless bracket attached to the subpanel.
Dean 40449
Posted: Sun Nov 12, 2006 8:27 pm Post subject: Quadrant vs. Vernier Cables |
Dave,
To the bottom edge of the panel.
Dean
bldgrv10450(at)comcast.ne Guest
Posted: Sun Nov 12, 2006 9:57 pm Post subject: Quadrant vs. Vernier Cables |
Changes?
Wouldn't you know it, I just drilled out the SS oil cooler recess for cables. Then Scott brings up the quadrant and Tim tells us again how much he likes them. Feels like I made a mistake. In the spring of 05' I was planning to build a 9A until Randy Debauw showed up at the EAA105 fly in. That changed my mind. Life is all about change, isn't it? Tim how did you cap off those cable holes? I remember you drilled them out and then later found the quadrant runs in a different location?
Bill DeRouchey, I am going to be in Santa Cruz for Thanksgiving. Will you be around home? I'd love to see the paint job.
Paul Grimstad
RV10 40450 with holes to fill
Portland, OR 97219
Posted: Mon Nov 13, 2006 3:55 am Post subject: Quadrant vs. Vernier Cables |
Hey Paul, basically what happened to me wasn't that the cables
were in a different location (they probably can be the
same from quadrant to vernier), but that I wanted to use
eyeball passthroughs because the dual snap-bushing thing just
didn't cut it for me. My eyeballs are aluminum, which some
would disagree with (they don't disagree with the aluminum rivets
holding the firewall on though), but it's got to be better than
snap bushings. They allow you to start angling that cable
so it comes out of the firewall at an angle that you wish for
better routing, and aluminum allows you to drill the bore
to your cable size for perfect fit.
The situatio that happened is that I had already drilled the 3
holes out for snap bushings. To use eyeballs, I only wanted
to use the 2 outer holes and then drill another below them
in the middle. (the holes would run together if I drilled
all 3. Well, as I unibit drilled the outer 2 holes, they
ran into the drilled center hole, and that whole area
got chewed up. Had I not pre-drilled the holes, it would
have been simple, but I made the mistake of first attempting
snap bushings.
So to fix it, I cut out the mangled metal, went to a metal
shop where they gave me some stainless scrap, and bought
a "patch" that I could drill properly, and then rivet and
red RTV in place to make it all good again. I got slightly
thicker stainless as well.
For what it's worth, I'm not saying you made a mistake not
going with the quadrant. If you like Verniers, you may like
them here too if they don't work like 220RV. But you can
be reassured that the quadrant offers smoothness and precision...
and yes, even on the mixture side to the .1 gph resolution
Kelly. If you haven't flown one (of this type specifically,
it's worth a try. They're nice.
Paul Grimstad wrote:
[quote] Changes?
Paul Grimstad
Portland, OR 97219
Posted: Mon Nov 13, 2006 6:27 am Post subject: Quadrant vs. Vernier Cables |
Thanks Tim
Where did you purchase the eyeballs and do you recall the hole size?
Paul
