Beer30?
Posted: Mon Oct 30, 2006 10:21 pm Post subject: Fuel sensors |
I have a question for the more experienced builders out there regarding fuel sensors. I just purchased a used wing kit for my -7. It came with the float type fuel sensors. My question is, what would the advantages or disadvantages of capacative sensors over the floats? I intend on having a fuel totalizer built into the engine monitor, and will probably install a flop tube for limited aerobatics. Thanks in advance for your advice.
Beer30?
David Dalton
Ron Schreck
Joined: 10 Jan 2006 Posts: 94 Location: Gold Hill, NC
Posted: Tue Oct 31, 2006 3:51 am Post subject: Fuel sensors |
David,
Your post brings up a subject which merits some discussion. I often hear builders saying they want to do "limited aerobatics" so they are installing this or that thingamajig on their RV. As delivered, the RV (except the 9 and 10) is capable of many aerobatic maneuvers and it is a joy to flop about with reckless abandon, knowing that it will eventually come out upright with the pointy end going ahead of the tail. Generally the "as delivered" RV is capable of most POSITIVE "G" maneuvers and this gives it quite a long list of available aerobatic options. David, I'm not picking on you, but just adding a flop tube in one of your fuel tanks is not going to give you NEGATIVE "G" capability and thus expand the range of aerobatic maneuvers.
A carburetor will starve your engine immediately at negative "G". Cost of a fuel injection system: $3000+
After 15 to 30 seconds of negative "G" flight your oil pressure will go to zero. Cost of inverted oil system: $1200+
If you have a standard constant speed prop, a momentary loss of oil pressure (even possible with inverted oil system) can cause the prop to go to fine pitch at high power setting and overspeed your engine. Additional cost for an aerobatic constant speed prop: $1500+
Now, if you do spend $6000+ to truly make your RV "fully" aerobatic you really should do something about that single lap belt and purchase a parachute just for safety sake. (Also, remove any ADI (vacuum or electric) with a mechanical ADI or you will eventually ruin the gyro bearings.)
And now you are ready to turn that baby downside up, but the airfoil is not symmetrical so you will really need to work hard to make it perform inverted maneuvers, and did I mention how uncomfortable inverted flight is on your body!
Bottom Line: Most RV's are capable of limited aerobatics when built according to plans and they are a blast to fly. If you want more performance, go buy an airplane that is purpose-made for aerobatics.
I bring all this up, not to discourage anybody, but to give those who may be inclined to equip their RV for "limited" aerobatics something to ponder before you spend the milk money on the next thingamajig. Flame away. Nomex installed.
Ron "Smokey" Schreck
RV-8 "Miss Izzy"
Gold Hill Airpark, NC
Time: 10:21:24 PM PST US
From: "David Dalton" <ddalton536(at)gmail.com (ddalton536(at)gmail.com)>
>disadvantages of capacitive sensors over the floats? I intend on having a
>David Dalton
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Tue Oct 31, 2006 4:11 am Post subject: Fuel sensors |
David,
Advantage = No moving parts to wear and better accuracy over the range. But, if you will have a fuel flow sensor/computer you will find that the fuel gauges will become a reference only.
The mechanical sensors will do fine.
I have the capacitive sensors on one OBAM aircraft that has no fuel flow computer and would recommend them in that case. But, have fuel flow sensor on the 6A and it gives much better useful info.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
charlieray(at)optonline.n Guest
Posted: Tue Oct 31, 2006 3:43 pm Post subject: Fuel sensors |
How DARE you have the GALL to actually make sense!
Beer30?
Posted: Tue Oct 31, 2006 8:49 pm Post subject: Fuel sensors |
Ron,
Thanks for the words of wisdom. You bring up some good points. I was already planning on the CS prop to get the climb performance (I live in Denver), I had considered and knew of the need for the inverted oil system (to protect the engine and keep the belly clean) but did not know the cost. I hadn't considered the CS prop's ability to maintain pitch, although the Super Decathlon I flew had a CS prop, and seemed to do OK with negative G stuff.
In any event, you have me thinking about this, and more research is certainly in order. Thanks to everyone else who responded. I think I'll stick with the float sensors and the fuel totalizer.
Keep on riviting,
DD
On 10/31/06, Ron Schreck <ronschreck(at)alltel.net (ronschreck(at)alltel.net)> wrote: [quote] David,
RV-8 "Miss Izzy"
>David Dalton
Ron Schreck
Posted: Wed Nov 01, 2006 6:58 am Post subject: Fuel sensors |
You live in Denver! That brings up some other points: A constant speed prop would be a great addition. At high density altitudes a fixed pitch is really at a disadvantage. Sure, you lose engine power at altitude regardless of the prop, but with a constant speed you are starting out with far superior takeoff performance in the first place. I was in Greeley, Colorado two weeks ago and did some formation flying and aerobatics. The "floor" is above 7000 feet for aerobatics and performance is noticeably different from the 2000 foot "floor" which is typical out here on the east coast. I can't imaging how difficult negative "G" aerobatics might be at 7000+ feet!
About that Super Decathlon; I haven't flown one and don't know if the prop is aerobatic or not. (Aerobatic props have counterweights that cause the prop to go to coarse pitch when oil pressure fails). Many entry level and intermediate aerobatic airplanes don't use aerobatic props. I guess they are betting that oil pressure fluctuations will be brief and/or occur at less than full throttle operation. Similarly, you could get away without an aerobatic prop on an RV if you are willing to take similar chances.
Side note: Check out the eyeballs of pilots who have done serious negative "G" acro. Looks like they have been on a 3-day bender! The condition (blood shot eyes) isn't dangerous to health but just points out how hard negative "G" is on the body. Positive "G" has similar effects such as G-Rash.
Ron Schreck
RV-8 "Miss Izzy"
>Ron,
>stuff.
>Keep on riveting,
>DD
panamared3(at)brier.net Guest
Posted: Wed Nov 01, 2006 8:28 am Post subject: Fuel sensors |
On the other hand, I purposely built my RV6 for aerobatics. I do positive
and negative maneuvers, I fly the sportsman and intermediate acrobatic
maneuvers. I find the RV6 a delight to fly aerobatics. I do like it much
better than the Super Decathlon. The RV6 is not a Extra 300, nor does it
cost $300,000.
I do have inverted oil, and no it does not keep the belly clean. I do fly
with a 7 point Hooker Harness (ratchet) and it is no more uncomfortable
upside down as it is right side up. Actually my RV6 upside down is a lot
less painful than the Super Decathlon I used to fly. Personally, I would
not own an airplane that did not have Hooker Harnesses in it.
I do not fly with a CS prop. In my opinion it would only give me about 100
FPM more in climb and it would cost me 10 kts in speed, it also would cost
me 45 lbs and increased complexity and maintenance costs. I believe that
the single best thing to do for acrobatics is to keep it light. The extra
45 lbs puts a lot of extra stress on the crankshaft, and if you want a CS
prop and want to do serious acrobatics then you will probably want an
aerobatic crankshaft as well.
As for keeping it light, that applies to my aircraft as well as to me the
pilot.
As for fuel injection. A lot of RV owners have it and they never fly
upside down.
At 10:48 PM 10/31/06, you wrote:
| Quote: | Ron,
Keep on riviting,
DD
<<mailto:ronschreck(at)alltel.net>ronschreck(at)alltel.net> wrote:
David,
on your body!
RV-8 "Miss Izzy"
From: "David Dalton" <<mailto:ddalton536(at)gmail.com>ddalton536(at)gmail.com>
regarding fuel
with the
advantages or
having a
install a
>David Dalton
<http://www.matronics.com/Navigator?RV-List>http://www.matronics.com/Navigator?RV-List
<http://www.matronics.com/contribution>http://www.matronics.com/contribution
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Wed Nov 01, 2006 9:01 am Post subject: Fuel sensors |
In a message dated 11/01/2006 9:00:22 AM Central Standard Time, ronschreck(at)alltel.net writes:
| Quote: | | Side note: Check out the eyeballs of pilots who have done serious negative "G" acro. Looks like they have been on a 3-day bender! |
Sean Tucker was giving a talk at OSH a few years ago and said he knew he was pulling some "real" Gs when he could "feel his eyeballs touching the inside of his sunglasses"
Ow...
Mark do not archive
_________________ From The PossumWorks... |
Ron Schreck
Posted: Thu Nov 02, 2006 1:51 am Post subject: Fuel sensors |
I agree that keeping it light is extremely important. Just curious though, how do you manage to keep the RPMs below red down when you are on a long downline? I fly a lot of formation with others that have FP props and I have to make slow speed descents when leading in order to keep their RPMs under red line. I'm guessing that you have a "climb" prop which would increase the tendency to wind up on the downline as well. I don't compete in aerobatics so I have no need for inverted oil and all but I sure like having the CS prop so I never worry about the RPM. I have a Whirlwind 200RV which is not much heavier that a metal FP.
While we are on the subject. I'm looking for a parachute and would appreciate hearing from others that fly RV-8's. What make/model works best?
Ron Schreck
RV-8, "Miss Izzy"
--> RV-List message posted by: Bob <panamared3(at)brier.net (panamared3(at)brier.net)>
cost $300,000.
pilot.
upside down.
Posted: Thu Nov 02, 2006 7:52 am Post subject: Fuel sensors |
though, how do you manage to keep the >RPMs below red down when you are on
a long downline?
> Ron Schreck
Good questions on the RPM on the downline. One of the major drawbacks of
the RV in acrobatics is the speed build up on the downlines. A comparison
with the purpose built acrobatic One Design: pilots report on the
downline with fixed pitch prop that the drag is so high it is hard to
exceed 180 MPH. In my RV I exceed 180 MPH in straight and level
cruise. So managing RPM is an important task.
I do it by retarding the throttle. I do get criticized severely by the
competition crowd, but then they are not flying RVs. Also the competition
guys and the airshow types often fly way above redline. Some have told me
they are very happy at 3100 RPMs. Of course they also tell me they do an
engine rebuild every year during the off season. If you can not afford a
yearly engine rebuild, and who can, then keep the RPMs close to redline.
A few hints
1. Retard the throttle during downlines, I call this energy
management. Most acrobatic types will tell you energy management is
keeping the speed up, in my case it means keeping the speed down. Conserve
the slow speed. Example, while at cruise speed you want to do a split
S. I do an immelman to reduce the speed below 100 KTS and then do the
Split S and pull out around 140 KTS.
2. Pulling Gs will reduce your speed which in turn will reduce your RPMs.
3. If you do not want to jockey with the throttle during maneuvers, then
you can set your power setting so that 2700 RPMs will equal redline at a
certain speed. I use 160 KTS and 21" MP equals 2700 RPM. As long as I
stay below 160 KTS I am below redline.
Unfortunately on long descents a fixed pitch will not work as well as a
constant speed. Engine people tell me it is bad for the engine to be at
very high RPM (2700) and very low MP (10"). So in decent the best I can do
is about 1500 FPM at 17" MP for a short period of time before I exceed
redline.
The RV is just too fast sometimes. Never thought I would say that. So
when doing acrobatics, speed management is critical, no I should say super
critical. But it can be done, just enter the vertical downlines just above
stall speed and watch your airspeed.
Interestingly the speed difference between my RV and an Extra 300 is not
that much. One thing (not the only thing) that makes the Extra 300 such a
better aerobatic aircraft is that it can pull 10 Gs as compared my 6
Gs. And nothing except impacting with the earth will kill airspeed (or
RPMs) faster that high Gs. Of course impacting with the earth is a
extremely high G maneuver!!?!
chaztuna(at)adelphia.net Guest
Posted: Tue Nov 07, 2006 5:11 am Post subject: Fuel sensors |
Ron,
Good advice. However, I have to take exception with your cost assessment for using fuel injection versus a carburetor. Aircraft Spruce sells the Precision Silverhawk system for $2400. Considering that you can sell your new or overhauled carburetor for $1000 (or more if new), that makes the "difference" only $1400. The ability to run lean of peak with fuel injection will allow you to recoup a savings in future fuel costs.
Charlie Kuss
[quote]David,
Snipped[b]
