parahawk
Joined: 10 Jul 2006 Posts: 21 Location: Washington State
Posted: Tue Sep 19, 2006 9:44 pm Post subject: Tailwheel dolly question |
There was mention on using a dolly to raise the tail to a level position with the wings for folding to avoid the swing back of the wings and removal of fuel.
Does anybody have a picture or drawing of such a dolly ??
Al
_________________ Flying is the highest form of life on earth. |
Michel
Posted: Wed Sep 20, 2006 5:27 am Post subject: Tailwheel dolly question |
| Quote: | From: parahawk [alfi98596(at)yahoo.com]
Eric and Al,
I was thinking about the front wheel of a child's bicycle with its fork. Then a Y-shaped weld to the two holes of the transverse pipe supposed to hold the Kitfox's dorsal fin. On the other side, a Y-shaped weld that has a leather strap over it to rest the fuselage.
I made a simple animated sketch of it here:
http://home.online.no/~michel/tmp/tail.swf
I think that by simply lifting the tail, the wheel will pivot in place. If not, a wheel choke and a lift plus forward movement would do it. The inverse is then done to lower the tail. What do you think?
Cheers,
Michel
dave(at)cfisher.com Guest
Posted: Wed Sep 20, 2006 5:44 am Post subject: Tailwheel dolly question |
Michel , excellent .swf there
I would add that if would have to limit the tail height to the door height.
Once the wings are folded , then it wold be hard to lower it as the weight
is only a guess but 150 to 200 pounds on that point .
Dave
dosmythe(at)cox.net Guest
Posted: Wed Sep 20, 2006 8:34 am Post subject: Tailwheel dolly question |
Michel,
Pretty good animation. I think you will need to put training wheels on
the main wheel to provide side to side support. Also, I know it was just a
close animation but the short 45 degree bar that holds the wheel in place
should probably be set where it will rest on the tail spring fuselage bolt.
I made one from wood. It's 2 foot square on the bottom with four castors.
It's about 4 inches square at the top (pyramid shaped). The tail spring
fuselage bolt rest in the center of the 4" top. I installed a safety strap
that goes around the tailwheel spring. Mine works great moving around the
hanger but seems a little unstable moving across an uneven floor or dirt.
bearup(at)ida.net Guest
Posted: Wed Sep 20, 2006 9:10 am Post subject: Tailwheel dolly question |
For those who don't want to build their own, here is a tailwheel hoist on
wheels that can be purchased.
Stan
http://www.tail-mate.com
Posted: Wed Sep 20, 2006 9:36 am Post subject: Tailwheel dolly question |
Michel,
I was going to say that you need a wheel that turns
back there to maneuver it. How about 2 big casters
for rough surfaces?
Kurt S.
--- Don Smythe <dosmythe(at)cox.net> wrote:
[quote] Michel,
parahawk
Posted: Wed Sep 20, 2006 1:44 pm Post subject: Re: Tailwheel dolly question |
Great animation Michael, thanks It gives me the basic idea, and I have to see what material I have laying around to use and come up with a similar functional device.
Thanks again
Posted: Wed Sep 20, 2006 2:21 pm Post subject: Tailwheel dolly question |
That's a handy little thing but, IMO, it would have to be modified to raise
the tail from the spring attachment point and not the tailwheel itself. You
don't want to support the tail on the wheel because it puts too much
tension on the spring.
Don Smythe
Float Flyr
Posted: Wed Sep 20, 2006 3:52 pm Post subject: Tailwheel dolly question |
I find the weight of the tail not to be too heavy until the wings are
folded. When I put the plane on a trailer I lift the tail up onto a support
that is lashed three ways then I fold my wings. I was thinking of getting
one of those little garden wagons ( about twice the size of a flyer) and
permanently installing a block on it to take the tail wheel for ground
handling with the wings folded. I would mount the block on a swivel to
allow the wagon to turn under the tail of the plane.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Ceashman(at)aol.com Guest
Posted: Wed Sep 20, 2006 4:50 pm Post subject: Tailwheel dolly question |
Stan
There we go Stan.That looks perfect.
The only thing lacking are the bigger wheels 'cause of the extra weight when the wings are folded.
All problems solved.
Eric. Atlanta area.
Guy Buchanan
Posted: Wed Sep 20, 2006 5:01 pm Post subject: Tailwheel dolly question |
At 10:09 AM 9/20/2006, you wrote:
| Quote: | For those who don't want to build their own, here is a tailwheel hoist on
Neat idea. Another good reason to learn how to weld.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
rjdaugh
Posted: Wed Sep 20, 2006 7:51 pm Post subject: Tailwheel dolly question |
Michel,
I am sure that that would work. You may have to play with the angle of the
bike steering axel to make it castor correctly. I think it should be close
to vertical.
Do you have two sets of hard points at the end of the fuselage? If so, you
could lock it into the second set once in the "up" position. I do think the
one wheel would be plenty stable if locked into the hard points.
I don't need one, but it is such a good idea, I may need to build one.
Oh, one data point. With near empty tanks, when both wings are folded on my
series 5, the weight on the tail wheel is 152 lbs, so the estimates others
have made sure seem right to me. I did a "folded weight and balance" to
determine where the weight would be when trailering my plane to the airport
for the first flights. It hasn't been on a trailer since.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Michel
Posted: Thu Sep 21, 2006 11:21 am Post subject: Tailwheel dolly question |
On Sep 21, 2006, at 5:51 AM, Randy Daughenbaugh wrote:
| Quote: | Do you have two sets of hard points at the end of the fuselage?
In fact I do, Randy: the aft dorsal fin go-through tube. And you may be
right, a second attachment point may be necessary. But - as I wrote - I
am not in need of folding my wings. I was just playing with the idea of
how to do it if I had to. I don't know how it is in the US but over
here hangar room is hard to find and often one has to move several
planes before getting out. So far, I am lucky, I can go in and out
alone without moving a thing. But I also know my hangar is condemned an
one day I'll need another solution.
Cheers,
Michel
Posted: Thu Sep 21, 2006 12:36 pm Post subject: Tailwheel dolly question |
Randy,
Someone is always getting it right here and thinking
of things the rest of us missed. A folded weight and
balance is a great idea.
Kurt S.
--- Randy Daughenbaugh <rjdaugh(at)rapidnet.com> wrote:
| Quote: | Oh, one data point. With near empty tanks, when
since.
Randy
Posted: Thu Sep 21, 2006 2:24 pm Post subject: Tailwheel dolly question |
And a fine sketch it was Michel.
You have the advantage of creating this computer stuff
faster than the rest of us. We are just using you to
fine tune it for the list. That happens when you
volunteer to draw!
On mine, I run the risk of breaking the wood stringer
under the tail using a strap. The strap would have to
run under the spring, or attach to a hard point, to
take the load when the wings are folded.
This is not a new problem. What did WW-I planes use?
More ideas flow here freely than any place else I
know.
Kurt S.
--- Michel Verheughe <michel(at)online.no> wrote:
| Quote: | Guys, my animated sketch was only an idea, I don't
know at all if it will work. Currently, I don't
need to fold my wings but ... I like to be
prepared!
Posted: Thu Sep 21, 2006 3:51 pm Post subject: Tailwheel dolly question |
Hey guys,
Why not just have something to cradle under the tailwheel ?
I like Michel' s idea but that will put alot of pressure on those dorsal fin
attach tube with fuel in wing tanks and even empty.
I use a 5 gal pail all the time under the tailwheel to keep the cat off the
plane. I would guess that I could fold the wings like that as well but it
is heavy to lift then.
You could just jack it up with a floor jack and roll it around on a firm
surface.
Hope this helps,
Dave
