rv8striker(at)hotmail.com Guest
Posted: Fri Oct 06, 2006 5:51 am Post subject: Heatset woes |
List,
I finally took the plunge and bought the Thirty 3G Lightspeeds. The day after they arrived I used them in the corporate jet that I fly. They worked beautifully and because the jet has Bose headsets, I was able to do a back to back comparison, which BTW, seemed to be about even on all points. Anyway, here's the problem. When I use the Lightspeeds in my RV-8, I get a squeal in the interphone when the volume is turned up past a point where I can hear the back seater. If the volume is low enough, it goes away but so does my ability to hear my passenger. I don't think it's feedback. It sounds more like it's related to the VOX threshold. Once the threshold is crossed and the volume is too high, it squeals. Turn the volume down, the VOX clips off and the squeal stops. If I put the LS's in the rear and my "cheapos" in the front, the LS's work fine. I tried the Bose in the RV and they work beautifully in the front or rear. Until now (60 hours) my two cheepos have worked fine.
I've talked to the techs a LS and they have no idea. They seem to think it's my airplane...but why does brand "B" (and my cheepos) work in my plane and theirs does not?
I also talked to the guys in the avionics shop at work. They think it could be a mismatch between the LS's (stereo) and my cheepos. (mono)
My next step is to try two stereo sets and see if that's the problem but in the meantime any ideas from you guys would be appreciated.
Steve Struyk
St. Charles MO
RV-8 60 Hours
Posted: Fri Oct 06, 2006 6:04 am Post subject: Heatset woes |
Steve, since it appears from your post that you are just listening as you crank up the volume to get the squeal, alternately unplug the mic from the pilot then passenger and see if the squeal goes away. A very sensitive mic can (and will) pick up the sound in the headset ..... nand viola .... feedback. I may be blowing smoke here as it's a WAG, but try it anyway. Another excuse to take someone flying!!! Cure can be as simple as a second foam cover on the mic.
Linn
Steve Struyk wrote:
[quote] List,
Steve Struyk
St. Charles MO
RV-8 60 Hours
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Fri Oct 06, 2006 6:48 am Post subject: Heatset woes |
Linn
Steve Struyk wrote:
[quote] List,
Steve Struyk
St. Charles MO
RV-8 60 Hours
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
ronlee(at)pcisys.net Guest
Posted: Fri Oct 06, 2006 7:28 am Post subject: Heatset woes |
| Quote: | Verify that your headset jacks are proper for the headset. Are there
three prongs to match the three sections of a stereo headset. Not sure
how this works but worth checking.
Ron Lee
mail(at)cleavelandtool.co Guest
Posted: Wed Oct 11, 2006 12:27 pm Post subject: Heatset woes |
On this subject has anyone found a good "no headband" headset for the RVs?
I don't have much headroom in the RV4 so I bought a Panther headset that
uses custom earmolds. The headset fits perfect and is Sooo comfortable, on
the ground it works great, but above 1500rpm and the mic feeds all the noise
to the intercom and radio. The earmolds block out as much noise as our
Telex ANR and Bose ANR, but since the mic is useless I need another
solution. I have been fighting with it since May and just today sent it
back again this time with a recording of different headsets vs. theirs. I
expect I will be getting a refund and will try something else. I was
impressed with the ClarityAloft headset at Oshkosh, but it was not in an
aircraft. I would have been impressed with the Panther on the ground. Any
advise would be appreciated.
Mike
Mike Lauritsen
Cleaveland Aircraft Tool
mike(at)cleavelandtool.com
www.cleavelandtool.com
bartrim(at)gmail.com Guest
Posted: Wed Oct 11, 2006 2:17 pm Post subject: Heatset woes |
I'm really happy with my Aurricom set. The only complaint I can think of is that during the test phase (experimental engine... little bit of tweaking) I was in & out often and hands would get a little dirty and soon you would have an ear piece that you really didn't want to put back in your ear. Fortunatly they come with spare foam ear-pieces. Custom earmolds are also an option, but I've not found that I needed them. I must admit that I was a new pilot at the time, so didn't have any bias toward conventional headsets as I'd only had a few hours using them.
Todd Bartrim
C-FSTB
Turbo13B RV9
On 10/11/06, Cleaveland Aircraft Tool <mail(at)cleavelandtool.com (mail(at)cleavelandtool.com)> wrote:[quote]--> RV-List message posted by: "Cleaveland Aircraft Tool" < mail(at)cleavelandtool.com (mail(at)cleavelandtool.com)>
Mike
Mike Lauritsen
mike(at)cleavelandtool.com (mike(at)cleavelandtool.com)
john(at)fureychrysler.com Guest
Posted: Wed Oct 11, 2006 4:01 pm Post subject: Heatset woes |
I like my Clarity, takes more time to get on and sometimes bothers my ears. Pressure changes from altitude can also be a slight anoyance. The mic and sound quality are the best I've ever seen. My Bose X is easier to put on and about the same noise cancelling but heavier and messes up the little bit of hair that I have. Both have their + & - and either make a great choice.
John
2 RV6A
RV7 in process
hansconser(at)gmail.com Guest
Posted: Wed Oct 11, 2006 4:58 pm Post subject: Heatset woes |
On Oct 11, 2006, at 6:03 PM, John Furey wrote:
| Quote: | I like my Clarity, takes more time to get on and sometimes bothers my
I bought a $700 pair of Telex's the Stratus 50D's, they had a hiss.
Sent those back got the Bose, which are pretty good, but don't have
enough passive attentuation in my opinion, they let more high
frequencies through than they should.
Hans
RV Dreaming
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Wed Oct 11, 2006 9:27 pm Post subject: Heatset woes |
Has anyone an opinion about the new X11 Headset that David Clark now offers?
Jim in Kelowna
_________________ "I never make mistreaks" |
denis.walsh(at)comcast.ne Guest
Posted: Thu Oct 12, 2006 5:27 am Post subject: Heatset woes |
I chose Peltor because of the thin headband top. I have been
satisfied with it.
Denis Walsh
On Oct 11, 2006, at 07:27 5207400010, Cleaveland Aircraft Tool wrote:
<mail(at)cleavelandtool.com>
the RVs? I don't have much headroom in the RV4 so I bought a
Panther headset that uses custom earmolds. The headset fits
perfect and is Sooo comfortable, on the ground it works great, but
above 1500rpm and the mic feeds all the noise to the intercom and
radio. The earmolds block out as much noise as our Telex ANR and
Bose ANR, but since the mic is useless I need another solution. I
have been fighting with it since May and just today sent it back
I expect I will be getting a refund and will try something else. I
was impressed with the ClarityAloft headset at Oshkosh, but it was
not in an aircraft. I would have been impressed with the Panther
on the ground. Any advise would be appreciated.
Mike
Mike Lauritsen
