brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Jan 23, 2006 6:34 am Post subject: Yak 52 r/h gear failure |
Mark Jefferies YAK Uk wrote:
| Quote: | We (world wide) are permitted to operate these experimental a/c
(remember the wording “This a/c is not certificated to an international
standard”) and its our responsibility to operate as safely as possible
or suffer the consequences of tightened CASA, FAA, CAA etc regulations
not to mention litigation.
So what productive can come from all of this? We can stand around and
rant, implore, castigate, and otherwise make nuisances of ourselves to
our neighbors.
Instead, how about:
1. What are the recommended IRAN intervals for Yak and CJ?
2. Who is offering service to IRAN the actuators in a timely fashion in
different parts of the world?
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
pa3arw(at)euronet.nl Guest
Posted: Mon Jan 23, 2006 6:36 am Post subject: Yak 52 r/h gear failure |
Gus,
Mark is right of course, lifed items should be replaced.
On the other hand though: in the previous Sovjet Union maintenance programs
for aircraft were in first instance not set up for the sake of the aircraft,
i.e. technically required, but for the sake of employment, i.e. keeping
everybody at work......
On our Yak (RA3326K previous a.k.a LY-AQC) we do replace lifed items
according to the book though....
Hans O.
-----Oorspronkelijk bericht-----
Van: owner-yak-list-server(at)matronics.com
[mailto:owner-yak-list-server(at)matronics.com] Namens Fraser, Gus
Verzonden: maandag 23 januari 2006 15:01
Aan: 'yak-list(at)matronics.com'
Onderwerp: RE: Re: Yak 52 r/h gear failure
Mark raises what is almost the single most serious point with ongoing
maintenance of these aircraft, regardless of country of origin. That is the
issue of lifed items.
Now how many of you out there are riding around fat dumb and stupid with
seals over 5 years old, fuel lines that have exceeded useful life. These
aircraft have a considerable list of items that need to be changed on spec,
how many of you are doing that ?
Mark can you post a list of lifed items for Yak aircraft as I think it will
shock some subscribers. As Mark mentions it will not take long for insurance
companies to see this as an out if you don't get this stuff replaced. But as
always it is up to you if you know about it and choose to avoid it don't
complain when the insurance company says bye bye.
Personally I think this is probably the biggest safety risk to the US fleet
right now and I am sure that we will see a few more issue sin this space in
the future. As far as fuel lines go, for example, it cost very little to
have them replaced, a lot more than the cost and pain associated with an in
flight fire.
I would urge you to also look at the information that Mark put together
about Yak 52 bulletins at http://www.yakuk.com/MPD.asp
Gus
gus.fraser(at)gs.com Guest
Posted: Mon Jan 23, 2006 6:56 am Post subject: Yak 52 r/h gear failure |
I agree,
If it is in 6 years as opposed to 5, given a good hanger environment etc
etc, is it going to fail ? Probably not but there are aircraft operating in
the US that have been out of overhaul for getting on for 10 years, how many
of those have had all the required preventative maintenance ?
As far as this stuff goes spread the love, do one oleo this year, another
next year and so on. Otherwise the sticker shock of doing it all at once
will really hurt.
Gus
brian
Posted: Mon Jan 23, 2006 7:20 am Post subject: Yak 52 r/h gear failure |
I am amazed at just how reliable the pneumatic systems are as they
operate in a very hostile environment. High pressure air with moisture
in it is a very corrosive medium for steel. I would expect problems with
check valves, shuttle valves, and actuators on a pretty regular basis.
Air tool oil will help but not solve the problem.
Frankly, I would be uncomfortable with a 15-year-old aircraft with only
30 hours on it. I doubt that the pneumatic system was purged with dry
nitrogen in that time. You don't have gear and flap cycles to ensure
that the air-tool oil is redistributed on the walls of the actuators.
OTOH, it may be in the middle of the desert with little or no moisture
in the air.
So I come back to my previous question: what should the IRAN interval be
on pneumatic components?
Mike Bell
Posted: Mon Jan 23, 2006 8:35 am Post subject: Re: Yak 52 r/h gear failure |
Jill at M-14P ("Carl Hays & Co.") does a great job on Yak-52 actuator overhaul. The turnaround is fast and it's done for just slightly more than the cost of the parts. The uplock actuators are pretty easy to do yourself if they only need seals, but the gear actuators are trickier. My 1993 Yak had been maintained by some name-brand Yak shops and never had the actuators or hoses touched. There was plenty of rust in some of them. Jill fixed the whole lot including the check valves. The worst part is the job to get them in and out, but it's only every 5 years, and look at the uplock actuators annually. It's cheap insurance.
_________________ Mike Bell
Elk Grove, CA
avbell2(at)comcastdotnet |
Posted: Mon Jan 23, 2006 8:53 am Post subject: Yak 52 r/h gear failure |
Here is Marks list of lifed items
http://www.yakuk.com/lifeitems.asp
Gus
Posted: Mon Jan 23, 2006 8:56 am Post subject: Yak 52 r/h gear failure |
I would second that. I think that it was Jill who posted the best method for
inspecting the seals. With the aircraft jacked disconnect the lower
connection of the actuator and unscrew it with the top still connected to
the aircraft. That way you don't have to get up into the wing quite as much
which is a very sucky thing to have to do.
Gus
Yakmech
Joined: 19 Jan 2006 Posts: 6 Location: Melbourne Australia
Posted: Mon Jan 23, 2006 12:31 pm Post subject: Re: Yak 52 r/h gear failure |
Hi Gus,
Once again I have looked at this site and others since the incident. They are a wealth of information I agree.
The only problem is that once again these are all bulletins etc relevant to the aircraft in that country, Issued by that country. I know the aeroplane does not change when it goes over seas but these bulletins etc are not released here, so unless we look elsewhere or are told about it in some form or another, how are we supposed know. Further if the bulletins are not put out by our relevant authority then we have no requirement to carry them out.... Crazy but true and further as I have already stated we dont know about them. Unfortunately its not my job to keep up to date with what the world are doing with there aircraft i can only be guided by what the local authroity has to say. The authorities here are supposed to look at the relevant information being supplied world wide and issue directives here if they feel its relevant, and most of this information would have to come from the manufacturers of the aircraft.
One can only do what one only knows about. !!!
_________________ Once you have experienced flight you will forever walk this earth with your eyes turned skyward for it is there that you have been and there that you long to return ! |
brian
Posted: Mon Jan 23, 2006 1:21 pm Post subject: Yak 52 r/h gear failure |
Yakmech wrote:
| Quote: | The authorities here
aircraft.
I don't know about you but I wouldn't trust the FAA here in the US to
provide me with accurate data about anything. With few exceptions they
don't seem to be able to tell their empenage from their armpit. (Well,
they do seem to get the charts right but I think that may be NOAA and
not the FAA.)
Seems it might make sense to set up a conduit to get the information
another way.
Valkyre1(at)comcast.net Guest
Posted: Tue Jan 24, 2006 8:38 am Post subject: Yak 52 r/h gear failure |
Mick,
As a retired Airline pilot with 34 years of flying experience behind me so far, I can only laud your generous courage and concern in sharing this experience with us. "There are those who have, and those who will" as the old saying goes.
In your case, it will probably never be known how many of us you may have saved from having a similar or worse experience, simply by making us double check. In reality, we all think "Thank you God, that could have been me." Unless we're someone willing to test the theorem of "Pride goeth before a fall."
I've not had an accident, but I did let our airline push my crew and I well beyond our required crew rest years ago, and was later pretty angry at myself for letting it happen. It's amazing what you let happen when they wear you down until you're too tired to know that you're too tired to think straight.
At the time, many airlines were doing this by juggling numbers, printing ridiculously false projected and arrival and departure times to conform with the letter of the law to get us to go legally, then changing them after the fact.
To make a long story short, we had lots of weather delays and were already past our 16 hour duty day. Dispatch kept telling us to keep going. I kept refusing, they kept assigning us new flights and calling us at the hotel throughout the rest of the night/morning.( We didn't even get to the hotel until 03:00 and had to find it ourselves).
I didn't know that they had also begun calling my F/O and flight engineer as well. This wore them down enough to get them to agree to leave for an 11am flight that same day, just to get some rest when we finally got to New York through Chicago.
This was technically legal by FAA standards, but broke our contract and the laws of good sense. I'll just have to leave myself open to criticism here, because to put in all of the dreary details would take too long.
My belabored point in all of this being, I wrote an article on this entitled "Sometimes the Good Guys Wear the Black Hats". In other words, "Please Guys, don't let yourselves be talked into doing what I did just because you're too exhausted and harassed to know better. Take the phone off the hook, piss people off, and say "NO" in the interest of safety.
My Union balked at a story where a pilot admitted making a mistake and others were concerned that I would be criticized. I was willing to take that risk for the greater good by holding up my less than stellar decision so that others wouldn't have to repeat it.
Oddly enough, I didn't get criticism, just about thirty letters from fellow pilots saying that they had found themselves in similar situations and made a better decision because my article had "given them permission" to do so. As a side benefit, my airlines "Pilot Pushing" policies were changed, and News Services became an interested party in stopping this practice as well. (This was just after Americans tragic accident at Little Rock, where crew fatigue, pilot pushing, and extended duty period was a factor.)
Again Mick, thank you for sharing and I hope that your example leads to more of the same. That's one of the best things about the "List". We all arm-chair quarterback, and try to pick the situation apart to evaluate it. But it's usually nothing personal and "You Had'da be there."
Fraternally - Val (O.K. Guys, my turn to duck and run for cover.)
L39parts(at)hotmail.com Guest
Posted: Wed Jan 25, 2006 1:45 pm Post subject: Yak 52 r/h gear failure |
Air Speed indicator?
In the long list of things that wreak havok when they fail on an airplane, I
don't personally see how an airspeed indicator made it to number 3 on your
list. I'll conceed that it's not as bad as an air bottle blowing up or a
prop disintegrating, but there are several hundred parts I think I need more
than an A/S indicator to safely get back to terra firma.
Posted: Wed Jan 25, 2006 2:20 pm Post subject: Yak 52 r/h gear failure |
Don't comment one way or the other just reporting what the Russians say.
Gus
brian
Posted: Thu Jan 26, 2006 7:38 am Post subject: Yak 52 r/h gear failure |
Ron Davis wrote:
airplane, I don't personally see how an airspeed indicator made it to
number 3 on your list. I'll conceed that it's not as bad as an air
bottle blowing up or a prop disintegrating, but there are several
hundred parts I think I need more than an A/S indicator to safely get
I agree with you. It is the old "pitch plus power equals performance"
thing. If you know the power setting that yields a particular
performance, you are going to be there whether or not you use the ASI. I
teach my students to find out what power settings are correct for
various configurations and then the airspeed just falls into place. It
also lowers workload.
Other than a quick glance to make sure I am at gear and flap speed, I
know I really don't use the ASI much in the pattern.
But I did use my AoA a LOT when I had it. I probably need to figure out
how I am going to get one in the Project.
