msm_9949(at)yahoo.com Guest
Posted: Tue Oct 17, 2006 8:01 am Post subject: 582 Idle Speed - WAS PRop Drag |
Noel,
I haven't been able to get my 582's idle speed below about 2400 rpms. I've adjusted the carb slides and throttle cables, rejetted the idle jets (twice), everything that's been suggested. It will go no lower. The only thing I've found that will slow it down further is to apply the choke. I don't do it for very long, not wanting to soot up my plugs, but by making the prop free-wheel, it works very well to stop the floating.
Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | I was advised to set my idle to around 1500 rpm. and to use that speed only to assist in getting the plane back on the ground. Once on the ground speed the idle up to at least 2000 rpm or higher if required to get the engine to run smoothly.
Marco Menezes
Model 2 582 N99KX
Float Flyr
Posted: Wed Oct 18, 2006 5:57 am Post subject: 582 Idle Speed - WAS PRop Drag |
When I pull my throttle all the way out the rpm will go all the way down to 1500. Mind you if that happens while on the ground there will be enough vibration to shake the fillings out of your teeth. That's not good for the engine or the aircraft.
What kind of tachometer do you have??? The electronic "Kitfox tach or one of the newer digital tachs that have no moving parts e.g. Tiny Tach? last year I had a lot of problems with my engine. By the end of the season (floats) I came to the conclusion that there was a problem with my tach. The cheapest most accurate way to tell if I was right was to install a tiny tach. The short story is I was right.
My Kitfox tach was reading 250 rpm high per 1000rpm indicated. e.g. 2000rpm indicated was actually 1500rpm, 6800 rpm (take off max) was actually 5100rpm.. Wonder why I had problems getting into the air and climbing with floats or why I had to shim the hinges in my elevator. ( from idle vibration)
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Thu Oct 19, 2006 8:14 am Post subject: 582 Idle Speed - WAS PRop Drag |
Noel,
I have a cheap analog tach for CDI ignitions purchased from ACS. I put it in after frying the analog Kitfox tach during initial run-ups. (I neglected to install the supplemental resistor in the tach's circuit, per the Rotax SB). I'm sure the current tach reads 200-300 rpm too high at idle. I've checked this with hand-held digital tach. The clutch manufacturer represents that clutch disengages at 2400 rpm. At idle (throttle full back) my tach reads about 2700 rpm, so in reality, it's probably turning just at the threshhold where clutch engages.
I should probably invest in a more accurate tach, but that wouldn't resolve the puzzle of idle speed that won't go below 2400.
[quote] When I pull my throttle all the way out the rpm will go all the way down to 1500. Mind you if that happens while on the ground there will be enough vibration to shake the fillings out of your teeth. That's not good for the engine or the aircraft.
Noel
dave
Posted: Thu Oct 19, 2006 8:36 am Post subject: 582 Idle Speed - WAS PRop Drag |
Marco , I would get a tiny tach. They are accurate and simple to install ( about 1 minute)
I know nothing about cluthes nor do I have any use for one. But With the prop not engaged I think your 582 should easily idle below 2000 and smooth as well.
I would call a Rotax guy like Bob Robertson to get his opinion and order a tiny tach from him. They are cheap and Bob ships overnight.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Thu Oct 19, 2006 11:49 am Post subject: 582 Idle Speed - WAS PRop Drag |
Marco:
I would suggest the first thing to do is to get a more accurate tach. Even if it is only a borrowed optical tach that reads the prop speed. That way you at least will know what ball park you are in.
I am thinking the clutches that engage your clutch are supposed to be set up for 2400rpm but that may be off too. If the springs that disengage the clutch are stretched at all than the clutch could be engaging at too low an engine speed. One thing I can tell you for sure that below 2000+ rpm the engine will run rough as it can. Shortly above 2000rpm the engine will smooth out considerably.
Noel [quote]
Kitfox III-A
Float Flyr
Posted: Thu Oct 19, 2006 11:54 am Post subject: 582 Idle Speed - WAS PRop Drag |
I agree whole heartedly with Dave.... I got my tiny tach from Bob. Probably the best money I've spent.
Noel [quote]
Kitfox III-A
