On-line info on making and using form blocks - the results
craig(at)craigandjean.com
PostPosted: Sun Oct 15, 2006 4:57 pm    Post subject: On-line info on making and using form blocks - the results Reply with quote
Thanks for all the pointers and instruction on making and using form blocks.
The results are attached.
One might ask why I need two luggage shelf bulkheads. Well, the new one on
the left is 5 mm wider than the old factory one on the right. Why 5 mm? That
is long story that begins in 1999...
-- Craig
 Filesize:  44.37 KB
 Viewed:  142 Time(s)
