rjdaugh
Posted: Thu Oct 05, 2006 2:22 pm Post subject: Fuel System Rotax 912UL(to Howard) |
Rotating the wrong way (more than about half a prop turn) will pump the oil
backwards into the oil tank, while drawing air from the crankcase into the
oil pump. This causes the oil pump to lose prime. Then it is possible for
the engine to run without oil pressure which can damage the engine.
There are procedures that Rotax published to prime the oil pump every time
you change the oil.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
