Continental 0-200 EGT CHT
s.c.richards(at)homecall.
PostPosted: Sun Oct 01, 2006 2:00 am    Post subject: Continental 0-200 EGT CHT Reply with quote
Hi list
  do you have the max CHT & EGT recomended by manufacturer for the Continental 0-200 as we have now fitted gauges, only had oil temperature before. Any one flying with a 0-200 what are you getting ?
Clive Richards
For Ray Lasniers G CBDG
agustafson(at)chartermi.n
PostPosted: Sun Oct 01, 2006 5:14 am    Post subject: Continental 0-200 EGT CHT Reply with quote
The Continental manual states
CHT max 525
Oil temp max 225
" " desired 150-200
no info on EGT do not archive
Aaron Gustafson
nick(at)aoaircrafters.com
PostPosted: Sun Oct 01, 2006 11:12 am    Post subject: Continental 0-200 EGT CHT Reply with quote
Clive,
I looked up the Continental 0-200-A (Do you have the A model?) Type
certificate data sheets from www.faa.gov. It at least has max CHT
temps.
Please see attachment.
~nick
[quote] ------
0-200-A_TCDS.pdf
 Filename:  0-200-A_TCDS.pdf
 Filesize:  13.78 KB
 Downloaded:  4291 Time(s)
