LarryRosen
Posted: Wed Oct 04, 2006 6:12 pm Post subject: Load Analysis & Electrical Schematic |
I have posted on my web site the electrical schematic and load analysis
that I am considering. The electrical design is a single battery, dual
alternator design. Comment if you would.
<http://lrosen.nerv10.com/Electic/index.html>
Thanks to all who have before for a great load analysis layout for the .
Larry Rosen
RV-10 #356
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
bob.kaufmann(at)cox.net Guest
Posted: Wed Oct 04, 2006 6:33 pm Post subject: Load Analysis & Electrical Schematic |
I would consider a dual battery instead of a dual alternator.
Bob K
All I know about electricity is that the paddles tingle after the juice goes
into them.
armywrights(at)adelphia.n Guest
Posted: Wed Oct 04, 2006 8:01 pm Post subject: Load Analysis & Electrical Schematic |
Really? I guess as Bob N. says, your design goals must be the deciding
factor on your decision.
Either option is viable. And even though the U.S. Army doesn't get it right
all the time, they've opted for a single battery, dual alternator design in
their single-engine helicopters. Of course, the option for the 2d battery
is there, but that's usually left for cold-soaked aircraft needing the amps
to start in the middle of the night with no ground power units available.
Now if you plan on a hangared plane where you can hook up a ground power
cable if it's too cold, you may want to choose the single battery/dual
alternator setup. Then you don't have to immediately start the 30 minute
"my-battery-is-going-dead" clock if your only alternator fails that powers
your glass panel.
I'm sure there are some more nice battery/alternator wars in the
aeroelectric list archives that go into choices due to weight, c.g., spare
engine pads, etc. in addition to original design goals.
Rob Wright
#392
Fuse
GenGrumpy(at)aol.com Guest
Posted: Thu Oct 05, 2006 6:01 pm Post subject: Load Analysis & Electrical Schematic |
In a message dated 10/5/2006 2:01:04 AM Central Standard Time, armywrights(at)adelphia.net writes:
| Quote: | --> RV10-List message posted by: "Rob Wright" <armywrights(at)adelphia.net>
your glass panel.
Rob Wright
#392
Fuse |
For what it's worth, I chose to use both dual alternators, dual batteries 2 busses (I can connect the 2 if needed). Just now into ground runs before first flight, and I am happy that I decided to go this way - redundancy for intended IFR flight.
Grumpy #40404
DO NOT ARCHIVE
