dcw(at)dddirectories.com Guest
Posted: Thu Sep 28, 2006 5:12 am Post subject: Graphics body wrap! |
I am considering having a custom graphics designed and installed on my
Kitfox. The industry calls this a body wrap. Many vehicles can be seen with
complete body wraps. It doesn't hurt the paint on an automobile and can be
replaced as needed or removed. Can anyone think of a reason I should not do
this or anyway this could possibly damage my plane or affect it's
performance.
Michel
Posted: Thu Sep 28, 2006 5:44 am Post subject: Graphics body wrap! |
| Quote: | From: David C. Watterson [dcw(at)dddirectories.com]
performance.
I can't think of any, David. We already use a few decalcs like the callsign, etc. I even have a tiny Norwegian flag on my tail. They are, usually, very easy to remove with a heat gun. But, please, send us a photo when it is finished. We like to see nice and creative body work.
Michel
flier(at)sbcglobal.net Guest
Posted: Thu Sep 28, 2006 12:41 pm Post subject: Graphics body wrap! |
Flutter. No way I would do it on the wings or tail without testing.
ddsyverson(at)comcast.net Guest
Posted: Thu Sep 28, 2006 1:54 pm Post subject: Graphics body wrap! |
David,
I can't claim to have any experience with this on airplanes, (I will say I am
a car nut and there is some transfer of technology from cars to planes) but
my advice is to rephrase the question: Rather than thinking of any reason not
to do it, think about if there is any real compelling reason to do it. I know
we are experimental types, but this is a pretty big experiment.
My concerns would start with the potential for the stuff delaminating, then
getting tangled up in something important, which is just about anything on an
airplane (static port, lift struts, tailfeathers, etc) I hate to think about
the stuff bridging the horizontal stabilizer and stabilizer strut. One of the
big differences between cars and airplanes is that very few things attached
to the skin of a car affect the ability to operate - quite different with an
airplane.
There might be a difference between a few sticker decals for an N number and a
really big sheet of material.
If I were doing extensive graphics, I would personally choose to use paints to
get the job done.
Just a thought - As I said, I don't really know much about this material, but
I would really, really want to know I could avoid killing myself before
trying something like this.
Sincerely,
Dave S
St Paul, MN
M-7 Trigear
On Thursday 28 September 2006 8:12 am, David C. Watterson wrote:
<dcw(at)dddirectories.com>
lcfitt(at)sbcglobal.net Guest
Posted: Thu Sep 28, 2006 3:42 pm Post subject: Graphics body wrap! |
Hi, David.
I have a stripe down the fuselage side of my IV done with vinyl. I know
there are several grades, but suspect what you are looking at is of the
better type.
Regarding delamination. I doubt it would be a problem as far as a
catastrophic failure is concerned. What you might find is a subtle peeling
back at the leading edge. I just checked mine and there is no evidence of
any separation and it has been on the airplane for eight years and 800 hours
and the leading edge of the tape is unprotected, i.e. begins on the flat
surface of the door.
Incidentally, with my video camera set-up I have used 3M vinyl tape quite a
bit to hold on some fairings between the camera and the fuselage on the lift
strut and have had no peeling at the leading edge so far. I do replace it
from time to time, though.
As a side note, when California tightened up its VOC requirements, United
Airlines at their San Francisco maintainance facility expermented with what
they called decals as a substitute for the paint after their paint facility
was shut down. The "decals" were actually laser cut vinyl adhesive sheets.
I don't know the result of that experiment, but they didn't seem to be
initially concerned at close to 600 mph. My guess is that rather than
concern over control problems, they would be concerned about cosmetics and
cost. In other words, if they came off - serious negative image issues and
replacing them frequently = money wasted.
Lowell
dan(at)azshowersolutions. Guest
Posted: Thu Sep 28, 2006 4:23 pm Post subject: Graphics body wrap! |
David,
I talked to a guy that does the body wraping and specifically asked him if he thought it would work (stay put) on a fabric airplane. He had never done it, but his indications were iffy. My little voice told me it may not be a good idea. Dave S. gave some good things to consider.
Dan B.
314DW / building
Dave and Diane <ddsyverson(at)comcast.net> wrote:
[quote]--> Kitfox-List message posted by: Dave and Diane
David,
airplane.
get the job done.
I would really, really want to know I could avoid killing myself [quote][b]
jimmieblackwell(at)sbcglo Guest
Posted: Thu Sep 28, 2006 5:29 pm Post subject: Graphics body wrap! |
A friend of mine has it on the fuselage of his Model IV with about 600 hours. No problems.
Lowell Fitt <lcfitt(at)sbcglobal.net> wrote: [quote]--> Kitfox-List message posted by: "Lowell Fitt"
Hi, David.
better type.
Lowell
Guy Buchanan
Posted: Thu Sep 28, 2006 5:59 pm Post subject: Graphics body wrap! |
At 05:22 PM 9/28/2006, you wrote:
| Quote: | I talked to a guy that does the body wraping and specifically asked him if
Dan B.
My EAA Flight Advisor just finished an RV-7 with fairly extensive graphics
applied via vinyl adhesives. I doubt you'll have any problem with it on a
Kitfox, but you'll want to do the usual testing before-hand with pieces in
various places that might be a problem. Watch the weight, be careful of
heat, and be careful of flutter. (Since our only balanced surfaces are the
ailerons you'll want to re-balance after installation. All other control
surfaces should be fine.)
I certainly hope you have something outrageous in mind. I'm looking forward
to it.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
brodg(at)texas.net Guest
Posted: Fri Sep 29, 2006 4:08 am Post subject: Graphics body wrap! |
Yep, and no 'flutter' issues ! ;o)
FLIER(at)sbcglobal.net Guest
Posted: Fri Sep 29, 2006 5:51 am Post subject: Graphics body wrap! |
Hey Folks,
Installing some cut vinyl graphics is a lot different
from the overall body wraps used on vehicles which
typically covers most everything.
Flutter is insidious, can occur at any speed, and can
occur on any surface including the fuselage. I saw a
comment about the flaperons being the only balanced
surface. The wings, the horiz & vert stab as well as
rudder & elevator are all surfaces that can
experience flutter.
If you can peel a body wrap off a vehicle without
damaging paint then the graphics can peel off an
airfoil surface and create flutter. Lifting of
fabric off plywood wings killed a very experienced
homebuilder...
There's no problem using cut vinyl on most surfaces
but again I'd be very careful trying to cover the
entire aircraft with a wrap.
Ted
--- Original Message ---
Subject: Re: Graphics body wrap!
| Quote: | Yep, and no 'flutter' issues ! ;o)
dave
Posted: Fri Sep 29, 2006 6:06 am Post subject: Graphics body wrap! |
I think sticks ons are pretty safe.
The Adhesives nowadays are prolly stronger that the poly fobre glues in
some cases.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
av8rps(at)tznet.com Guest
Posted: Fri Sep 29, 2006 10:02 am Post subject: Graphics body wrap! |
Hey Gang,
I agree with Dave. The glues used on the tape are quite good.
I have a large vinyl cut graphic of a girl in a bikini on an island
(really!) on the tail of my Lake amphibian now for 10 + years with no signs
of peeling. And the prop blast is only 3 or 4 feet from it (being that it
is a pusher), as well as the huge amount of water spray it endures. Also,
a
friend of mine has an Avid Flyer that has vinyl graphics (large ones) on
the
fuselage, tail, and wings. It has been probably 5 years and 300 hours of
flying conditions (winter, summer, spring, and fall - skis, wheels, floats)
with no problem. Another friend has done three (going on four now) Just
aircraft co. Highlanders, each of them having large graphics on the
fuselage
and the floats. No problem there either, and we flew two of them from
Wisconsin to Florida and back, along with a couple 1,000 mile trips thrown
in. I also have a set of fibreglass floats with graphics on them that are
at least 5 yrs of heavy water use, and left outside. No problems with that
either. Granted, fibreglass and metal are different than fabric. But from
what I can tell the fabric holds the stripes just as well.
I personally think if you make sure a professional tape stripe installer
does the work it will stay on without issue.
Here's a pic of what the graphic on the tail looks like today (with a bonus
picture for all of you guys that don't understand why I like seaplanes so
much.....) <GRIN>
Paul Seehafer
107.55 KB |
458 Time(s) |
220.03 KB |
417 Time(s) |
Posted: Fri Sep 29, 2006 11:13 am Post subject: Graphics body wrap! |
I am dumping the wheels and making mine a sea plane!!
Jimmie
Paul Seehafer <av8rps(at)tznet.com> wrote:
[quote]Hey Gang,
a
the
fuselage
much.....)
Paul Seehafer
Guy Buchanan
Posted: Fri Sep 29, 2006 6:03 pm Post subject: Graphics body wrap! |
At 11:43 AM 9/29/2006, you wrote:
| Quote: | Here is a photo of my sailboat taken three years ago.
I like Paul's decal a lot better. Michel, maybe you could apply Santa's
helper...
Guy Buchanan
Deceased K-IV 1200
Guy Buchanan
At 10:59 AM 9/29/2006, you wrote:
| Quote: | Here's a pic of what the graphic on the tail looks like today (with a bonus
much.....) <GRIN>
They're your daughters, right? <GD&R>
Guy Buchanan
Deceased K-IV 1200
Float Flyr
Posted: Fri Sep 29, 2006 6:23 pm Post subject: Graphics body wrap! |
Weight... for a full body wrap
I have a small plastic graphic installed on the tail of my plane for the past two years... No cracks,rips or tears. Installing a full body wrap on a cloth plane could be fun though. The chemicals used to remove it may not be good to the dope system you are using let alone the cloth. Try a small piece of the wrap material on a sample of cloth doped to a small frame to see how it applies and removes. While applying the graphic any small bubbles can be taken care of with the judicious use of a small diameter sewing needle.
Just for the Halibut, I'm including a small pic of my graphic and one of it on the plane.
BTW I'm so far down in the woods in Newfoundland I have to come out to hunt. I found a company that does auto graphics about an hour away. Companies that do street banners or shop graphics should also be able to help you.
Noel
[quote] --
43.61 KB |
476 Time(s) |
60.57 KB |
531 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri Sep 29, 2006 6:31 pm Post subject: Graphics body wrap! |
Hey Paul!
How come you didn't say your Lake came with hot running women??? Now the
important question does your 'Fox get the same attention???
Now I'm convinced I'm doing something wrong!
Noel
[quote] --
Kitfox III-A
Posted: Sat Sep 30, 2006 4:39 am Post subject: Graphics body wrap! |
Hi Noel,
Didn't you know a good looking, exotic looking seaplane will attract good
looking, exotic looking women? <smirk>
Does my Kitfox get the same amount of attention? Hmmmmmmm........
Honestly, no. But women in general sure do think it is "cute". I'm not so
sure I like that whole cute thing, but anything is better than nothing.
Here's a picture of my "cute" Model IV at our annual Eagle River Seaplane
Fly In during the poker run (we fly 6-8 lakes) we had 3 weeks ago.
Incidently, my little Kitfox IV had no trouble whatsoever keeping up with
Husky Amphibs in the group. The Kitfox makes for one nice seaplane!
Oh yeah, that is my buddies Highlander in the foreground. If anyone is
interested that airplane is up for sale. (68K on floats, and 58K on
wheels). It was a Sun-N-Fun Grand Champion, plus Oshkosh Seaplane award
winner. Very nice airplane.
Paul
Hey Paul!
Noel
483.43 KB |
505 Time(s) |
Guy Buchanan
Posted: Sat Sep 30, 2006 4:54 am Post subject: Graphics body wrap! |
At 07:21 PM 9/29/2006, you wrote:
| Quote: | Just for the Halibut, I'm including a small pic of my graphic and one of
it on the plane.
Noel,
You're going to have to explain that one. "Beothuck"?
Guy Buchanan
Deceased K-IV 1200
smokey_bear_40220(at)yaho Guest
Posted: Sat Sep 30, 2006 7:57 am Post subject: Graphics body wrap! |
Didn't the older SS demo aircraft with the "wild paint
jobs" actually use wraps?
I wrapped my lift strut fairings this way rather than
painting, but I wrapped completely around with no
edges to the front, except for some patches at the
joints, etc. Works well past 150 mph. Don't ask how
I know that though.
Kurt S. S-5/NSI turbo
