n616tb(at)btsapps.com Guest
Posted: Sat Sep 23, 2006 4:12 pm Post subject: Vision Microsystems - oil pressure problem |
Hi Listers,
I have a Vision Microsystems VM-1000 installed in my RV-6. I have no oil pressure reading as it just flashes 0’s. I pulled the connector and checked the pins and location but don’t see a problem. The sender is mounted on the firewall with an aero quip hose up to it. VM is apparently NOT available for calls or support. Any ideas on what I can check? Thanks
RV -6
rv8(at)lazy8.net Guest
Posted: Sun Sep 24, 2006 6:18 am Post subject: Vision Microsystems - oil pressure problem |
If you keep after them, and leave phone messages, they will answer you eventually. They are in the midst of a move from Oregon to Texas.
Meanwhile, check to see if you have 5 volts from the red wire to the black wire at the transducer.
If you get desperate, I can send you an old transducer that works, it just reads wrong, and you can check your wires with it.
John
Tim Bryan wrote: [quote] <![endif]--> <![endif]-->
Hi Listers,
RV -6
Vanremog(at)aol.com Guest
Posted: Sun Sep 24, 2006 6:40 pm Post subject: Vision Microsystems - oil pressure problem |
In a message dated 9/24/2006 1:34:59 P.M. Pacific Daylight Time, chasb(at)satx.rr.com writes:
| Quote: | If you have the VM-1000 Installation/User Manual, Section 5 is a
Trouble Shooting Guide. Page 88 give specific readings to check out
the oil pressure indicating system. If you don't have the manual,
contact me back channel and I'll send you a copy of the appropriate
page.
My experience may give you pause to consider what can happen in an intermittent piece of cable. This it the only explanation I was able to come up with my fuel pressure (carbureted) sender indications from day one until I changed the cable (remade it with all new materials).
From the first flights until about 6 months ago I had variations in my pressure indications that ran the gamut from zero to 9 psi at various times and then would settle down for months only to recur at odd times. I discussed with VMI and they told me that there is no way the sender or the conditioning and/or display driver circuits in the DPU could behave this way. Before my last trip to Sedona I finally gave up, rebuilt it and spent an hour on my back under the panel stripping out the old one and reconnecting the new one.
It has been working well ever since.
What I believe happens is that the cable VMI buys is the wonderfully high quality (he said facetiously) stuff that comes from overseas. It is constructed of individual primaries that get shielded and jacketed as a grouping. I suspect that when the cable making machine senses that one of the individual wires has reached the end of the spool, it stops and notifies the operator to manually load a new spool. The operator (making the equivalent of 5 cents a day) strips back some insulation on the free ends and twists them together. He hits go and the machine continues making more high quality cable and no one is the wiser.
The shipping guy tests the spool (if they test at all) and there is continuity on all wires. We're good to go off to the USA and fly in the instrumentation circuit of an aircraft.
Imagine an only slightly less motivated operator that doesn't strip the wires and a manufacturer that laid off the test function to cut costs. Good wire and cable is worth the money.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 809hrs, Silicon Valley, CA)
