pete.howell(at)gecko-grou Guest
Posted: Mon Oct 02, 2006 5:20 am Post subject: Facet Pump Failure |
I had my pump fail after 45 seconds of fuel flow test (just
installed) - does anyone have an address or phone # for the mfg. I'd
like to call to see if they have seen this before or want to analyze
the unit.
Pete
finn.lassen(at)verizon.ne Guest
Posted: Mon Oct 02, 2006 6:02 am Post subject: Facet Pump Failure |
First I'd recommend you inspect it for foreign object stuck in it
preventing the piston from moving.
Finn
Pete Howell wrote:
the unit.
Pete
FLYaDIVE(at)aol.com Guest
Posted: Mon Oct 02, 2006 3:52 pm Post subject: Facet Pump Failure |
In a message dated 10/2/2006 9:22:22 AM Eastern Standard Time, pete.howell(at)gecko-group.com writes:
| Quote: | I had my pump fail after 45 seconds of fuel flow test (just
the unit.
Pete |
Pete:
I have repaired about 3 pumps that have failed. In all three cases it was debris that jammed the piston.
One side of the pump unscrews and the unit comes apart. DON'T LOOSE THE PIECES when taking it apart.
Barry
"Chop'd Liver"
inverteddecathlon(at)hotm Guest
Posted: Mon Oct 02, 2006 4:27 pm Post subject: Facet Pump Failure |
The Facet pump is very sensitive to dirt and requires a fuel filter between
the tank and the pump.
Also, they are made to push the fuel, not pull it. They will burn up from
running dry.
Craig
| Quote: | From: FLYaDIVE(at)aol.com
Reply-To: rv-list(at)matronics.com
Subject: Re: Facet Pump Failure
Date: Mon, 2 Oct 2006 19:51:45 EDT
the unit.
Pete
Pete:
Barry
"Chop'd Liver"
jmsears(at)adelphia.net Guest
Posted: Tue Oct 03, 2006 3:19 am Post subject: Facet Pump Failure |
I guess this thread concerns the little square Facet pump that Van pushes.
I sounds like it's a touchy little critter that I'd not want in my airplane.
I have one of the cylindrical Facets, like those found in the ACS catalog.
It's worked quite well in about 400 hours of flying. The one I had in my
Grumman-American Cheetah had never been replaced. The Cheetah had about
fifteen hundred hours on it, when I sold it. This unit has a screen inside
to catch dirt, a magnet on the bottom to catch metal, and a removable bottom
that allows one to inspect it. It may be a good alternative for the ones
who are having problems with the little square pump. You'd have to do some
plumbing work to install it, though. Those not at the point of installing
the pump may look at these as an alternative. Get the anti-syphon version.
There is one that fits well with our lines; but, I don't think ACS has it.
One of the contributors told us about it, a long time ago. It's in the
archives. With the ACS version, one has to downsize to a smaller nipple
size at the pump. No big deal; but, the other pump would be better.
Oh, yeah. I have my fuel pump mounted on the engine side of the firewall.
I didn't like the idea of having one in the cockpit with me. At annual
time, it's easier to get to for inspection while I'm looking at the engine
and lines.
Jim Sears in KY
RV-6A N198JS (Scooter)
RV-7A #70317 (Very slowly working on the fuse)
EAA Tech Counselor
ebundy(at)speedyquick.net Guest
Posted: Tue Oct 03, 2006 5:25 am Post subject: Facet Pump Failure |
I really don't think I'd label the Facet pump as touchy. That thing is in
thousands of airplanes and the only time anyone is likely to post is when
they have a problem with it. I would guess that most everyone else that
hasn't posted is probably doing fine. I have 750+ hours on mine with no
trouble whatsoever. FWIW, it's cheap, simple, and it works.
Ed Bundy
Gary.A.Sobek
Posted: Tue Oct 03, 2006 5:46 am Post subject: Facet Pump Failure |
My little square Facet Pump is the one recommended by Van and is mounted in
the cockpit where Van recommends it. It has worked PERFECT since day one 9
years ago and 1,953 flying hours. Paul Rosales has almost 2,500 hours on
his and he has worked perfect also.
Gary A. Sobek
1,953 + Flying Hours So. CA, USA
----Original Message Follows----
To: <rv-list(at)matronics.com>
Date: Tue, 3 Oct 2006 07:15:51 -0400
I guess this thread concerns the little square Facet pump that Van pushes. I
sounds like it's a touchy little critter that I'd not want in my airplane. I
Oh, yeah. I have my fuel pump mounted on the engine side of the firewall. I
didn't like the idea of having one in the cockpit with me. At annual time,
it's easier to get to for inspection while I'm looking at the engine and
lines.
Jim Sears in KY
EAA Tech Counselor
sbuc(at)hiwaay.net Guest
Posted: Tue Oct 03, 2006 6:05 am Post subject: Facet Pump Failure |
Ed Bundy wrote:
And....the Facet pump is a backup pump. What are the odds of the
engine-driven fuel pump and the Facet failing at the same time?
Sam Buchanan (RV-6 Classic with 780 hrs on the original Facet pump)
joelhaynes
Posted: Tue Oct 03, 2006 8:48 am Post subject: Facet Pump Failure |
Regarding the comment that Facet pumps require a filter between the fuel tanks and the pump to prevent debris from jamming the pump, I have Van's standard carbureted fuel system setup in which the only "filter" I have between the pump and the tanks is Van's fuel pickups with screens on the ends. Are some people using an additional filter in the fuel system? My pump has performed well for 50+ hours (not continuous operation) even though I occasionally see a small amount of fine debris in my tanks when I test for water.
Joel Haynes
RV-7A
N557XW
51 hours
Bozeman
Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more.
Bill Schlatterer
Posted: Tue Oct 03, 2006 7:27 pm Post subject: Facet Pump Failure |
So not having looked inside one, if the piston jams on junk, will it still flow fuel if the mechanical pump is working ? In other words, does it fail in a safe mode ?
Thanks Bill S
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FLYaDIVE(at)aol.com
Sent: Monday, October 02, 2006 6:52 PM
the unit.
Pete |
Pete:
Barry
"Chop'd Liver"
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
href="http://wiki.matronics.com">http://wiki.matronics.com
Vanremog(at)aol.com Guest
Posted: Tue Oct 03, 2006 10:42 pm Post subject: Facet Pump Failure |
In a message dated 10/3/2006 6:49:24 A.M. Pacific Daylight Time, rv6_flyer(at)hotmail.com writes:
| Quote: | My little square Facet Pump is the one recommended by Van and is mounted in
811 hrs same pump (carbureted in my case) mounted all standard per Van's instructions yadda yadda also perfectamundo. Let's not re-engineer this area, folks.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 811hrs, Silicon Valley, CA)
richard.b.zeidman(at)boei Guest
Posted: Wed Oct 04, 2006 3:20 am Post subject: Facet pump failure |
I don't want to cause a fuel pump panic, but I, unfortunately, was one
who had a facet pump failure at about 800 hours. It hadn't been sounding
normal for a few hours and should have been replaced. During it's last
flight, I toggled the pump switch and the engine shut off. I tested it
in a lab later and found it to be intermitant below 13.5 volts and would
start dithering instead of pumping. Why it didn't allow fuel throuh it,
I canot explain.
PS My new RV has a cylindrical pump installed.
Rich
N42RZ RV6A
N42PZ RV7
jjessen
Posted: Wed Oct 04, 2006 8:02 am Post subject: Facet pump failure |
Who makes the cylindrical pump? Are you flying with it, yet?
John Jessen
#40328
Posted: Thu Oct 05, 2006 8:04 am Post subject: Facet pump failure |
In a message dated 10/4/2006 4:21:59 A.M. Pacific Daylight Time, richard.b.zeidman(at)boeing.com writes:
| Quote: | I don't want to cause a fuel pump panic, but I, unfortunately, was one
in a lab later and found it to be intermittent below 13.5 volts and would
start dithering instead of pumping. Why it didn't allow fuel through it,
I cannot explain.
It would help us all a little to know which pump you had fail (FI high pressure or Carb low pressure).
Posted: Thu Oct 05, 2006 3:41 pm Post subject: Facet pump failure |
In a message dated 10/5/06 12:06:36 PM Eastern Daylight Time,
Vanremog(at)aol.com writes:
| Quote: | Why it didn't allow fuel through it,
I cannot explain.
I think you should take it apart.
It comes apart very easy, just one bog nut. Problems I found were debris
clogging and jamming the piston.
I sure would like to know what you found.
Barry
"Chop'd Liver"
Posted: Fri Oct 06, 2006 3:43 am Post subject: Facet pump failure |
It was the low pressure Facet pump from Vans catalog. It did give me
some warning that I didn't heed. Along with not sounding quite right,
the day prior to the in flight failure, after flying around for awhile,
I stopped for fuel and could not get any fuel pressure on restart.
Thinking I had a vapor lock in my engine pump, I let the engine cool for
20 minutes and then flew home without any problems. The next day,
(5/11/05) I added a blast tube to the engine pump and flew around to
warm up the engine to see if I could get it to repeat the prior day's
event. During that flight is when I toggled the electric pump, shutting
off the engine.
Pump failure may be rare, but it does happen.
Rich
RV6A N42RZ
RV7 N42PZ
time: 09:04:04 AM PST US
Subject: Re: Facet pump failure
sounding
would
it,
I cannot explain.
Posted: Fri Oct 06, 2006 11:49 pm Post subject: Facet Pump Failure |
In a message dated 10/4/2006 2:44:23 AM Eastern Standard Time, Vanremog(at)aol.com writes:
| Quote: | 811 hrs same pump (carbureted in my case) mounted all standard per Van's instructions yadda yadda also perfectamundo. Let's not re-engineer this area, folks.
ONLY that the little square thing should have a filter on the intake side. As I said before, I repaired three pumps due to debris jamming the piston. Other than that they work fine.
Barry
"Chop'd Liver"
Posted: Fri Oct 06, 2006 11:57 pm Post subject: Facet Pump Failure |
In a message dated 10/3/2006 11:29:42 PM Eastern Standard Time, billschlatterer(at)sbcglobal.net writes:
| Quote: | So not having looked inside one, if the piston jams on junk, will it still flow fuel if the mechanical pump is working ? In other words, does it fail in a safe mode ?
Thanks Bill S
Bill:
It all depends on what you consider the safe? Yes, it will pass fuel. Will it pass fuel in a high enough quantity for a take off, or when switching from a dry tank, or when the throttle is fire-walled? I don't think so! And I don't want to take the chance.
I know it will NOT pass fuel from a DRY PRIME START.
The cure is simply install a filter on BOTH feeds from the wing before it hits the pump. The round Facet Pumps have a filter built into the bottom.
Van's did a great job designing our planes, GREAT, not PERFECT! And we are here to help. I point out the use of a pop-rivet for the static port. Now how many have used that method?
Barry
"Chop'd Liver"
Posted: Sat Oct 07, 2006 6:46 am Post subject: Facet Pump Failure |
FLYaDIVE(at)aol.com wrote:
| Quote: | It all depends on what you consider the safe? Yes, it will pass fuel. Will
How many have used pop rivets for the static ports? I suspect it would
be close to 90% of all flying RV's. And the pop rivet port is more
accurate than the alternate, "properly engineered" ports.
The little square Facet pump does indeed appear to be sorta rinky-dink
for our highly engineered, garage-built airplanes, and it sounds awful.
But the thing has a great field history in hundreds and hundreds of
aircraft. There have obviously been isolated failures, but that is the
case with nearly every component on our planes. If a builder decides to
replace the pump with something more "appropriate", so be it, just be
sure safety issues aren't being introduced by tampering with a proven
design. By the way, the Facet pump on my plane was able to produce fuel
flow from a "dry prime". The same was true of the two Facet pumps I have
in automotive applications. The pump certainly has a limit as to how
high a column of fuel it can pull, but it seems in our RV application
there is sufficient head pressure, at least with ample fuel in the tank,
for the pump to self-prime.
If debris large enough to repeatedly clog the Facet was in my fuel
system, I would open up the tanks and find out where it was coming from!
I have the optional Vans fuel pickups with the screens, and that is as
fine a filter as I want near the fuel tank. Usually, filters are very
coarse near the fuel pickup, then get finer the closer you get to the
carb. The gascolator is fine enough to pick up any particles large
enough to clog carb jets, and the only stuff I have found in the
gascolator screen in nearly 800 hrs was a few tiny black specks when the
plane was new.
A couple of years ago I purchased two glass automotive filters that I
intended to put in the wing roots and then remove the gascolator.
But....I chickened out after reconsidering why I would mess with a fuel
system that had been flawless for hundreds of hours on my RV, and
countless thousands of hours on other planes.
I certainly don't want to discourage anyone from exploring ways to
improve the RV breed, but it is probably good for new builders to be
very wary of changing critical flight systems without considering the
proven track record of planes that have been in service for a long time.
Sam Buchanan (1999 RV-6 Classic, 784 hrs)
EAA Tech Counselor
http://thervjournal.com
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sat Oct 07, 2006 9:23 am Post subject: Facet Pump Failure |
I'm coming to this thread late so forgive me. I also don't really know
diddly, yet, about engines as I don't have one. I installed an Airflow HP
fuel pump because a lot of builders who I've been getting advice from did
(same rason I bought a TATCO hand squeezer so you'd think I'd learn, eh?)
When you talk about filtering both wings....do you mean separately? As
in,...two filters? As you may know the AF doesn't do that either.
I'm also still kickng around whether I should put a Gasoclator on my RV.
Some people say you don't need one with an AF pump, others say "why not?"
And for those with the AF pump, how do you service that filter without
having fuel spilling all over the the floor and carpet.
Apologies in advance if these sound stupid. I blame my parents for that. (g)
Do not archive.
[quote] --
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
