Dennis Jones
Joined: 17 Sep 2006 Posts: 45 Location: Poplar Grove, IL
charlieray(at)optonline.n Guest
Posted: Wed Sep 20, 2006 6:36 pm Post subject: Switched power |
Dennis,
If you are powering your encoder right from a fuse from the bus (to reduce
warm up time) the switched power pin out of the transponder will be left
empty. 8 and 14 are tied together on multi voltage encoders.... the old
convention was 28 volts on pin 8 and 14 on pin 14....
Run your fused encoder power to pin 14 and leave pin 8 empty, run no other
power wires from the transponder swithced power.
I just read this message after i sent the previous. I still want to know
exactly shich encoder and transponder you are using. I could draw you up a
schematic and fax it to you.
Let me know.
Dennis Jones
Posted: Wed Sep 20, 2006 10:57 pm Post subject: Switched power |
Charles
The transponder is the Terra 250D and the encoder is the Terra 3000.
Dennis
Quoting Charles Reiche <charlieray(at)optonline.net>:
Dennis,
reduce warm up time) the switched power pin out of the transponder
will be left empty. 8 and 14 are tied together on multi voltage
encoders.... the old convention was 28 volts on pin 8 and 14 on pin
14....
other power wires from the transponder swithced power.
know exactly shich encoder and transponder you are using. I could
draw you up a schematic and fax it to you.
Let me know.
