First flight write up.
sschmidt(at)ussynthetic.c
PostPosted: Tue Oct 17, 2006 11:26 am    Post subject: First flight write up. Reply with quote
Here is the write up I put in Van’s Airforce with a couple shot.
Saturday was a great day all around. The winds were 0-3 knots, 60 degrees OAT, and I didn't sleep one wink that night.
I know everyone says don't have alot of people come to the first flight but that is one rule that I didn't follow. I let everyone know that wanted to know but it was still mostly my family and my wife’s family. There were the usual airport groupies that were hanging around and two of my best friends from work were there too.
I did a preflight on the plane early that morning and then Ray did one too. My friend Mark Patey came up from Spanish Fork airport in his RV-6A to fly chase and we went through the flight on the ground first. I was going to climb out (4230ft airport elevation) to 6500 ft. and orbit the airport below Class B. I wasn't going to touch the power settings until at least 6000 ft. There have been many engines that have quit when people started to pull back RPM's or MP. I was then going to fly 65% to 75% power for at least 20 minutes, then go into some slow flight and get some airspeed numbers. Then back to full power for 10 more minutes and land.
I walked the plane one more time, made sure I had my POH (Thanks Tim) and my notes that I had made and strapped in. I did mount a camera in the plane. My friend’s wife walked into the hanger as I was duct taping the tripod to the floor. I think she thought I was putting in the last few critical pieces. By the way, we will be putting the duct tape on e-bay from the first flight. The video is awesome from inside, can't wait to get it edited so everyone can see it. You can see the camera in the back in some pictures.
My wife took a camera and flew with Mark in the chase aircraft and again some of the formation video turned out great. Because there was really no wind and my hanger is on the south end of the airport we had to make some calls and reverse the pattern. I did not want to taxi my new engine all the way to the other end and everyone was really nice about it. We then both taxied out to the end of 34 and I did my final checks.
So there I was sitting at the end of the runway ready to take off. This is the moment we all think about over and over again after long nights of deburring, riveting, wiring, sanding, painting, troubleshooting, and day dreaming at work. I've always thought that I would get to end of runway, take a big breath and really take it all in. Well, I got out there and I was ready, the plane was ready and I just wanted to fly.
I added one notch of flaps, turn the fuel pump on, checked for the 10th time that the fuel was on and all instruments were set and made the announcement, "OK, here we go!"
The next few moments were very routine thanks to Mike Seager and 410RV. I went up and flew 8.5 hours in 410RV and had 44 landings with Mike. Everything felt identical in this takeoff. The plane accelerated quickly, I pulled the nose off within the first 200 feet and just held it up and we were airborne before the first exit. I am going to go out there someday and measure it because it seemed shorter than 500 ft.
The RPM's were right around 2710 on climb out, I actually pulled them back to 2650 on my down wind and then back to 2500 at 6000 ft.
It was great to have a chase plane there for the 30 minute flight. I didn't have to make any radio calls, I monitored the airport frequency but left it on 123.45 and talked with the ground and with Mark in the chase plane. I was able to focus on the flying and monitoring engine parameters.
During the flight my airspeed seemed to be 5-6 knots slower at 140 knots than Marks RV-6A, and at 100 knots seemed to be around 4-5 knots. My CHT maxed at 410 on climb out and then cooled and stabilized at 385 F with 75% power. My oil temp never went above 185 F. The engine ran flawless (Great job Aerosport).
I made one more upwind leg and started to slow her down to 85 knots for the first notch of flaps. Then I set up for a 78 knot decent and added the second notch (20 degrees). I didn't add full flaps because with only one or two people in the plane you can't trim out all the control forces with 30 degrees of flaps. Even with 50 lbs in the baggage, Mike Seager and I couldn't fully trim out the forces. So I decided during my transition training that 20 degrees would be my setting and it worked perfect.
I was definitely fast on my approach but I had plenty of runway to bleed off speed. I planned on aiming for 1/3 down the runway and a couple extra knots over 76. 76 (90 mph) was the approach speed Mike Seager teaches you. My brother has some great shots of the landing sequence. I'll just include a few.
Once the smoke came off that first wheel it was time to relax and celebrate.
Now I need to fly off another 24 hours and then another 25 of rides but that is the fun part.
I would definitely recommend some transition training for your first flight. When I initially called for insurance they quoted me 10 hours of total RV time with one hour in an RV-10. They apparently are now requiring 10 hours of RV-10 time! I have argued with them that this is going to be impossible for the whole RV-10 community to get but that is what they said. They allowed my training to count but start calling your insurance now and check on that.
Also, having a chase plane was nice to relieve stress and to keep an eye on the outside of the plane.
Scott Schmidt
Product Manager
1260 South 1600 West
Orem, UT 84058
Cell 801-319-3094
Work 801-235-9001
Fax 801-235-9141
sschmidt(at)ussynthetic.com
 Filesize:  69.68 KB
 Viewed:  186 Time(s)
wayne.e(at)grandecom.net
PostPosted: Wed Oct 18, 2006 4:44 am    Post subject: First flight write up. Reply with quote
Scott,
Congratulations on your first flight and for building such a beautiful RV10. You certainly appear to have done a great job and your write up was great.
I know I'm very anxious to be not to far behind you.
Wayne Edgerton #40336
PostPosted: Wed Oct 18, 2006 4:27 pm    Post subject: First flight write up. Reply with quote
People always joke about that last 5% lasting forever but it is so true. It was really nice to get the DAR inspection done and then take a few days to really make sure everything was finished.
I took off three days of work and combined it with a weekend working 16-18 hour days for five days. I couldn’t believe how much we got done in that time.
I’m sitting here in Houston right now knowing that the weather in SLC is perfect and its killing me. I’ve been reading more about the Cheltons and Grand Rapids and can’t wait to play with some of the features this weekend.
Keep plugging away and call or e-mail if you have any questions. Sometimes you just get stuck on something.
Scott Schmidt
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Wednesday, October 18, 2006 6:44 AM
Subject: Re: First flight write up.
Scott,
AV8ORJWC
PostPosted: Wed Oct 18, 2006 6:36 pm    Post subject: First flight write up. Reply with quote
Scott, our hopes and prayers are with you and the gang for a comprehensive “Head to Head” on the Chelton Pair vs. the Grand Rapids Pair after the 25 hour Fly Off.
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Wednesday, October 18, 2006 5:27 PM
Subject: RE: First flight write up.
Scott Schmidt
Scott,
[/b]http://www.matronics.com/Navigator?RV10-List
[/b]
[/b]
[/b][b]
