Glueing the foam ribs into the trim tabs of the elevator
Mike Whisky
PostPosted: Mon Oct 09, 2006 12:54 am    Post subject: Glueing the foam ribs into the trim tabs of the elevator Reply with quote
Hello,
so far I used tank sealant to glue the foam ribs into the elevator. Since I always need to order the small portion from Van's (no known vendor available in Switzerland) I wonder I anyone used a product which is also available in Europe. Would Scotch-Weld work to and if yes which product number of Scotch-Weld?
Thansk for your help.
Michael
empennage / elevator trims
http://www.wellenzohn.net
RV-10 builder (flying)
#511
zackrv8
PostPosted: Mon Oct 09, 2006 2:40 pm    Post subject: Re: Glueing the foam ribs into the trim tabs of the elevator Reply with quote
Michael,
This is exactly what I used on my foam blocks. 2216 is the part number. Great stuff!
Zack
quote="Michael Wellenzohn"]Hello,
Michael
http://www.wellenzohn.net[/quote]
 Filesize:  3.34 KB
 Viewed:  2069 Time(s)
RV8 #80125
RV10 # 40512
