jaybrinkmeyer(at)yahoo.co Guest
Posted: Tue Oct 31, 2006 3:27 pm Post subject: matco parking brake mounting bracket? |
I got my nifty Matco parking brake dodad recently, but it didn't come with a
mounting bracket. Anyone else have tips on how to mount this puppy? I'm close
to riveting on my fuse skins and would like to get this done before access
becomes an issue.
Thanks in advance for responding...
Jay
Slooow building away (but my finish kit arrived!)
(http://voice.yahoo.com)
noel(at)blueskyaviation.n Guest
Posted: Tue Oct 31, 2006 4:19 pm Post subject: matco parking brake mounting bracket? |
453.62 KB |
394 Time(s) |
434.64 KB |
322 Time(s) |
Here is one I built. Needed to be a little longer so the cable sheath would
have something to secure to. Would also make the base and doublers a little
bigger so all the holes in the fire wall would be covered.
Noel
Blue Sky Aviation, Inc.
433.38 KB |
343 Time(s) |
Posted: Tue Oct 31, 2006 4:20 pm Post subject: matco parking brake mounting bracket? |
428.57 KB |
316 Time(s) |
Deems Davis
Posted: Tue Oct 31, 2006 4:39 pm Post subject: matco parking brake mounting bracket? |
Here's a link to a couple of pics on how some of us have done it. I
can't remember the part #, but if you are not using a carburated engine
there is an extra part that can be adapted to serve as the mount.
http://deemsrv10.com/album/Sec%2036%20Brake%20Lines/slides/DSC02515.html
Deems Davis # 406
Finishing - ( A Misnomer ! )
Jay Brinkmeyer wrote:
becomes an issue.
Jay
Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Wed Nov 01, 2006 6:57 am Post subject: matco parking brake mounting bracket? |
Look at this page. I used the same part as Deems. I believe it is used to
mount a Facet fuel pump, but is not used if injected. The bracket for the
cable I made from scrap. Picture is about half way down the page.
Ted French
RV-10 firewall forward
_________________ Ted French
RV-10 fuselage |
Ted French
Posted: Wed Nov 01, 2006 7:43 am Post subject: matco parking brake mounting bracket? |
Guess a link would help eh !
Look at this page. http://www3.telus.net/elfrench/blog/ I used the same
Ted French
RV-10 fuselage |
Posted: Wed Nov 01, 2006 8:00 am Post subject: matco parking brake mounting bracket? |
Looks really nice! How are you making a positive stop on both ends?
Noel
wcurtis(at)core.com Guest
Posted: Wed Nov 01, 2006 10:03 am Post subject: matco parking brake mounting bracket? |
Here is my take on it. http://wcurtis.nerv10.com/08fuselage/fuselage03w.html >I got my nifty Matco parking brake dodad recently, but it didn't come with a >mounting bracket. Anyone else have tips on how to mount this puppy? I'm close >to riveting on my fuse skins and would like to get this done before access becomes an issue. > >Thanks in advance for responding... > >Cheers, >Jay William Curtis http://nerv10.com/ [quote][b]
Ted French
Posted: Wed Nov 01, 2006 4:57 pm Post subject: matco parking brake mounting bracket? |
Adjust the arm so when knob is in all the way, valve is open. When knob is
pulled out, arm will contact the end of the cable sheath. I don't think you
need any more positive than that.
Ted French
RV-10 fuselage |
jjessen
Is a parking brake required? Necessary? Opinions?
John Jessen
40328
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of W. Curtis
Sent: Wednesday, November 01, 2006 10:03 AM
To: RV10-List(at)matronics.com; jaybrinkmeyer(at)yahoo.com
Subject: RV10-List: RE: matco parking brake mounting bracket?
| Quote: | I got my nifty Matco parking brake dodad recently, but it didn't come with a
Jay
William Curtis
http://nerv10.com/ | Quote: |
| -- No virus found in this Edition. Release Date: 11/1/2006 |
11/1/2006
Deems Davis
dlm46007(at)cox.net Guest
Posted: Wed Nov 01, 2006 5:41 pm Post subject: matco parking brake mounting bracket? |
only if you ever fly alone to an airport on unleveled surface.
Rick S.
jjessen
Posted: Thu Nov 02, 2006 6:23 am Post subject: matco parking brake mounting bracket? |
So, I have to put in those little rings, too?
Ok, enough of this. There was a discussion at some point about the PITA of
the parking break, especially sticking parking breaks. I've actually never
had to use a parking break, other than making double sure the breaks were on
during run-up, and, given the little brain, did not think of the obvious.
John Jessen (40328)
AV8ORJWC
Posted: Thu Nov 02, 2006 8:35 am Post subject: matco parking brake mounting bracket? |
Just place the transmission in Park and Forget-about-it. It only
matters in San Francisco.
John Cox
Rick S.
LloydDR(at)wernerco.com Guest
Posted: Thu Nov 02, 2006 9:51 am Post subject: matco parking brake mounting bracket? |
It is so we can roll start it and pop the clutch!
Dan
40269
jhstarn(at)verizon.net Guest
Posted: Thu Nov 02, 2006 11:39 am Post subject: matco parking brake mounting bracket? |
"Park" would mean that it's an automatic, no clutch so ya gotta push it to
45 MPH to get it to turn over & start. (from a very old joke)
Do Not Archive KABONG (GBA & GWB)
<LloydDR(at)wernerco.com>
Dan
40269
