Backup Power supply for GNS-430?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
olechap(at)comcast.net
PostPosted: Mon Oct 02, 2006 2:14 pm    Post subject: Backup Power supply for GNS-430? Reply with quote
Hey guys,
I posted this question to a Yahoo forum and someone suggested I post it here as well. For those in both forums, sorry for repeats!
I would like to know if anyone out there has wired up a home-made
backup power supply (rechargable/UPS variety) that, in my case, would
feed something like a GNS-430? I prefer not spending an arm/leg on a
COTS (commercial off-the-shelf) rig. Actually, let me tell you what I
want to do and maybe there's a simpler solution... please read on.
I want to be able to fire up Com & GPS prior to engine start in order
to talk to the tower, get my clearance and program in the
routing/waypoints. However, I am afraid of start-up spikes in the
system, so I'd prefer to either cut the power to it or IDEALLY I'd
isolate the 430 to its own battery momentarily so it can stay alive
and be ready to roll.
Hopefully some of you guys can relate and chime in:
1. Is it a long shutdown/recycle process for the 430?
2. Should I not worry about the startup spike and keep it on?
3. Is there a startup procedure that will minimize any power
fluctuations (ie. waiting to turn on the alternator field until engine
stabilizes)
4. Are there any special filters that I can use (I'm thinking no)
5. Wiring diagrams available / small rechargeable battery availability?
6. If I put it on a manual isolate switch, might I see enough of a
spike/voltage drop during switching to trip the 430?
7. Is COTS the only way to go?
Apologies for the lengthy email. Thoughts and comments will be much
appreciated!
-Andy
RV-7, Finish
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Gilles.Thesee(at)ac-greno
PostPosted: Mon Oct 02, 2006 2:27 pm    Post subject: Backup Power supply for GNS-430? Reply with quote
Andrew,
I installed a Garmin Series 400 in our four seater project.
Why not just switch your master switch on ?
Just do what you want, and then start your engine. You afraid of
start-up spikes ? Fear not, no one ever caught one with a scope or so.
Hangar tales. Besides, modern avionics is totally immune to any
transient the on-board circuit may throw at it.
Still not convinced ? Turn off your radios before start-up, that's all.
Why would you need your GPS during engine startup and pretaxi checks.
Be careful with the "avionics master" some are still fond of : if the
switch fails, you loose all your avionics. That's a single point failure.
I usually turn the radios on just after startup.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
trigo(at)mail.telepac.pt
PostPosted: Mon Oct 02, 2006 2:54 pm    Post subject: Backup Power supply for GNS-430? Reply with quote
Hi Andrew
Good questions, to which I would like to know the answers as well.
Have you posted this in the AeroElectric list?
Carlos
Float Flyr
PostPosted: Mon Oct 02, 2006 5:27 pm    Post subject: Backup Power supply for GNS-430? Reply with quote
As far as I know starting spikes are always reverse voltage caused when disengaging the starter. Most radios and even the power distribution systems of larger turbine starter/generators have a healthy diode installed to shunt reverse voltage away from avionics equipment. This shouldn't be necessary on your RV7 unless you have been busy shoe horning a turbine in it. You can check your schematic for a reverse polarity diode where the positive terminal enters a unit. With such a diode installed any reverse voltage will be grounded. One thing to be careful about these diodes is if you wire your unit with reverse polarity it will cause a big spark without damaging sensitive components. Most units wired in this way have the diode in the circuit after a fuse. Wire it up in reverse and you will have to replace the fuse.
In smaller piston engines where the starter and charging system are separate the battery itself should be able to filter out a pretty big spike, forward or reverse. The only thing I would avoid is trying to transmit and start the engine at the same time...not much chance of that happening.
Noel [quote]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
flyboy.bob(at)gmail.com
PostPosted: Mon Oct 02, 2006 5:36 pm    Post subject: Backup Power supply for GNS-430? Reply with quote
Andy,
I plan to add a second smaller battery to support my 430, BMA Lite,
Engine Monitor and Elec AH . . . more for backup in the air but could
and probably will be used the way you suggest. In IFR Conditions it
will be isolated from the other battery in VFR I'll probably cross
connect putting them in parallel.
Good Luck,
RV-8 Finishing Slowly!
On 10/2/06, Andrew Olech <olechap(at)comcast.net> wrote:
Hey guys,
stabilizes)
appreciated!
-Andy
RV-7,
Finish
- The Avionics-List Email Forum -
Navigator to browse
page,
Photoshare, and much much more:
- NEW MATRONICS WEB FORUMS -
the Web Forums!
http://forums.matronics.com
- NEW MATRONICS LIST WIKI -
Wiki!
http://wiki.matronics.com
- List Contribution Web Site -
Float Flyr
PostPosted: Mon Oct 02, 2006 6:25 pm    Post subject: Backup Power supply for GNS-430? Reply with quote
Item 6.
Even better you could put a forward diode in the positive line to your GNS and then wire the second (stay alive) battery in parallel to the first that way if voltage from the main battery dropped below 12V. on start-up the second battery would keep the voltage up to the GNS 430 during starting.
I'll attach a little thumb nail drawing. BTW this set up will keep the stay alive 12v battery charged while in normal operation. Both batteries would absorb forward spikes. I would suggest a small 12V gel pac cell or a battery pack of 9 or ten NiMh AAA batteries in series.
There is a very slight voltage drop across the diode but not enough for the GNS 430 to notice it. just choose a diode to handle the current of the GNS. You'll be surprised how small these diodes are. For safety put a piece of heat shrink over the diode and its leads
Noel [quote]
 Filesize:  34.93 KB
 Viewed:  889 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
