		dean.psiropoulos(at)veriz Guest
				 Posted: Sun Oct 22, 2006 8:50 pm    Post subject: EFIS D-10 Question |
				I know this should go to Dynon but I have a question on mounting the remote
 compass module.  The instructions say to mount this module as close to the
 orientation of the D-10 unit as possible. Given that on an RV-6 the
 instrument panel is tilted almost 10 degrees forward, wouldn't it make more
 sense and be more accurate to mount it on the longeron line (which happens
 to be the horizontal line of flight in cruise)?  Why does Dynon say to mount
 the compass at the same angle of tilt?  Have you RV-6 drivers who've used
 the remote Dynon compass mounted it with the tilt?  Thanks.
 Dean Psiropoulos
 RV-6A N197DM
 Wiring and wiring.
		khorton01(at)rogers.com Guest
				 Posted: Mon Oct 23, 2006 3:13 am    Post subject: EFIS D-10 Question |
				On 23 Oct 2006, at 24:47, DEAN PSIROPOULOS wrote:
  <dean.psiropoulos(at)verizon.net>
  the remote
  to the
  make more
  happens
  to mount
  who've used
 The remote compass module works by measuring the components of the
 magnetic field in three dimensions.  Then, they use the aircraft
 attitude to calculate the direction of magnetic north.  The
 calculation that the EFIS does assumes that the remote compass module
 is at the same attitude as the EFIS.  If it is not, the heading
 accuracy will be reduced.
 See: http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1145885596
 Kevin Horton         RV-8 (finishing kit)
 Ottawa, Canada
 http://www.kilohotel.com/rv8
		Jerry Cochran
  Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
				 Posted: Mon Oct 23, 2006 8:18 am    Post subject: EFIS D-10 Question |
				Greetings, Dean...
  I've mounted them on two Rv6a's. One in the tail, but not fun to crawl back  there to secure wires. On the other, I built a shelf just behind the baggage  compartment which was pretty easy. Just used an angle finder to match the panel  angle. At the time I wondered if this method would be accurate enough, but the  D-100 performs flawlessly, so guess it was. BTW, Dynon wants the same  orientation in all 3 axis... Again, easy to do with above method.
  Jerry Cochran
  Wilsonville, OR
   	  | Quote: | 	 		  Time:    09:50:24 PM PST US
 From: "DEAN PSIROPOULOS"    <dean.psiropoulos(at)verizon.net>
 Subject: EFIS D-10    Question
 --> AeroElectric-List message posted by: "DEAN PSIROPOULOS"    <dean.psiropoulos(at)verizon.net>
 Dean    Psiropoulos
 RV-6A N197DM
 Wiring and wiring. |
