Motor Mount
zackrv8
PostPosted: Fri Sep 22, 2006 2:15 pm    Post subject: Motor Mount Reply with quote
Guys,
Anybody else have this problem?
I pinned the motor mount onto the firewall today. With the top 2 motor mount holes up flush against the firewall, the bottom 2 outboard holes are about a 3/16 of an inch from the firewall. This is because the 2 bottom inboard mounting holes of the motor mount won't allow the 2 outboard mounts to sit flush.
What did you guys do about it? Send it back? Make shims? Just pulled it tight with the bolts? Reweld it?
I'm inclined to make shims. I don't want undue stress on the mount by pulling it tight with the bolts.
Zack
RV8 #80125
RV10 # 40512
rene(at)felker.com
PostPosted: Fri Sep 22, 2006 2:30 pm    Post subject: Motor Mount Reply with quote
I do not remember having that problem. If I remember right mine all sat
pretty flat.
Rene' Felker
40322
Finish
N423CF
acs(at)acspropeller.com.a
PostPosted: Fri Sep 22, 2006 2:41 pm    Post subject: Motor Mount Reply with quote
Zack, my concerns were more to do with the alignment of the outer holes
being up to half a hole out, but found when I began to pull the bolts up it
easily stretched and moved into place, well below any torque value required
on the nuts. You'll find some information in the archives reporting the fact
that there seems to be a bit of twist in some frames.
John 40315
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of zackrv8
Sent: Saturday, 23 September 2006 8:15 AM
Subject: Motor Mount
Guys,
to sit flush.
Zack
RV8 #80125
RV10 # 40512
http://forums.matronics.com/viewtopic.php?p=63295#63295
dlm46007(at)cox.net
PostPosted: Sun Sep 24, 2006 12:54 pm    Post subject: Motor Mount Reply with quote
Just drilled up the motor mount this morning; another possible gotcha is the
top two pilot holes on the QB (#8 Mar/2005) fuselage were about .050
different in distances from the outboard edge. When we drilled the right top
pilot hole the left top was almost out of the mount hole. After pinning the
other four holes with rivet sets which fit the 3/16" on one end 3/8" on the
other and 3/16" bolts we were able to flex the mount on the top left hole to
use as a drill bushing for an off center drilling of the pilot hole. Also
its best to test fit the motor mount (section 47) before riveting the front
deck (section 41) as the access for cleaning and deburring the mount holes
inside is much easier.
