cazw(at)ihug.co.nz Guest
Posted: Sat Sep 23, 2006 1:40 am Post subject: Windscreen frame |
Listers
Having trouble matching the screen frame to the canopy (slider) frame. After careful measuring and ensuring correct positioning and alignment of mounting points etc it would appear that my screen frame is distorted. I am not talking about a slight bend here, it appears as though one side of the frame has been cut too long before the mounting plate was welded in place. The result is that one side sits about 0.5 inch higher than the other. Has anyone else had this problem? Is there a fix for this, or is it something I will just have to work around? All suggestions gratefully received.
Clive Whittfield
New Zealand
RV6 - fuselage well on the way
tcervin(at)valkyrie.net Guest
Posted: Sat Sep 23, 2006 5:54 am Post subject: Windscreen frame |
Cliff, The slider frame will have a tube on each side in the lower front to accept your track wheels. On my frame each side was quite a bit longer than needed and can be shortened.
A 1/2 inch should be no problem to accomplish but I wouldn't do this until all the other fitting points seem to be coming into spec. I trimmed these tubes a little at a time until the overall fit came right in.
Tom in Ohio (RV6-A)
Posted: Sat Sep 23, 2006 11:14 am Post subject: Windscreen frame |
Thanks Tom. Yes I understand the need to adjust the height of the canopy frame to suit, and using spacers under the canopy where needed etc. It just appears that the screen frame (roll bar) is the culprit here. I have sat it upright on a dead flat bench and measured the heights at various points. When comparing one side to the other, this is where that 0.5 inch difference shows up. Even my mark one eyeball tells me it looks like the frame has been 'pushed to one side'. The support bar mount is still centred tho' so I'm pretty sure any attempts to simply heat and bend would cause other problems. This looks like it would need cutting, reshaping and welding. Do all RV6 roll bars have this degree of variation in their shape, or am I worrying about nothing and should I simply ignore and adjust/ shim canopy to suit?
Clive in NZ
Subject: Re: Windscreen frame From: Tom & Cathy Ervin (tcervin(at)valkyrie.net ([email]tcervin(at)valkyrie.net?subject=Re:%20Windscreen%20frame&replyto=008f01c6df17$975c2c80(at)your4dacd0ea75[/email])) Date: [b]Sat Sep 23 - 6:54 AM[/b] [quote] | Quote: | Cliff, The slider frame will have a tube on each side in the lower front
in.
Tom in Ohio (RV6-A)
| [b]
Posted: Sat Sep 23, 2006 4:03 pm Post subject: Windscreen frame |
Clive, Mine fit pretty well but I have heard of people pulling in the sides.....fit was too wide. Shimming the canopy and-or combinations of both.
Tom in Ohio
n616tb(at)btsapps.com Guest
Posted: Sat Sep 23, 2006 4:09 pm Post subject: Windscreen frame |
I would discuss this live with Van’s. If it is irregular beyond their QC maybe they will just send you another one.
RV-6 Would be flying tomorrow if my address change didn’t put a kink in my airworthiness application. Dang!
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Clive Whittfield
Sent: Saturday, September 23, 2006 12:10 PM
To: rv-list(at)matronics.com
Clive in NZ
Subject:
Date:
Sat Sep 23 - 6:54 AM | Quote: | | Quote: | | Cliff, The slider frame will have a tube on each side in the lower front to accept your track wheels. On my frame each side was quite a bit longer than needed and can be shortened. A 1/2 inch should be no problem to accomplish but I wouldn't do this until all the other fitting points seem to be coming into spec. I trimmed these tubes a little at a time until the overall fit came right in. Tom in Ohio (RV6-A) | to accept your track wheels. On my frame each side was quite a bit | 0 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 1 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 2 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 3 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 4 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 5 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 6 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 7 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 8 | Quote: | | to accept your track wheels. On my frame each side was quite a bit | 9 | Quote: | | longer than needed and can be shortened. | 0 | Quote: | | longer than needed and can be shortened. | 1 | Quote: | | longer than needed and can be shortened. | 2 | Quote: | | longer than needed and can be shortened. | 3 | Quote: | | longer than needed and can be shortened. | 4 | Quote: | | longer than needed and can be shortened. | 5 | Quote: | | longer than needed and can be shortened. | 6 | Quote: | | longer than needed and can be shortened. | 7 | Quote: | | longer than needed and can be shortened. | 8 | Quote: | | longer than needed and can be shortened. | 9 | Quote: | | A 1/2 inch should be no problem to accomplish but I wouldn't do | 0 | Quote: | | A 1/2 inch should be no problem to accomplish but I wouldn't do | 1 | Quote: | | A 1/2 inch should be no problem to accomplish but I wouldn't do | 2 | Quote: | | A 1/2 inch should be no problem to accomplish but I wouldn't do | 3
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sat Sep 23, 2006 4:32 pm Post subject: Windscreen frame |
Clive,
Vans response to these type of questions is usually to 'just make it
fit'. This is easy to say for someone who has the skills and experience.
It may also be something for which they would consider replacing the
part. You should call.
Do you have the canopy frame installed yet?
I am about to install my own RV-6 canopy and I intend to get the canopy
frame fitted to the fuselage shape before I worry about the roll bar.
Right now I can see I will need to do a lot of work to get it within the
1/16" to 1/8" as called out on SC-2.
For both parts I fully expect to have my welder make some 'adjustments'.
Some local builders have needed to add a small section of tube to the
frame, yours is the first roll bar I have heard that may need some
serious adjustment. Just be certain the change is exactly what you want
before getting the work done.
I'm sure you could make it fit the way it is, but judging from your
comments this may not be the right solution for you.
Having said all that, by eyeball my roll bar looks pretty right in width
and symmetry. Famous last words.
Doug Gray (in OZ)
On Sun, 2006-09-24 at 07:10 +1200, Clive Whittfield wrote:
| Quote: | Thanks Tom. Yes I understand the need to adjust the height of the
canopy to suit?
Clive in NZ
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Sep 23, 2006 7:47 pm Post subject: Windscreen frame |
In a message dated 09/23/2006 4:28:58 PM Central Daylight Time, cazw(at)ihug.co.nz writes:
| Quote: | | Do all RV6 roll bars have this degree of variation in their shape, or am I worrying about nothing and should I simply ignore and adjust/ shim canopy to suit? |
Hi Clive- You might best leave the monster rollbar as is and make the frame match it, since re-bending the smaller tubes will result in less hernias and insanity. These frames will typically have to be beat, bashed, stomped, cussed at, hootchie-cood and occasionally sweet-talked into shape. As a matter of fact, I spent the better part of yesterday doing all of the above on a -7. Fear not, there is help a mouse-click away. Take a look at Mike Schipper's excellent description of how he wrestled his frame into submission:
http://www.my9a.com/finish6.asp
I've seen other descriptions, but this seems typical- an archive search will expose many horror stories and a great deal of help...
From The Possumworks in TN (USA)
Mark Phillips http://websites.expercraft.com/n51pw/[url=http://www.my9a.com/finish6.asp][/url]
_________________ From The PossumWorks... |
