k9hxt(at)sbcglobal.net Guest
Posted: Sat Nov 04, 2006 8:36 am Post subject: RV-6A brake squealing |
Has anyone had a problem with squealing brakes during use? One side seems to be more prone to this than the other. New pads at annual in Sept too. This is not new. I have had it for quite some time, years. I read a thread recently about securing the brake lines to gear legs in more than three places, say 5 or 6. Seems to change depending on air pressure in tires too.
Larry , RV-6A, at 2R2, near Avon,IN
"NINER LIMA TANGO SENDS"
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Sun Nov 05, 2006 10:11 am Post subject: RV-6A brake squealing |
Larry,
I doused my brake rotor with liberal amounts of laquer thinner, while scrubbing same with sandpaper and brush. Also cleaned pads. I also put some automotive "squeal stop" on backs of pads. Squealing ceased, so one or more of these cures seemed to work.
Jerry Cochran
In a message dated 11/4/2006 11:58:46 P.M. Pacific Standard Time, rv6-list(at)matronics.com writes:
Quote: | Time: 08:36:49 AM PST US
Subject: RV-6A brake squealing
oo.=0ALarry , RV-6A, at 2R2, near Avon,IN=0A =0A"NINER LIMA TANGO SENDS"
FREE Gifts!) |
dick(at)rclabs.com Guest
Posted: Wed Nov 08, 2006 6:23 am Post subject: RV-6A brake squealing |
Larry;
I had the same problem as you describe.
RV6-A Tires wear unevenly so I rotated the tires at condition inspection time, squeal persisted. Put new tires on airplane and squeal went away. Of course I also did many of the things Jerry mentioned when I changed tires, i.e. cleaned rotors, repacked bearings etc. Did not use squeal stop.
Dick Wildman
Posted: Wed Nov 08, 2006 6:57 am Post subject: RV-6A brake squealing |
Dick,
A couple years back I swapped tires (Van's) and the noise went away for a while. I also have done the cleaning and re-surfacing of the pads/rotors which also helps for a while. Now I have new Goodyear Tires (at annual in Sept) and lo and behold it is back. I am beginning to think tire pressure enters into the equation. I am running about 34# now and have noise. I am going to lower it to say 28# and see it that changes the problem as step one. Have you heard about the brake lines on the gear legs vibrating and thus noise? Also, I did change pads on the offending gear (at tire change). Which makes me suspect I may have glazed them etc. I'll give them a good "resurfacing" also as step two.
Larry
"LIMA TANGO SENDS"
