Trailering The CH701
cwolf41(at)comcast.net
PostPosted: Sat Oct 14, 2006 10:37 am    Post subject: Trailering The CH701 Reply with quote
I'm interested in doing extended trailering of a Zenith 701.
I've been flying for many years, and I'm currently part owner of a Cessna
182. I also own a recreational vehicle which I love to travel in, around
the country. But what I would really enjoy, is an airplane that I could
tow on a trailer behind my RV, stopping and flying wherever the scenery
looks interesting. RVs seem to be towing every other kind of recreational
vehicle, these days, so why not an airplane?
Obviously such an aircraft would have to have folding wings, which is why
I've been looking at the Zenith 701. I took the rudder building workshop
for the 701, and thoroughly enjoyed it. I think I would enjoy building the
701. I also took a ride in the 701, and was quite impressed with its
performance.
I've seen pictures at the Zenith web site of a 701 on trailers. One plane
was even being towed behind an RV, so it looks like I'm not the first guy
to get the idea.
But is the 701 really suited for extensive trailering? That folding wing
design looks like it was more intended to reduce hangar space, rather than
designed for zooming down the highway at 70 mph. Those folding wings
constitute a large, flat surface of metal, high in the air. How much side
gusting of wind could the plane endure before it was damaged, or worse yet,
caused the trailer to flip over?
It's my understanding that the folded wings are only secured by a single
pivot bolt at the front, and slots in a plywood saddle at the back. Is
this really enough to secure the wings for extended highway travel?
I talked to Michael Heintz at Quality Sport Planes, in Cloverdale,
California, last week, while I was taking the rudder building workshop. He
said for extended trailering, the best method would be to remove the wings
entirely, and strap them to the bed of the trailer. Then trailering would
be fine.
Does anyone have any experience with extended trailering of the 701? If
so, I would sure like to talk to you!
I like the 701 very much. However I'm also looking at a Kolb Mark III
Xtra. It seems like Kolb planes get trailered quite a bit, while the 701
does not. Perhaps there is a good reason? The Kolb factory says their
aircraft was designed for folding and trailering, and the folded plane does
seem to look more solid and compact than the 701. I also like the fact
that the Kolb does not use a wet wing, so unlike the Zenith, there is no
need to drain the fuel before folding the wings.
If anyone has any suggestions or advice on this topic, I'd sure appreciate
hearing from you. Thanks!
Chris Wolf
marinegunner(at)gmail.com
PostPosted: Sat Oct 14, 2006 1:55 pm    Post subject: Trailering The CH701 Reply with quote
Chris,
If I were to build a 701 and then take it with me and the RV for extended trips, I would use an enclosed trailer. The wings come off easily and stores under the fuselage on the floor of the trailer without any problem.
Having recently sold a 701 airframe, I know this can be done because the person who bought it drove down with a trailer and took it home. His trailer was not long enough to enclose the entire tail, so he built a special rear door that allowed the tail to stick out when closed - sorta like those extra openings for rudders that you see in hangars designed for really big airplanes. A slightly longer trailer would have allowed him to enclose the entire airplane - and it was very easy to put inside.
Trailering this way would be much safer than any other, not matter what type airplane - that is why they do this with sailplanes.
Have flown both airplanes and enjoy the 701 more than the Kolb - just personal prefrence as both are very good airplanes.
DO NOT ARCHIVE
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned prior to opening/sending and uses an external firewall to help insure virus free email and attachments.
PostPosted: Sat Oct 14, 2006 2:51 pm    Post subject: Trailering The CH701 Reply with quote
On Sat, 14 Oct 2006 14:53:32 -0700, Steve Hulland wrote:
Chris,
Yeah, that's probably the best idea. I figured I could even build a couple
of form-fitting little cubbyholes, lined with carpet, and just slide the
wings in.
I suppose if you're going to trailer the plane on an open trailer, the Kolb
is probably best, since it has a much lower profile, and wouldn't be as
affected by the wind. But as you say, it's probably best to use an
enclosed trailer, no matter what kind of plane you're hauling. Open
trailers just expose the plane to a lot of risks.
It would take less enclosed trailer for the Kolb, since it's just a little
over five feet tall, with the wings folded. The 701 is about 8.5 feet tall
Also, I wouldn't have to drain the fuel from the wings, with the Kolb. But
I do like the 701!
Only problem with an enclosed trailer, is theft. The thieves don't know
what's inside, so they just grab it and run. An acquaintance of mine had
his trailer and plane stolen. He literally ended up in a remote forest, in
the middle of the night, leaving ransom money. He got his stuff back.
I think I'll paint MANURE HAULING, or DEAD ANIMALS REMOVED on the side of
my trailer, in great big letters. Or maybe MORTUARY SERVICE - BODIES
TRANSPORTED.
Clever!
Yeah, I noticed that last week, watching a glider land, and pack up. Off
comes the wings, and everything gets slipped inside a long, skinny trailer.
I have a local, custom trailer company that can make me whatever I need.
Shucks, I was hoping you could help me break the tie! Wink
Thanks for the feedback!
Chris Wolf
PostPosted: Sat Oct 14, 2006 4:39 pm    Post subject: Trailering The CH701 Reply with quote
Chris,
I have an enclosed utility trailer. I lock the safety chains to my vehicle and they are firmly attached (plus lock) to the tounge. I also use another lock as the safety pin that holds the ball hitch lever in the down position. Finally, if on a trip that requires the trailer to be at a motel, etc. I take a tire boot and lock one of the tires. Takes a couple of extra minutes to hook things up, but I have never lost the trailer - or any other.
Also have a small 1/4 ton ex-USMC utility trailer with a pintal hitch. Lock the safety chains, but don't worry about the hitch part - most people do not have a pintel and cannot steal it.
Last resort, if I see them stealing it, I simply shoot. Seems to work well. Ha!
DO Not Archive
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
rstone4(at)hot.rr.com
PostPosted: Sat Oct 14, 2006 5:27 pm    Post subject: Trailering The CH701 Reply with quote
Hay Steve,
When you catch a thief trying to steal your goods, you should use a bow & arrow, cross-bow, or a blowgun w/poison darts, then no one can hear anything when you kill the bastard.
Bob Stone, Harker Heights, Tx
ZodiacXL
PostPosted: Sat Oct 14, 2006 6:12 pm    Post subject: Trailering The CH701 Reply with quote
Yep, the bow and arrow, etc. would work well. Where is Harker Heights, TX? I was in Corpus Christi with my wife from the 3rd until the 9th of this month. Had a great time with a great bunch.
Going to airport after I get off work at 06:00 tomorrow. Hope to get a good bit of work done on the airplane.
DO NOT ARCHIVE
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned prior to opening/sending and uses an external firewall to help insure virus free email and attachments. [quote][b]
PostPosted: Sat Oct 14, 2006 7:18 pm    Post subject: Trailering The CH701 Reply with quote
Steve,
You must be an Ex-Marine because you always sign off with Semper-Fi. Harker Heights is a very small town in Central Texas between Temple and Lampasas, right next to Killeen and US Army Fort Hood.
Bob Stone DO NOT ARCHIVE
ggower_99(at)yahoo.com
PostPosted: Sat Oct 14, 2006 9:26 pm    Post subject: Trailering The CH701 Reply with quote
To trailer the 701 fuselage is better to have the fuselage kind of a "take off" position.
This is with the front wheel raised as little and tied up over a stool type support in the trailer floor and also a tie in the tail hook. Off course with the main gears well tied and movement free.
This way the trailer not need to be too tall.
The wings will be safe in a hamoc type support to the side walls. The hamoc support we made it from strips of carpets (samples from a carpet store) carefully passed betwen the wing and the slats. The wings will be movement free with straps to the wall. the wall will have strips of foam and heavy cloth to protect the wings.
This, of course is a two or three person task, for the volume of the parts, not the weight.
Hope this helps.
Saludos
Gary Gower.
Chris Wolf <cwolf41(at)comcast.net> wrote:[quote] --> Zenith-List message posted by: Chris Wolf
Chris,
wings in.
I do like the 701!
TRANSPORTED.
Clever!
Thanks for Get on board. [url=http://us.rd.yahoo.com/evt=40791/*http://advision.webevents.yahoo.com/mailbeta]You're invited[/url] to try the new Yahoo! Mail. [quote][b]
PostPosted: Sun Oct 15, 2006 5:18 am    Post subject: Trailering The CH701 Reply with quote
Robert,
Nope, not an Ex-Marine as they are only the ones who were discharged under less than honorable conditions. I am a Marine - retired at that. Ha! Attended a reunion of Marines in Corpus Christi Oct 3-9. Attendees included active duty from Cpl to Lt.Gen. and retirees from GySgt - Lt General and Marines who got out with less than 20 from PFC to GySgt. We are a great band of brothers.
On the way to the airport to work on airplane. Have a grand day.
DO NOT ARCHIVE
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
PostPosted: Sun Oct 15, 2006 7:29 am    Post subject: Trailering The CH701 Reply with quote
Steve,
I cannot say I am from a more glorious outfit but very effective anyway. I am retired US Air Force. The only people who get into combat in the USAF today is the officers. The only positions on air crews today that are filled by enlisted is radio operators and load masters. They are on cargo aircraft only. All tactical combat aircraft have an all officer crew. During the second world war the situation was quite different because the bulk of the crew of a B-17 or a B-24 were the gunners. The 8th Air Force conducting bombing operations over German occupied areas of Europe suffered loses of up to 67% until the North American P-51 Mustang became available. After that loses to enemy fighters went down to almost nothing. I went in right after the war in 1946 and have never heard a shot fired except on the rifle range.
Tell me what you are building and how far along you are. I am building a ZodiacXL with the Jabiru 3300 engine and expect to be finished this November or December. I have enclosed a picture.
Bob Stone
 Filesize:  53.72 KB
 Viewed:  305 Time(s)
PostPosted: Sun Oct 15, 2006 12:32 pm    Post subject: Trailering The CH701 Reply with quote
On Sat, 14 Oct 2006 17:39:13 -0700, Steven Hulland wrote:
Chris,
Ha!
DO Not Archive
Good advice. Thanks!
Chris Wolf
PostPosted: Sun Oct 15, 2006 12:35 pm    Post subject: Trailering The CH701 Reply with quote
off" position.
Very clever! Do you happen to know how tall the fuselage is, in this
"takeoff" position?
Sounds like a good system.
not the weight.
Hope this helps.
Saludos
Gary Gower.
Very helpful. Thanks!
Chris Wolf
daveaustin2(at)can.rogers
PostPosted: Sun Oct 15, 2006 12:58 pm    Post subject: Trailering The CH701 Reply with quote
Of course, with the aircraft in the takeoff position, at hiway speed there
will be no weight on the trailer or its' wheels so it will tow rather
easily..
Dave Austin 601HDS - 912, Spitfire Mk VIII
jnjkimbell(at)HOTMAIL.COM
PostPosted: Sun Oct 15, 2006 3:20 pm    Post subject: Trailering The CH701 Reply with quote
Chris, 3 months ago I trailered my ch 701 on a trailer behind my Motorhome
from FL to CA and Back, so I have do have experience and knowledge of your
desire. I would rather not discuss this on the list as I do not like to be
ridiculed or put down. Please contact me by telephone or at my email
jnjkimbell(at)hotmail.com
PostPosted: Sun Oct 15, 2006 7:09 pm    Post subject: Trailering The CH701 Reply with quote
Robert,
CH 600. It will be ready to fly in a few weeks. I have the registration and am finishing a re-paint on instrument panel before scheduling the DAR. Hope to fly in Nov/Dec. Will send pictures to everyone soon.
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
PostPosted: Sun Oct 15, 2006 7:11 pm    Post subject: Trailering The CH701 Reply with quote
Hello Chris,
Dont remeber right now how tall was... But with the propeller in a "Y" position, the rudder was just a little higher than the propeller. A almost "normal" height enclosed trailer can be made.
Saludos
Gary Gower
do not archive.
off" position.
"takeoff" position?
not the weight.
Hope this helps.
Saludos
Gary Gower.
Chris Wolf
PostPosted: Mon Oct 16, 2006 10:32 am    Post subject: Trailering The CH701 Reply with quote
On Sun, 15 Oct 2006 20:11:24 -0700 (PDT), Gary Gower wrote:
Hello Chris,
Saludos
Gary Gower
Sounds like a good system, Gary. Thanks!
Chris Wolf
