dave
Posted: Thu Oct 19, 2006 11:14 am Post subject: Heater Pot scrubbers |
Guys -- this is what you want right here
http://update-international.com/jpg_300x300/ssp-50.html
Most stores carry them .
I use them and they are excellent. You can get 20 to 30 C temp gain in
your cockpit done properly.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dosmythe(at)cox.net Guest
Posted: Thu Oct 19, 2006 12:10 pm Post subject: Heater Pot scrubbers |
Not sure if it would make any difference but I read somewhere about these
scrubbers being used in aircraft fabricated heat muffs. However, it made a
point to use the ones made from Brass (on the same shelf right next to
stainless). I can't remember why they specifically called for Brass except
maybe brass is softer and less likely to wear a hole in the muffler/heat
muff or, maybe it was heat retention?????. For whatever reason, I use the
Brass ones.
Don Smythe
bsmith3163(at)aol.com Guest
Posted: Thu Oct 19, 2006 12:46 pm Post subject: Heater Pot scrubbers |
I don't know about the stainless steel scrubbing pads you have mentioned but
have you ever seen steel wool burn? One spark will ignite it like it was
made out of gasoline. I have carried it before in a survival kit. One good
spark and you can easily start a camp fire. I have heard that it burns so
well because of an oil used in the process of making it. I would test a
piece of what ever you are using just to make sure.
Brian Smith.
Posted: Thu Oct 19, 2006 2:33 pm Post subject: Heater Pot scrubbers |
Brian,
These scrubbing pads are no where near the thin consistency of steel
wool. I understand what you are saying but the products are completely
different.
Don Smythe
Lynn Matteson
Posted: Fri Oct 20, 2006 3:41 am Post subject: Heater Pot scrubbers |
Steel wool will really go off if used to short across a battery's
terminals. Probably best to test this with long jumpers, and not right
across the battery...explosive gasses and all. Those of you who are my
age will probably recall a commercial product that used this principal
to huge success...the photographic flashbulb. They might have used a
magnesium "wool".
Lynn
On Thursday, October 19, 2006, at 04:45 PM, Brian Smith wrote:
mentioned but
was
One good
burns so
a
Brian Smith.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Fri Oct 20, 2006 3:51 am Post subject: Heater Pot scrubbers |
Lynn.
I have a shroud around my muffler and a long door spring maybe 18 or 24"
long hooked on each side of shroud and it falls down inside the shrould but
is used to retain the stainless steel pot scrubbers....... I have close to
200 hours on them now and no issues are all. But i do not have steel wool.
Dave
algate(at)attglobal.net Guest
Posted: Fri Oct 20, 2006 4:33 am Post subject: Heater Pot scrubbers |
Brian
The Stainless steel scrubbers I used were very soft to the touch and are
shredded to quite a large strand size and do not have any tendency to burn.
Dave was the gentleman that actually put me onto this idea and it instantly
raised the temp in my cabin by a significant amount. I had a full winter on
mine with no sign of any abrasion damage.
Gary Algate
Classic4 Jab 2200
Brian Smith.
dave
Posted: Fri Oct 20, 2006 5:05 am Post subject: Heater Pot scrubbers |
Hi Dave
I managed to get a set of Turbulent Aviation skis when I brought the new
plane but I am really interested in wheel skis - especially as I now only
use AV Gas.
Either way, with over 90Ltrs of fuel and a 14 Ltr/Hr burn I have enough fuel
to go about 6-1/2 Hrs so it's not really an issue.
I would love to catch up with you for some ski flying and my friend in
Sudbury ended up getting a Model 4 /582 and he is also an avid winter flyer.
Let me know when you are ready
Gary
Float Flyr
Posted: Sat Oct 21, 2006 7:21 am Post subject: Heater Pot scrubbers |
I used to have a wad of SOS r pads (steel wool) in my emergency kit. That
In a Ziploc r bag and a 9V battery in another Ziploc. The 9V battery
shorted with a small piece of steel wool would start the fire you could use
the ziploc bags to carry berries or worms to fish with.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Sat Oct 21, 2006 7:24 am Post subject: Heater Pot scrubbers |
Iron filings will ignite almost as fast if you get them hot enough. The pot
scrubbers we are discussing are considerably heavier. My mother used to
call them "Curly Qs" they are usually stainless steel so they will last a
good long time. Steel wool will rust.
Noel
[quote] --
Kitfox III-A
Lynn Matteson
Posted: Sat Oct 21, 2006 10:54 am Post subject: Heater Pot scrubbers |
I knew I'd heard of this someplace....I'm just glad I had heard it
somewhere and forgot it, rather than to have actually DONE it and then
forgot it. : )
Lynn
That
could use
Noel
N369LM |
